GrindingThud Posted December 25, 2014 Report Posted December 25, 2014 Thanks! I should have checked for a new version 1st. Quote
GrindingThud Posted December 29, 2014 Report Posted December 29, 2014 (edited) //edit// Found the 1N914 above.....never mind. Very cool board, thanks! ------- What are all those little diodes on the board? Jumpers? gt Edited December 29, 2014 by GrindingThud 1 Quote
cetoole Posted December 29, 2014 Report Posted December 29, 2014 Diodes are diodes? That is inconceivable! 3 Quote
kevin gilmore Posted December 29, 2014 Author Report Posted December 29, 2014 diodes are there to protect the inputs from voltages > +/-12 on those amplifiers with high power output Quote
GrindingThud Posted December 29, 2014 Report Posted December 29, 2014 (edited) Did you have any luck locating a 47uf ceramic? I've been hunting and can't find one greater than 10V. Old thread, sorry: Kevin, do you have a schematic for the current version of this board? //UFN EDIT: Oh, and some BoM-questions: 1) I assume the diodes are just standard 1N4148/1N914? 2) Is the 47uF cap supposed to be ceramic or similar since it hasn't got the same footprint as the electrolytics? Edited December 29, 2014 by GrindingThud Quote
UFN Posted December 29, 2014 Report Posted December 29, 2014 Well, it seems the 25V part is backordered at Mouser until February. I haven't done anything yet, but maybe a 47uF bipolar electrolytic will work instead? Looks like you can get at least an 8mm part into the board (and maybe 10mm at a pinch). //UFN Quote
GrindingThud Posted December 29, 2014 Report Posted December 29, 2014 Yea, that's what I'll probably do for test until they come in. Well, it seems the 25V part is backordered at Mouser until February. I haven't done anything yet, but maybe a 47uF bipolar electrolytic will work instead? Looks like you can get at least an 8mm part into the board (and maybe 10mm at a pinch). //UFN Quote
luvdunhill Posted December 30, 2014 Report Posted December 30, 2014 Perhaps check out "pos-cap"? I am not sure the generic non trademark name, but that's what I would use. Quote
kevin gilmore Posted December 30, 2014 Author Report Posted December 30, 2014 no matter what i order, or when, mouser is always backordered on something Quote
gepardcv Posted January 12, 2015 Report Posted January 12, 2015 1. For the 100uF cap, I measured the leads at 2.5mm, and thought to use 647-UMA1E101MDD from Mouser. Is that adequate? 2. There are 7 short components on the board labeled "100k" left of the terminal blocks, but they don't look like normal resistor silkscreen images (2 by the in block, 3 by the out block, 1 to the right of each row of 1uF caps). Are they just resistors I'm supposed to mount at an angle so they fit? Quote
kevin gilmore Posted January 12, 2015 Author Report Posted January 12, 2015 those are vertical mount resistors to keep the board size down Quote
gepardcv Posted January 12, 2015 Report Posted January 12, 2015 Thanks! Is there any reason to use something like this slightly pricey Ohmite part (SM101031003FE) which seems like a perfect fit, rather than just bend the leads of an ordinary axial resistor for a vertical mount? Quote
GrindingThud Posted February 27, 2015 Report Posted February 27, 2015 Ready for test. 1st install will be in my SuSy Dynalo. 1 Quote
Pars Posted March 12, 2015 Report Posted March 12, 2015 (edited) I was going thru the schematic and the gerbers for this to do a layout including a muting switch and Molex KK connectors, which I like better than the terminal blocks. From what I am seeing in the gerbers, I had a couple of questions: It appears that the LM339s are powered by V+/V- rather than V+/GND? The LM339 has 4 comparators in it. It appears that 2 are being paralleled for each input signal? The input protection diodes run from V+/V-? There are a couple of 1uf capacitors (the yellow ones on GrindingThud's board above) that I am not sure where these go? I attached a pdf of the Eagle schematic I have worked up so far. Gilmore_protect3_schematic.png.pdf Edited March 12, 2015 by Pars Quote
kevin gilmore Posted March 12, 2015 Author Report Posted March 12, 2015 (edited) It appears that the LM339s are powered by V+/V- rather than V+/GND? yes The LM339 has 4 comparators in it. It appears that 2 are being paralleled for each input signal? yes, one for the + limit, the other for the - limit and then repeated 4 times for each of the signals The input protection diodes run from V+/V-? to the inputs of the lm339, not as shown. this should make it easier http://gilmore.chem.northwestern.edu/protector3.jpg Edited March 12, 2015 by kevin gilmore Quote
Pars Posted March 12, 2015 Report Posted March 12, 2015 Thanks Kevin. Yes, that is much easier to see than what the gerber viewer was showing me Quote
Pars Posted March 12, 2015 Report Posted March 12, 2015 This version should incorporate all of Kevin's corrections from my previous version. One further question: I know on Ti Kan's protection circuit, the relay drive requirements were pulling the + rail down, though he was using a virtual ground scheme on his. A user was the one who suggested the use of the 2N7000 and a 24V rather than a 12V relay, so that both rails were involved in supplying the relay drive. I notice here the you are using a 12V relay and driving it with V+ / GND. In actual use, does this present any problems? Gilmore_protect3_schematic.png.pdf Quote
kevin gilmore Posted March 12, 2015 Author Report Posted March 12, 2015 test circuit certainly worked, and I don't believe in virtual grounds for all sorts of reasons. when you are running a dynahi with 400ma of bias, 25ma to turn on the relay seems tiny Quote
GrindingThud Posted March 12, 2015 Report Posted March 12, 2015 (edited) Its running happily in my SuSy Dynalo with no issues that I've noticed. Provides a nice little startup delay and cuts out if I induce DC on the output. Edited March 12, 2015 by GrindingThud Quote
kevin gilmore Posted March 12, 2015 Author Report Posted March 12, 2015 the 15 second startup delay is intentional. you can change the resistor string to make it more or less sensitive Quote
GrindingThud Posted April 7, 2015 Report Posted April 7, 2015 (edited) This circuit should work single ended with both negative inputs grounded, yes? I'm planning on putting it in the CFA2. Edited April 7, 2015 by GrindingThud Quote
kevin gilmore Posted April 7, 2015 Author Report Posted April 7, 2015 yep in fact you can delete a number of the parts. 2 sets of RCRC and then a jumper on the C to ground. 1 Quote
gepardcv Posted April 8, 2015 Report Posted April 8, 2015 Pardon the ignorant question, but... does using this circuit make any sense with an electrostatic amp, like a KGSSHV or KGST? Quote
spritzer Posted April 8, 2015 Report Posted April 8, 2015 Nope, DC isn't a problem for electrostatics. 1 Quote
