Nanoha Posted December 12, 2006 Report Posted December 12, 2006 Lite Special Edition? Where is the info on this? Quote
Guest sacd lover Posted December 12, 2006 Report Posted December 12, 2006 Lite Special Edition? Where is the info on this? http://www6.head-fi.org/forums/showthread.php?t=211742 Quote
grawk Posted December 12, 2006 Report Posted December 12, 2006 Hardcore audiophile bullshit? Yeah when I've spent thousands on gear, I'll take a player that can at least bypass Windows kmixer The airport express doesn't use the kmixer at all. Quote
volcomjerk Posted December 12, 2006 Author Report Posted December 12, 2006 iTunes uses quicktime to decode music files and quicktime is considered to be one of the best sounding decoders. Back in the days of winamp 2 craze, quicktime was considered to sound the best. I don't know what player takes the throne for that now. Quote
Bob_McBob Posted December 12, 2006 Report Posted December 12, 2006 There's someone on head-fi selling a Dynahi that looks pretty nice. Having just sold one myself (only for the slightly retarded reason of trying a nice tube amp instead), I can tell you it is an amazing amp. The GS-1 is a dynalo isn't it? Quote
TheSloth Posted December 12, 2006 Report Posted December 12, 2006 There's someone on head-fi selling a Dynahi that looks pretty nice. Having just sold one myself (only for the slightly retarded reason of trying a nice tube amp instead), I can tell you it is an amazing amp. The GS-1 is a dynalo isn't it? Isn't the dynahi a much higher output version of a dynalo? Isn't it the same circuit give or take a bit? Shouldn't that mean that in some ways the dynalo will actually be better if it has enough power for your headphones? Quote
grawk Posted December 12, 2006 Report Posted December 12, 2006 Isn't the dynahi a much higher output version of a dynalo? Isn't it the same circuit give or take a bit? Shouldn't that mean that in some ways the dynalo will actually be better if it has enough power for your headphones? With nothing else changed, higher power available at the same gain seems like it would be the preferrable situation. Unless you don't like heat. Quote
n_maher Posted December 12, 2006 Report Posted December 12, 2006 The GS-1 is a dynalo isn't it? With Justin's new modules I believe it's no longer really a valid comparison. I could be wrong though. Quote
TheSloth Posted December 12, 2006 Report Posted December 12, 2006 With Justin's new modules I believe it's no longer really a valid comparison. I could be wrong though. Yeah, the new modules have nothing to do with the Gilmore designs any more (the lite of course is unchanged), expect perhaps some inspiration. Quote
TheSloth Posted December 12, 2006 Report Posted December 12, 2006 With nothing else changed, higher power available at the same gain seems like it would be the preferrable situation. Unless you don't like heat. Wouldn't the higher power result in increased noise and distortion, purely theoretically? Quote
grawk Posted December 12, 2006 Report Posted December 12, 2006 Wouldn't the higher power result in increased noise and distortion, purely theoretically? My experience is distortion is caused by a lack of power, not an abundance of it. Noise is a feature of poor design, somewhere, not power. Quote
Guest sacd lover Posted December 14, 2006 Report Posted December 14, 2006 Wouldn't the higher power result in increased noise and distortion, purely theoretically? No. Not unless you are trying to squeeze more power out of the same output devices. If you add more output capacity by using say more transistors per channel .... or higher power transistors .... there is no reason for the amp to have higher noise or distortion. Quote
donunus Posted October 24, 2008 Report Posted October 24, 2008 Apple Airport Express is better than any usb source I've heard, if you're starting from itunes. How does this exactly work now? I have a laptop with wifi and a gilmore lite so all I do is get an airport express and connect pc to airport wirelessly then airport has analog outs to go in the glite??? How do I use my interconnects with airport express? I don't exactly understand this. Also, if I do this, can I also connect a usb dac to the airport express or is it a good enough dac in itself to connect directly to my rig Quote
grawk Posted October 24, 2008 Report Posted October 24, 2008 Holy old posts batman To use the airport express without a dac with your glite, take a mini to rca cable and hook them up. You can't add a usb dac to the airport express. That said, I recind my above comment about the airport express being better than any usb dac I've heard. The various headroom dacs and the pico quite handily beat the airport express. But in the price range, I still prefer the airport express. And you can add an optical dac to it later. The advantage the aex has is it's not electrically connected to the computer, so you get some noise isolation. If you then hook it up to a dac optically, you're golden. Quote
donunus Posted October 24, 2008 Report Posted October 24, 2008 aaahh so it has a toslink out on the unit itself. good stuff! I can then expand my choices of dacs instead of being limited to usb dacs only Quote
grawk Posted October 24, 2008 Report Posted October 24, 2008 It's got optical mini, not toslink, but it's the same basic concept. Quote
