b_b Posted October 5, 2011 Report Posted October 5, 2011 No network card. I have an 11" Mackbook Air that will be connected to the PWD with USB. I thought about the network card but I'm not sure I like the idea of the interface. I just worry about the touch interface being cumbersome. PWD's ipad interface is very functional. I have Linn so I use - - - wait for it - - - ipeng and squeezebox 3. squeezebox plugin for Linn is pure awesome. I can control all my SBs, transporter and Linn using ipeng for ipad, all running off of a server running SB server that's sitting in another room. Everything is connected wirelessly (even the Linn). If I were you, I would give network streaming a chance. Quote
jvlgato Posted October 5, 2011 Report Posted October 5, 2011 I stream off my NAS which is two floors upstairs, and it works quite well. (Be aware though, that the PWD needs an ethernet connection; Wifi has been promised for a while, but don't think it's available yet.) I remote control using e-Lyric on iPad. I'd guess a computer setup via USB would be fine, too, but I don't know all the technical stuff behind how it would sound. I know PS Audio talks about their digital lens, which is supposed to make it sound equally good regardless of source. Can't say if that's true or not, though. Quote
HeadphoneAddict Posted October 6, 2011 Report Posted October 6, 2011 I stream off my NAS which is two floors upstairs, and it works quite well. (Be aware though, that the PWD needs an ethernet connection; Wifi has been promised for a while, but don't think it's available yet.) I remote control using e-Lyric on iPad. I'd guess a computer setup via USB would be fine, too, but I don't know all the technical stuff behind how it would sound. I know PS Audio talks about their digital lens, which is supposed to make it sound equally good regardless of source. Can't say if that's true or not, though. i think the Digital Lens is only included with the PWT and Bridge, but not via USB, optical or Coax input. Quote
jvlgato Posted October 6, 2011 Report Posted October 6, 2011 Oh, could be ... so would that imply worse sound via those digital inputs, or does the Lens just keep the transport and network bridge up to the level of the usual digital inputs? Quote
NoValidTitle Posted October 6, 2011 Author Report Posted October 6, 2011 i think the Digital Lens is only included with the PWT and Bridge, but not via USB, optical or Coax input. Do you know if I can slap a USB hard drive on the USB port of the bridge and listen that way? I'm assuming you cant and it's only for diagnostics. Quote
b_b Posted October 6, 2011 Report Posted October 6, 2011 Do you know if I can slap a USB hard drive on the USB port of the bridge and listen that way? I'm assuming you cant and it's only for diagnostics. I believe the digital lens is an add-on for PWD, and not PWT. As for your HD question, you should use a network storage with built-in Upnp server to feed your PWD. I don't know if this sounds better than USB, but it's certainly more flexible. You are not tied down to any one computer and you can add more PWDs or another streamer in the future for multi-room playback. Quote
jvlgato Posted October 6, 2011 Report Posted October 6, 2011 I'm pretty sure the USB port is only for diagnostics and firmware upgrades. Quote
NoValidTitle Posted October 6, 2011 Author Report Posted October 6, 2011 I'm pretty sure the USB port is only for diagnostics and firmware upgrades. Booooo Well I snagged one online for $425 brand new, seemed like a good deal. At the very least it will be fun to mess around with. I may have to pickup a wireless bridge as where I want to put my rig doesn't allow ethernet to be run in my apartment. Quote
HeadphoneAddict Posted October 7, 2011 Report Posted October 7, 2011 I believe the digital lens is an add-on for PWD, and not PWT. As for your HD question, you should use a network storage with built-in Upnp server to feed your PWD. I don't know if this sounds better than USB, but it's certainly more flexible. You are not tied down to any one computer and you can add more PWDs or another streamer in the future for multi-room playback. My understanding is that they are working on an separate or add-on digital lens for the PWD, but the Bridge and PWT have one already. But I'll try to research that more. Quote
jvlgato Posted October 7, 2011 Report Posted October 7, 2011 Booooo Well I snagged one online for $425 brand new, seemed like a good deal. At the very least it will be fun to mess around with. I may have to pickup a wireless bridge as where I want to put my rig doesn't allow ethernet to be run in my apartment. I used one of those gizmos that extends your wired network via the electrical outlets. This extended my network from the upstairs office to the basement in the opposite corner of a >100 year old house. It's worked suprisingly well for both my XBox for Netflix, and for streaming music to the PWD. I also needed to get a switch to allow me to make more than one ethernet ports out of one. I know wireless bridges are possible, but I really had a hard time getting that done. Maybe I'm just an idiot, though. Quote
morphsci Posted October 7, 2011 Report Posted October 7, 2011 I use an airport express as a wireless bridge for my DishDVR. Quote
grawk Posted October 8, 2011 Report Posted October 8, 2011 I use one on my directv dvr for the same purpose Quote
NoValidTitle Posted October 11, 2011 Author Report Posted October 11, 2011 (edited) So the PWD came today... Why the hell do they include a pair of white cotton gloves??? Also via usb with audrivana on my MBA I'm getting a constant 3-4 pops per second coming through when tracks are playing. Time to dig. edit: messing with the audrivana settings seems to make it go away but not at any consistant rate. For example if the forced upsampling is set to max sample rate upsampling it will pop, I change it to none and it stops... but I change it back and it stop. O_o Then I will change a different setting and it will come back, if I change that setting back it will still pop. Confusing. Edited October 11, 2011 by NoValidTitle Quote
johnwmclean Posted October 11, 2011 Report Posted October 11, 2011 Why the hell do they include a pair of white cotton gloves??? Quote
Grahame Posted October 11, 2011 Report Posted October 11, 2011 (edited) So the PWD came today... Why the hell do they include a pair of white cotton gloves??? Because they want to be Quad? http://futuremark.yo...read.php?t=7500 EDIT: Tempted to fondle? from http://www.psaudio.c...ctwave-dac?cat= Outside the PWD The chassis of the PWD is a metal sculpture that rivals the best ever built. A combination of aluminum and steel, the PWD weighs in at 20 pounds of elegance and beauty. The top cover is a hand painted, hand polished piano black cover that has been lavished over for hours. When you receive your PWD, you’ll find a pair of soft white gloves to pull the unit out of its protective cotton sleeve and unveil its beauty. Every person who has had the opportunity to see a PerfectWave in person has the same initial reaction: they reach out and softly caress it’s finish and admire its beautiful lines. Edited October 11, 2011 by Grahame Quote
NoValidTitle Posted October 12, 2011 Author Report Posted October 12, 2011 This Bridge fucking sucks. It's so damn buggy. I'm honestly surprised PS Audio put their name on the software. Quote
jvlgato Posted October 12, 2011 Report Posted October 12, 2011 Really? Mine hasn't been bad. Not perfect, but not bad. What is happening with yours? Quote
NoValidTitle Posted October 12, 2011 Author Report Posted October 12, 2011 Really? Mine hasn't been bad. Not perfect, but not bad. What is happening with yours? 1. If I pause a track it restarts the track at the beginning every time... 2. ...that's if it actually pauses when I hit pause 3. The elyric software keeps crashing 4. The iDevice app is ungodly sluggish 5. When I hit play on a track it takes about 20 seconds before it actually stars 6. Tracks occasionally skip Quote
HeadphoneAddict Posted October 12, 2011 Report Posted October 12, 2011 1. If I pause a track it restarts the track at the beginning every time... 2. ...that's if it actually pauses when I hit pause 3. The elyric software keeps crashing 4. The iDevice app is ungodly sluggish 5. When I hit play on a track it takes about 20 seconds before it actually stars 6. Tracks occasionally skip Try upgrading the software via the front panel. Quote
NoValidTitle Posted October 13, 2011 Author Report Posted October 13, 2011 Unfortunately I'm already on the latest. Quote
jvlgato Posted October 13, 2011 Report Posted October 13, 2011 Well that sucks! Weird, mine does almost none of that. Only an occasional skip, but even then, it can be traced to network traffic or something wrong with the file. Maybe unplug and replug in the electricity, try resetting the bridge, try reinstalling the bridge, try calling PS Audio? Wish I could be more helpful ... Quote
morphsci Posted October 13, 2011 Report Posted October 13, 2011 Why not just return the bridge as defective and get a new one? Quote
jvlgato Posted October 13, 2011 Report Posted October 13, 2011 (edited) I suppose that would be a lot easier ... Edited October 13, 2011 by jvlgato Quote
