If the wires are enameled you can burn it off with any iron worth anything and it doesn't get any more simple than cutting the end off a cable and soldering on whatever termination desired. I think we can pretty much end this thread with that.
Yeah, that's why you're asking about re-terminating shitty cables and why you think for some reason 5 feet for a headphone cable is long enough.
I wouldn't go so far as to call it shitty. Snake oil maybe.
I think 5 ft is long enough because I sit right next to my gear and listen
I'm curious about that as well, if I consider myself a decent DIYer I'd just as much go and buy the cable and do it than wait around for replies to a post. Probably could have been done with the cable by now, actually.
I always like to see if anyone has done anything similar to what I am thinking about doing, and the 10ft 1/4" cable is out of stock. I saw no harm in asking just to see if it had been done before.
Thanks for the warm response
Ooh, can I give the advice for those questions? If he thinks he's confused now...
You're always welcome to share your wisdom with me, loverboy. :P
Pffft. Real DIYers have MAPP gas torches ...
Yep i have one of those. Needed when i changed out my
water heater. Not enough whoopie out of a propane torch
to sucessfully solder the copper fittings. Almost as good
as an oxy/accetyline torch without the required large
cylinders.
Have a small hydrogen torch for some specialty work :D
cylinders.
I learned exactly what you're saying when I was finishing my basement 5 years ago, and the damn pipes kept leaking and I couldn't sweat the joints properly with propane because it wasn't hot enough (especially after turning on the water and getting the pipes wet and leaky). Doh!
