humanflyz Posted December 7, 2006 Report Posted December 7, 2006 Do I need to do anything to run balanced headphones out of the XLR outputs on the Lavry? Can I simply get someone to recable the headphones terminated in female XLRs or do I need to do something different? I currently have the jumpers in the Lavry set on balanced output mode.
philodox Posted December 7, 2006 Report Posted December 7, 2006 You can get your headphones recabled with female XLR's, but I would use adapters if I were you in case you get a balanced amp down the road.
grawk Posted December 7, 2006 Report Posted December 7, 2006 Once you've recabled for balanced, switching connectors is easy. My preference for balanced is a 4pin xlr, and then I have adapters to male and female 3pin, as well as mini and 1/4".
