dmcs414 Posted November 5, 2011 Author Report Posted November 5, 2011 DMCS414, where are you in the DFW area? If you would like to test out a couple of cheap USB DACs, I've got a Pico DAC only and a Monica USB. I also have an Audio-gd NFB3 that's my prime DAC now. If I ever get off my butt and order a couple parts, I've got most of a pair of Bantams ready to go as well. I'm in Plano; Shops of Legacy to be specific. But hell, I'd be happy to come wherever you are and bring my stuff. I'd welcome the chance to both meet another local into this hobby of ours and would be extremely grateful to try out the Pico (and your other DACs) with my CTH/TP setup.
dmcs414 Posted November 5, 2011 Author Report Posted November 5, 2011 I wouldn't recommend the Predator in this case because it has no line-out to feed into the CTH amp. The D12 has a line-out and dual Wolfson WM8740 DACs, if he needs a portable DAC and amp combo, which I don't recall him mentioning needing an amp or portability. The Pico DAC-only would be closer to a desktop DAC to feed the CTH, and can still be combined with a portable amp if needed later. I'm also fairly impressed so far with the Audioengine D1 24/96 USB/Optical DAC and amp, which has a line out. It uses an AKM4396 DAC, and costs about $170. EDIT - if the DAC doesn't need to be portable, then the HDP is a pretty good DAC for the price, with the bonus of a decent built-in headphone amp which sounds identical to the balanced RSA protector (although a little aggressive sounding). It will still sound better feeding the CTH amp, unless you run it with a Sigma 11 PSU which really improves the tone and soundstage of the built-in amp noticeably. That's correct. I'm more than happy with my CTH and am primarily looking for a good desktop solution (albeit one that isn't huge so I can bring it to a meet if the mood strikes me) but it will live most of the time at home. I know the Pico would work for me because Gary uses it with his TPs and I trust his judgement. I really liked a slightly larger DAC I heard in Austin a few months ago though too, the PS Audio DL3, but it's kinda pricy so I've wavered a bit on that one. Thanks for the advice all.
mrarroyo Posted November 5, 2011 Report Posted November 5, 2011 (edited) Late to the game but the iBasso D4 w/ a TopKit from Ron sounds mighty nice and it does have a line out. I have not tried the Pico DAC so I can not comment. Edited November 5, 2011 by mrarroyo
ktm Posted November 6, 2011 Report Posted November 6, 2011 I'm in Plano; Shops of Legacy to be specific. But hell, I'd be happy to come wherever you are and bring my stuff. I'd welcome the chance to both meet another local into this hobby of ours and would be extremely grateful to try out the Pico (and your other DACs) with my CTH/TP setup. You have a PM. The Pico is a pretty good bang for the buck DAC. If i hadn't of gotten a steal on the NFB3, it would still be in use. I just had a conversation at the Club Polk website about DACS. It's hard to choose one anymore with all the new ones coming out. The reality of the DAC world is higher priced ones sound better(with a few exceptions). You have to just stop when the money runs out!
jvlgato Posted November 9, 2011 Report Posted November 9, 2011 (edited) Peachtree Dacit. Thoughts? http://www.musicdire...tree-dacit.aspx Specifications: Inputs: 1-USB, 1-coax, 1-optical Outputs: 1-L&R RCA DAC: ESS Sabre32 9022 Output: 2v Output impedance: 200 ohms S/N:120dB Ground isolation: Transformer coupled inputs USB isolation: Galvanic Power supply: External 100-240v, 50-60Hz, 9V-1A Jitter at master clock: < 3ps Power consumption: 1w Chassis and housing: All metal Remote control: Included Dimensions HWD: 2 ½” x 6 ½” x 6 ½” Edited November 9, 2011 by jvlgato
crappyjones123 Posted January 7, 2012 Report Posted January 7, 2012 Instead of starting a new thread I'd figure I'd ask here. With my thinkpad busted and impending shoulder troubles I will probably be springing for a MacBook air rather soon. I have a crack and a torpedo to feed. Unless the MBA does spdif out, I'm assuming I'd be limited to USB. I have heard and very much liked the emotiva dac. It is all of $250 shipped. I had a gamma 2 dac built by misterx which I found clean but too sterile. I've previously had a parasound 1100 I think which was ok. However of those 3 I found the emotiva to be my favorite. Were I to make to make a jump in the Mac pool, the apogee duet comes to mind as a highly regarded dac from a while back but it hasn't really been spoken of in a long time I don't think. Was it just the fotm? John posted the peachtree audio Dacit but I have a faint recollection of him not liking it (?) or maye I'm just imagining things. Cambridge? Schitt? Denon? Arcam? Budget of $600. Used is better. Should I just go for the emotiva unit for $250 or try something else? I'm willing to go the USB to spdif but would prefer to keep things to USB if possible unless there is a glowing recommendation for the former. Projected gear - MacBook air, torpedo, crack, hd650, Jh16. Might try some grado stuff since it supposedly sounds good with the torpedo. I have found them to be rather bright every time I got them so perhaps something entirely new...
TMoney Posted January 7, 2012 Report Posted January 7, 2012 I use the M2Tech HiFace to output SPDIF from my macbook to my buffalo dac. If you want to keep the DAC you've already got I'm sure you could find one on the cheap. They pop up all the time on the other site.
jvlgato Posted January 7, 2012 Report Posted January 7, 2012 You're right, I didn't love the Peachtree. Too edgy, sibilants a little harsh, a fair amount of listener fatigue ... but maybe the Arête was too detailed/dry, and therefore a bad match? I was able to exchange it at Crutchfield for an Arcam rDAC, and I like it much more. It's much smoother and more musical, not the last word on detail, but it's pretty enjoyable. I think I can live with it for a while for the price. Though I'll say I'm keeping my eyes open for the next great small sized DAC. I'd like to hear a Lavry, maybe an Apogee, for when the audio budget is not on empty.
grawk Posted January 7, 2012 Report Posted January 7, 2012 For $600 you definitely should get the duet 2. By all reports, it's fucking fantastic. Then you can report back here and let us know what you think. Or stretch the budget a bit and get a Steinberg UR824. Also, report back on that when you do, because that's on my "to purchase soon" list. After I quit investing in stupid synthesizer gear.
crappyjones123 Posted January 7, 2012 Report Posted January 7, 2012 Dan I was reading about the duet 2 last night and it has features that I don't think I need (like oled everything) but I might be wrong. Are there any updates/improvements in the dac section or is it just a prettier duet with more input/outputs. I've never heard of the other dac you mentioned. Will look into that. Tmoney I don't have any dac at the moment. The Dacit is out then. Will read about the Arcam.
grawk Posted January 7, 2012 Report Posted January 7, 2012 who cares if it has features you don't need, if it has features you do need (like good sound) Anyway, the dac is apparently much improved, plus it's USB and not firewire, so you actually could use it on the air. The steinberg is a usb version of the MR816CSX
swt61 Posted January 7, 2012 Report Posted January 7, 2012 On the other hand...if the Emotiva is a known quantity that you like, and it's just $250, what's the issue? Surely you could sell it if you decide to try something else.
morphsci Posted January 7, 2012 Report Posted January 7, 2012 If you do not need the portability the Emotiva is a no-brainer as Steve said. I use one at work (which I bought from you ) and the other in the home office. The Duet 2 is on my short list but it will have to beat the Pico DAC/Amp, which so far has stood up quite well.
blessingx Posted January 7, 2012 Report Posted January 7, 2012 (edited) I know early reports put the Duet 2 as equal to the Duet 1 in SQ (thus very good). On Lavry/Benchmark level from my previous experience. And you've always got the ADC for vinyl. Edited January 7, 2012 by blessingx
