Thanks for the update, Todd. Also big thanks for all the work you do to make this forum run so well.
I just noticed a problem with the devil smiley. It displays properly in the edit window, but apparently the new SW doesn't recognize it and displays > :D in the post.
There could easily be problems with other smileys too. I can try them all here or in a forum provided by you if you'd like.
  • Replies 140
What Ken said. This is the most bestest-running forum evar.
I'm not sure if this has been already posted, but anyone having problem with mobile theme? It used to be that if I changed it to mobile theme on my iPhone, it didn't change it to mobile theme when I browsed the forum on my laptop. I haven't been able to make it where mobile theme stays on iPhone and regular theme stays on my laptop.
I'm experiencing the exact same thing Salty.
Thanks Todd! Tapatalk still seems bonked, and I could not get Safari to work on my iPhone for awhile after you announced the update. I signed out and then shut down the phone without any positive effect, but it now seems to be working.
I'm still having the same issue...when I try to reply to a post, no options appear to include images, links, bold/underline/italics etc....
tried it in Opera Mini with the same results...
Tapatalk should be working now - though I know I'm not having any luck w/ unread posts part working it just shows 0 unread which isn't correct.
Also I made some behind the scenes changes to a few things - if you notice anything odd w/ attachments/avatars/uploads please let me know.
Now mobile theme automatically shows up on iPhone and the regular theme on computers. Thanks, Todd.
As for Tapatalk, it's still not working for me - unread posts sections results in error every time and while forums show up, but thread are messed up.
Edited by Salt Peanuts
Something still related to search: I was trying to search using the forum option, but all the links points me to the first post of a thread. Could we change this to have the thread links point to the post that contains the matching keywords? Thanks!
Use the advanced search for that (to get to advanced search click on the little gear looking icon right next to the search box) - then in that window scroll down to the "Display Results" line and change this to "As Posts".
