I'm in for a set of KGSSHV boards, but I can't seem to get to the spreadsheet - it goes into an endless redirect until timeout.
Edit: got it to work by slumming and using IE.
I'm in for an offboard KGSSHV set- spreadsheet has been updated.
Just wanted to say- a big thanks to everyone who made this possible, it's much appreciated!
I've never made an umbilical for this kind of voltage... any suggestions on wire? or can I use any old 600v teflon?
navships is the normal suggested source for teflon wires. His stuffs are rated 600v.
I'd recommend finding something labeled by Alpha or Belden. I don't trust wire unless it has a printed rating on the sleeve. Also, you can add heat shrink or teflon to the wire if you want to be extra certain.
Now if they'd sell the braided stuff using a couple of different colours instead of the same colour, it'd be perfect. I already bought a bag of 2m lengths in mixed colours of 600V generic "Kyouwa" wire anyway.
Edited by Currawong
Thanks for the info on brands.
Just bough last roll of this one. :dance: Could not fine anything cheaper.
http://ampbuildersparts.com/store/index.php?main_page=product_info&cPath=34&products_id=293
You do realize that we're talking, what 1.7kV Vpp here?
The ratings on the 600V wire is 600V AC.
Which just barely works at max voltage swing.
At least the teflon stuff i use is rated that way.
It's hard to infer AC ratings from DC ratings and vice-versa though, at least that is what I've found. Regardless, unmarked wire is a dice roll in my book.
The wire i used is actually labeled. At least some of the colors were labeled.
If its actually teflon, and nothing else is as slippery and hard to strip as
teflon, then if its the right gauge, its likely to be 600V. The much higher
voltage stuff is definitely available, but seems to be only available in red.
I am waiting to see if anyone can get the original DynaFet group buy boards working,
not going to invest in another DynaFet board at least until it becomes apparent
all attempts to get a reliably stable group buy board have been abandoned.
That said, I would rethink a new DynaFet group buy board,
as the a second group buy board may run into the same stability issues as the first attempt.
I would like to see several successful builds of a prototype DynaFet before I would consider investing
Edited by DigiPete
I didn't realise there were different ratings for AC and DC. Checking the packet of what I got, it says 600VDC and 750VAC. I can get, locally, just about any spec power wire (maybe not overhead power line spec, but not far off it) and I'm certainly not interested in stopping my heart through an accident the result of bad wiring.
I was thinking aloud about the braiding as I'm pondering whether I'll try bothering with the hassle of a two-case build.
Is there a reason to get more then one set of the same board?
1) make more than 1 amp :D
2) just in case you manage to fry it, scorch it, lift traces, snap it in half....
Spanish gang is having these same doubts, but we decided to get a few, or at least knowing how much they'd cost.
Yep. Ours got knocked out for an hour or so, but was back by 11 or so. Sucks that yours might be out for that long KG... hope they get it fixed sooner.
