  • 9 months later...
I've built a simple circuit with a PGA2310 which is very similar to the 2320 but comes in a DIP16 package. The only things I haven't done yet are figure out the input and output impedance and how well balanced operation would work.
  • 2 months later...
Anyone have used the KG Digital Att with Pot/Vol/Bal controls for an amp. If so how did it work out.
What did you use for controls. Want to do it but was interested if there were
any snags found.
Thanks
Les
  • 2 months later...
Just finished my two boards and wanted to say thanks to Kevin/Kerry and stv1756 for their valued contributions.
Assembly was straight forward and for a guy with buggared eye sight the 1206 smd were great.
My pair are for my T2 and will be balanced arrangement. The code worked well and absolutely thrilled.
This is my 3rd KG project that's worked first time and above expectation.
Les
  • 1 year later...
finally cleaning up, i have one extra set of the original attenuators, part of the buy that
kerry did, professionaly assembled, and i tested them last night, so if anyone is interested
i can sell that pair. Price is whatever kerry charged, which might take me a while to look up.
I'd like to buy
If I remember correctly they were around $97 $99 ​per board.
I'm going to review the new smt version of the board and order a couple so I can test it.
EDIT: I just checked on the price of the original assembled boards.  I have a set sitting in front of me that i'm putting into my BH build.
Edited by Kerry
I'm interested, count me in for one set please.
I was just looking at the 24.3K BOM and Mouser, and it appears that Mouser doesn't stock 6 of the resistor values anymore (in the IRC/TT PFC 1206).
If anyone has already worked through this problem, let me know.
Also, I assume that this version of the attenuator (Kerry group buy, 24.3K impedance) would work fine with the Multiamp?
Timely, I know ::)
Chris
Edited by Pars
I'm also interested in a set if you're willing to do a run, what impedance are you aiming for?
for multiamp, you really want the 10k version.
Is it still an issue if using FET input? I believe the 1st BOMs were for 10K? I presume the Rt termination resistor = 10K is what I am looking for?
