  1. Announcements
    1. General Announcements
      This Board Contains General Announcements From the Administrators.
      2.3k
      posts
    2. Suggestions
      This Board is for Members to Suggest Things That Could Make Head-Case a Better Forum.
      1.6k
      posts
  2. Gear
    1. Headphones
      Grok Headphones in Fullness
      58k
      posts
    2. Headphone Amplification
      More. Power. Please.
      26.1k
      posts
    3. Home Source Components
      Can I Put a Grado Sonata In My E-Mu?
      23.1k
      posts
    4. Home Theater
      Where you eat your dinner, yo
      1.1k
      posts
    5. Portable Audio
      Headcases Outside? The Horror... The Horror...
      13.2k
      posts
    6. Audio Accessories
      Every Thing Under the Sun That You Didn't Even Know You Needed!
      4.5k
      posts
    7. Miscellaneous
      For Anything Gear Related That Won't Fit Anywhere Else. Yah!
      28.5k
      posts
    8. Do It Yourself
      Fight the Man, DIY Power!
      50.6k
      posts
    9. Speakers
      I Can't Hear You, Speaker Man, I'm Listening to My Headphones
      10.3k
      posts
    10. Field Recording
      A place to discuss field recording equipment and techniques
      13
      posts
  3. Manufacturer/Member of the Trade Boards
    1. Product Annoucements
      MoTs and Manufacturers, Make Announcements of New Products Here.
      2.1k
      posts
  4. Entertainment
    1. Games
      Who Would Win in a Fight, Pac-Man or Kratos?
      2.7k
      posts
    2. Music
      From Kumbaya to Hammer Smashed Face.
      39.8k
      posts
    3. TV
      TV Shows and Other Little Screen Related Things
      5k
      posts
  5. General Category
    1. Meets
      Who Would Want to Meet These People?!
      15.4k
      posts
    2. Off Topic
      Wild and Crazy Go Nuts!
      178.8k
      posts
    3. Food and Drink
      From Whisky to Water and Soup to Nuts
      28.8k
      posts
    4. Sports Talk
      Sports Rawk!!!!!!!!1
      7.6k
      posts
    5. GoRedwings19's Computer Help Hotline
      You Wanted It, You Got It; Computer Talk All Night Long.
      17.4k
      posts
  • Posts
    • I checked the forum members if they reacted to death of Norm Macdonald. Dunno why but somehow I knew he was beloved by forum members. Only famous person I've cried over his/her death. Read his book when i was "away". Imagine doing standup and made jokes about cancer and death for 20 mins (Me Doing Standup) while you're battling. Well at least he didnt lose his battle, it was a draw.
    • I think you are not measuring CMRR, but rather the common mode to differential mode conversion ratio. With the ‘conventional’ dual pot connection, the common mode signal at the input is attenuated at the same ratio as the differential signal; while with the shunt connection (without the help of a line isolation transformer), the common mode signal is not attenuated at all. Apx has common mode drive, why not use it to evaluate CMRR?
    • It looks neat, I like it.  Still gotta build the Iron Pre kit from diyaudio but what's another preamp.  I think I have the transistors too
    • I may be a hack, but I switched from using 4-gang pots to shunting stereo pots because I think they work better. A big part of the reason why I would build a balanced circuit is to benefit from its CMRR (and even order distortion cancellation by proxy). I measured the matching between gangs on a 20k RK27; it's better than the specified 20% tolerange, but it's not great. Here are some measurements at arbitrary rotations. Gang A Gang B Matching 51.4 51.6 0.4% 255.7 252.8 -1.1% 623 624 0.2% 1299 1300 0.1% 3042 3089 1.5% 4230 4368 3.2% 8470 9080 6.7% 14680 15420 4.8% 19100 19930 4.2% 19900 20380 2.4% The matching is directly proprotional to the CMRR. So I took a measurement of CMRR using the following circuit. The idea is that this simulates the balanced input of an amplifier and will tell us how balanced things actually are. Not very, it seems. Each trace is a different rotation angle on the pot, with the -115dB one being with the signal fully shunted. (There is some resitual resistance with the pot at 0.) -35dB of CMRR will significantly degrade an amp's performance. I repeated the measurements with a shunting pot configuration, using Yageo 1% 2k resistors and the same 20k pot.  Although the AP input capacitance degrades CMRR at high frequencies, even the worst 1kHz measurement is about 12dB better than the best measurement with the series pot. The low frequency degradation is most likely caused by the AP's 1/f noise-- we're measuring microvolts at this point. If I wanted to further improve performance, I'd use resistors with better matching. The Vishay ORN arrays are available in 0.01% and would probably be my pick. LT5400 isn't bad either.  https://www.mouser.ca/ProductDetail/71-ORNTA1001ZUF I don't know that this is necessarily relevant to the design in the first post-- looks like it doesn't use a pot at all-- but the circuit has its place.
    • Another F-tier company.
  • Topics
  • Birthday Members
    1. 609mike
      609mike
      42 years old
    2. Gypt
      Gypt
      59 years old
    3. kelvinz
      kelvinz
      43 years old
    4. Markmaxx
      Markmaxx
      67 years old
    5. needmorstuff
      needmorstuff
      50 years old
    6. pomme de terre
      pomme de terre
      Not Telling
    7. Slugth
      Slugth
      54 years old
    8. www.loopsjunkiez.com
      57 years old
    9. Ypoknons
      Ypoknons
      38 years old
  • Forum Statistics
    • Total Topics
      13.5k
    • Total Posts
      778.2k
  • Member Statistics
    • Total Members
      6,625
    • Most Online
      2,423
    Newest Member
    RestleSSOtaKU
    Joined
