I don't mind doing this. Please PM me if you want in on the SMD version of the attenuator with how many boards you would like and I'll post the totals in this thread. Per Kevin, they will be approximately $15.28 + shipping depending on the final count.
Sorry. This didn't include assebmly / parts / etc.
If enough people are interested in assembed boards, we can look into that as well. Please let me know if you are interested in "Assembled", "Boards Only" or "Either" (include preference).
Edited by Kerry
I would be interested in boards. I've been waiting for a good, reliable, relay based attenuator solution. :) If we are doing a GB on the relays I'd be interested in that as well.
pm sent
Seems like we could use different voltage relays (other that 12V) provided the coil current is under 500mA. Just wanted to double check this.
EDIT: Also the digital voltage could support 5V as well.
EDIT2: Nevermind. I see the address ID jumper.
Edited by Kerry
The programming is way out of my league - I'd be in for 2 boards, assembled or blank, if I could get pointed in the right direction as far as control
PLEASE SEE POST FOR THE LATEST COUNTS.
Here's where we currently are:
Name - Count - Preference
grawk - 4 - A
Driftwood - 6 - EA
luvdunhill - 2 - B
ujamerstand - 4 - B
deepak - 3 - A
cetoole - 4 - E
manaox2 - 2 - A
el_doug - 2 - E
DouglasQuaid - 2 - EA
jgazal - 2 - A
Lil Knight - 4 - A
nattonrice - 4 - E
kevin gilmore - 4 - EA
looser101 - 6 - E
chinsettawong - 2 - E
Kerry - 6 - B
Fing - 4 - A
Preferences: A = Assembled; B = Board Only; E = Either; EA = Either-Assembled Preferred
If I have it wrong here or you would like to change something please PM me.
Just a reminder. Please PM me all requests so we can keep the thread clean. I'll post an update at the end of the day (will be on vacation soon so I hope I can keep up).
Also, depending on the pricing for assembly we may or may not end up doing this. I will reach out tomorrow for pricing based on a few different quantities.
Also, sounds like a group buy for relays might be a good idea as well.
Edited by Kerry
EDIT2: Would it be useful to add some address jumpers so that you could control the left and right channels of a balanced amp separately? One jumper per board might be enough for this.
This would be quite useful. I could imagine attenuating two separate streams to two different people. Or do channel matching for testing headphones.
I don't know about the resistors, but I've hand-wired G6k-2F relays before. They're the same distance between pins as the G6SK, and the same thickness of the leads, just two less pins.
Soldering them to a pcb isn't really that bad. So bare boards are perfectly fine with me.
Here the new board counts:
grawk - 4 - A
Driftwood - 6 - EA
luvdunhill - 2 - B
ujamerstand - 4 - E
deepak - 2 - A
cetoole - 4 - E
manaox2 - 2 - A
el_doug - 2 - E
jgazal - 2 - A
Lil Knight - 4 - A
nattonrice - 4 - E
looser101 - 6 - E
Kerry - 6 - B
Fing - 4 - A
blubliss - 4 - EA
n3rdling - 4 - EA
guzziguy - 2 - E
Pars - 2 - B
Nebby - 4 - EA
TOTAL 76
Please let me know if I've made any mistakes.
Also, can anyone pull a BOM together real quick. It doesn't have to be perfect, but I need one to send over to the manufacturer to get a quote on the assembly. I would do it, but I'm not going to have time tonight.
Thanks
Edited by Kerry
