Kerry Posted August 17, 2011 Report Posted August 17, 2011 (edited) Here's the code I used for the rotary encoder and the Uno board: #include "Wire.h" // Set up the Variables int state, prevstate = 0; int nextEncoderState[4] = { 2, 0, 3, 1 }; int prevEncoderState[4] = { 1, 3, 0, 2 }; const byte attSetAddr = 0x38; const byte attResetAddr = 0x3E; const int offVolume = 100; const int relayLatchTime = 3; // time in milliseconds int newVol = offVolume ; void setup() { delay(1000); Wire.beginTransmission(attResetAddr); Wire.send(0); Wire.send(0xFF); Wire.endTransmission(); delay(relayLatchTime); Wire.beginTransmission(attResetAddr); Wire.send(0); Wire.send(0x00); Wire.endTransmission(); delay(relayLatchTime); // Set up for the encoder pinMode(5, INPUT); pinMode(6, OUTPUT); pinMode(7, INPUT); digitalWrite(5, HIGH); digitalWrite(6, LOW); digitalWrite(7, HIGH); } void SetVolume(int newVol) { int sendVal; // now set sendVal = (byte)newVol ; Wire.begin(); Wire.beginTransmission(attSetAddr); Wire.send(0); Wire.send(sendVal); Wire.endTransmission(); delay(relayLatchTime) ; Wire.begin(); Wire.beginTransmission(attSetAddr); Wire.send(0); Wire.send(0x00); Wire.endTransmission(); delay(relayLatchTime); // now reset sendVal = 0xFF ^ (byte)newVol; Wire.beginTransmission(attResetAddr); Wire.send(0); Wire.send(sendVal); Wire.endTransmission(); delay(relayLatchTime); Wire.beginTransmission(attResetAddr); Wire.send(0); Wire.send(0x00); Wire.endTransmission(); delay(relayLatchTime); } void loop() { state = (digitalRead(7) << 1) | digitalRead(5); if (state != prevstate) { if (state == nextEncoderState[prevstate]) { newVol = newVol + 1; if (newVol > 255) newVol = 255; SetVolume(255-newVol); } else if (state == prevEncoderState[prevstate]) { newVol = newVol - 1; if (newVol < offVolume) newVol = offVolume; SetVolume(255-newVol); } prevstate = state; } } EDIT: Quick thanks to Max and the Arduino site where I got some of the code segments Edited August 17, 2011 by Kerry 1
Milosz Posted August 17, 2011 Report Posted August 17, 2011 Has anyone ever tried interfacing a Krell CAST DAC or Audio-Gd ACSS DAC to a KGSS/KGSSHV amp, keeping the signal in the current domain? I would think that whatever you used for a volume control- be it pot, stepped attenuator, resistor/relay or IC switches would have less sonic impact in an ACSS circuit than using a voltage divider in a voltage-domain circuit..... and in using current domain signals you eliminate the I-to-V stage in the DAC, any stage eliminated is a stage that can't screw with the sound.
kevin gilmore Posted August 17, 2011 Author Report Posted August 17, 2011 Too specific for most people. Besides which, cast does not really work the way you might think it does. Raw current out of a dac is unusable with even a few feet of cable, and then there are all the offsets that need to be controlled.
deepak Posted August 17, 2011 Report Posted August 17, 2011 I received mine as well, they look great, thanks Kerry!
Milosz Posted August 18, 2011 Report Posted August 18, 2011 Too specific for most people. Besides which, cast does not really work the way you might think it does. Raw current out of a dac is unusable with even a few feet of cable, and then there are all the offsets that need to be controlled. Yeah, you are right, for the ~7(?) DACs or analog preamps out there that have CAST or ACSS outputs, I guess developing a current domain input for the KGSS/KGSSHV would be a fair bit of work that would benefit very few users. While from all accounts it seems this signal transmission scheme does offer real sonic benefit, it is used by almost no one.
Shaman Posted August 18, 2011 Report Posted August 18, 2011 Got my boards as well! Thanks for everything and looking forward to the KGITSOJC!
chinsettawong Posted August 19, 2011 Report Posted August 19, 2011 Get my boards today. Thanks Kerry for making this GB. Could someone help me with how to use this thing? Wachara C.
Kerry Posted August 19, 2011 Report Posted August 19, 2011 (edited) Just wanted to post where I'm at with testing/shipping. Here's everything shipped. I should have some time this weekend to get through some more testing. Name - Assembled - Bare Boards - Shipped Beefy - 0 - 4 - S blubliss - 4 - 0 - S cetoole - 0 - 10 - S chinsettawong - 2 - 0 - S deadlylover - 0 - 6 - S deepak - 2 - 2 - S DouglasQuaid - 2 - 2 - S Fitz - 0 - 4 - S Flyingsparks - 0 - 4 - S Horio - 0 - 2 - S johnwmclean - 0 - 2 - S kevin gilmore - 4 - 4 - S luvdunhill - 0 - 2 - S nattonrice - 0 - 4 - S Pars - 0 - 2 - S Shaman - 0 - 2 - S tcpoint - 0 - 2 - S Vortex - 0 - 10 - S Edited August 19, 2011 by Kerry
Vortex Posted August 22, 2011 Report Posted August 22, 2011 My boards arrived in good shape. Thanks Kerry!
stv1756 Posted August 24, 2011 Report Posted August 24, 2011 (edited) Here is code to control two attenuators (i.e. balanced) with a potentiometer. Wire pot pins 1 and 3 to 5v and ground, and the wiper to A0 (analog input 0). Should work for a single board as well. For balanced configuration jumper id pins 1 and 2 of the second board (to change the address). Based on the code previously posted by Kerry. #include <Wire.h> int sensorPin = A0; // select the input pin for the potentiometer const byte attSetAddr0 = 0x38; const byte attSetAddr1 = 0x39; const byte attResetAddr0 = 0x3E; const byte attResetAddr1 = 0x3F; const int numReadings = 12; // max readings for averaging const int relayLatchTime = 3; // time in milliseconds const int maxVolVariation = 3; // max allowed variation in pot voltage without changing volume int oldVol = 0; int readings[numReadings]; // array to hold volumes (for averaging) int readIdx = 0; // readings array index void setup() { for (int i = 0; i < numReadings; ++i) readings = GetVolumeSetting(); oldVol = GetVolumeSetting(); delay(1000); } void WireTrans(boolean begin, byte addr, int range) { if (begin) Wire.begin(); Wire.beginTransmission(addr); Wire.send(0); Wire.send(range); Wire.endTransmission(); delay(relayLatchTime); } void SetVolume(int newVol) { // comment out if volume control works in reverse //newVol = 255 - newVol; // put avg volume into newVol readings[readIdx] = newVol; readIdx += 1; if (readIdx == numReadings) readIdx = 0; int total = 0; for (int i = 0; i < numReadings; ++i) total += readings; newVol = total/numReadings; // include only if relay chatter because of pot voltage variations if (abs(newVol-oldVol) < maxVolVariation) return; oldVol = newVol; // now set int sendVal = (byte)newVol; WireTrans(true, attSetAddr0, sendVal); WireTrans(true, attSetAddr0, 0); WireTrans(true, attSetAddr1, sendVal); WireTrans(true, attSetAddr1, 0); // now reset sendVal = 0xFF ^ (byte)newVol; WireTrans(false, attResetAddr0, sendVal); WireTrans(false, attResetAddr0, 0); WireTrans(false, attResetAddr1, sendVal); WireTrans(false, attResetAddr1, 0); } int GetVolumeSetting() { // pot reading int sensorValue = analogRead(sensorPin); // convert to new range sensorValue = map(sensorValue, 0, 1023, 0, 255); return sensorValue; } void loop() { SetVolume(GetVolumeSetting()); delay(50); } Hope this helps, Steve Edited August 24, 2011 by stv1756
kevin gilmore Posted August 24, 2011 Author Report Posted August 24, 2011 need version with 2 pots, one for volume, the other for balance.
stv1756 Posted August 26, 2011 Report Posted August 26, 2011 Here is working code for volume plus balance: #include <Wire.h> int sensorPinVol = A0; // select the input pin for the volume potentiometer int sensorPinBal = A1; // select the input pin for the balance potentiometer const byte attSetAddr0 = 0x38; const byte attSetAddr1 = 0x39; const byte attResetAddr0 = 0x3E; const byte attResetAddr1 = 0x3F; const int numReadings = 12; // max readings for averaging const int relayLatchTime = 3; // time in milliseconds const int maxPotVariation = 4; // max allowed variation in pot voltage without changing volume int currVol = 0; int currBal = 0; int volReadings[numReadings]; // array to hold volumes (for averaging) int balReadings[numReadings]; // array to hold balances (for averaging) int volReadIdx = 0; // readings array index for volume int balReadIdx = 0; // readings array index for balance void setup() { for (int i = 0; i < numReadings; ++i) { volReadings = GetVolumeSetting(); balReadings = GetBalanceSetting(); } currVol = GetVolumeSetting(); currBal = GetBalanceSetting(); delay(1000); } void SetVolume(int newVol) { boolean balChanged = SetCurrBalance(GetBalanceSetting()); // put avg volume into newVol volReadings[volReadIdx] = newVol; volReadIdx += 1; if (volReadIdx == numReadings) volReadIdx = 0; int total = 0; for (int i = 0; i < numReadings; ++i) total += volReadings; newVol = total/numReadings; // include only if relay chatter because of pot voltage variations if (abs(newVol-currVol) < maxPotVariation) { if (balChanged) newVol = currVol; else return; } else currVol = newVol; int leftVol; int rightVol; if (currBal < 125) { leftVol = newVol; rightVol = newVol*127/currBal; if (rightVol > 255) rightVol = 255; } else if (currBal > 130) { leftVol = newVol*127/(255-currBal); rightVol = newVol; if (leftVol > 255) leftVol = 255; } else { leftVol = newVol; rightVol = newVol; } // now set int sendLeftVal = (byte)leftVol; int sendRightVal = (byte)rightVol; WireTrans(true, attSetAddr0, sendLeftVal); WireTrans(true, attSetAddr0, 0); WireTrans(true, attSetAddr1, sendRightVal); WireTrans(true, attSetAddr1, 0); // now reset sendLeftVal = 0xFF ^ (byte)leftVol; sendRightVal = 0xFF ^ (byte)rightVol; WireTrans(false, attResetAddr0, sendLeftVal); WireTrans(false, attResetAddr0, 0); WireTrans(false, attResetAddr1, sendRightVal); WireTrans(false, attResetAddr1, 0); } boolean SetCurrBalance(int newBal) { // put avg balance into newBal balReadings[balReadIdx] = newBal; balReadIdx += 1; if (balReadIdx == numReadings) balReadIdx = 0; int total = 0; for (int i = 0; i < numReadings; ++i) total += balReadings; newBal = total/numReadings; // include only if relay chatter because of pot voltage variations if (abs(newBal-currBal) < maxPotVariation) return false; // currBal remains the same currBal = newBal; return true; } void WireTrans(boolean begin, byte addr, int range) { if (begin) Wire.begin(); Wire.beginTransmission(addr); Wire.send(0); Wire.send(range); Wire.endTransmission(); delay(relayLatchTime); } int GetVolumeSetting() { // pot reading int sensorValue = analogRead(sensorPinVol); // convert to new range sensorValue = map(sensorValue, 0, 1023, 0, 255); return sensorValue; } int GetBalanceSetting() { // pot reading int sensorValue = analogRead(sensorPinBal); // convert to new range sensorValue = map(sensorValue, 0, 1023, 255, 0); return sensorValue; } void loop() { SetVolume(GetVolumeSetting()); delay(75); } BTW, these attenuators sound fantastic. Many thanks to Dr. Gilmore and Kerry! Steve
Kerry Posted August 26, 2011 Report Posted August 26, 2011 I've got just about everything shipped. Two more to go, which I'll get out early next week. I wanted to beat the hurricane before Manhattan floats away
El_Doug Posted August 26, 2011 Report Posted August 26, 2011 I've got just about everything shipped. Two more to go, which I'll get out early next week. I wanted to beat the hurricane before Manhattan floats away thanks a bundle!
Kerry Posted August 26, 2011 Report Posted August 26, 2011 (edited) Here's the list of what is shipped: Name - Assembled - Bare Boards Beefy - 0 - 4 blubliss - 4 - 0 cetoole - 0 - 10 chinsettawong - 2 - 0 deadlylover - 0 - 6 deepak - 2 - 2 DouglasQuaid - 2 - 2 Driftwood - 4 - 6 dwhat - 4 - 0 el_doug - 2 - 0 Fing - 2 - 0 Fitz - 0 - 4 Flyingsparks - 0 - 4 guzziguy - 2 - 0 Horio - 0 - 2 Jezz - 2 - 2 jgazal - 2 - 0 johnwmclean - 0 - 2 Kerry - 2 - 10 kevin gilmore - 4 - 4 luvdunhill - 0 - 2 manaox2 - 2 - 0 MASantos - 2 - 2 Max - 1 - 0 minivan - 2 - 0 n3rdling - 4 - 0 nattonrice - 0 - 4 Nebby - 4 - 0 Pars - 0 - 2 Samuel - 2 - 0 Shaman - 0 - 2 tcpoint - 0 - 2 Vortex - 0 - 10 EDIT: Got the last two out as well: spritzer - 4 - 0 ujamerstand - 4 - 0 Edited August 29, 2011 by Kerry
jezz Posted August 29, 2011 Report Posted August 29, 2011 They came today and look great! Thanks Kerry and Kevin Gilmore!
n3rdling Posted August 30, 2011 Report Posted August 30, 2011 Mine came today as well, the boards are quite thick Thanks KGs!
nattonrice Posted August 30, 2011 Report Posted August 30, 2011 Thanks Kerry for hand delivering the boards! They turned out really smick =)
manaox2 Posted August 31, 2011 Report Posted August 31, 2011 I received my boards, Thanks Kerry and Kevin!
Pars Posted August 31, 2011 Report Posted August 31, 2011 Was there a BOM posted? I looked thru the thread, but may have missed it.
jgazal Posted August 31, 2011 Report Posted August 31, 2011 (edited) Was there a BOM posted? I looked thru the thread, but may have missed it. Link to the BOM: here It's hard to find all the resistor values from the same manufacturer. I also couldn't find 2 values in the appropriate package or in small quantities. Manufacturers are mixed and matched right now, but all of them are ±100ppm/°C, 1% 1W thick film resistors. Also need the value for the compensation caps. If anyone wants to edit or have it in a excel file let me know. I used the IRC thin film with .1% tolerance. Here's the actual values and part numbers. RP7 15 PFC-W1206R-03-15R0-B RP6 619 PFC-W1206LF-03-6190-B RP5 4530 PFC-W1206LF-03-4531-B RP4 15800 PFC-W1206LF-03-1582-B RP3 41200 PFC-W1206LF-03-4222-B RP2 93100 PFC-W1206LF-03-9312-B RP1 196000 PFC-W1206LF-03-2003-B RP0 402000 PFC-W1206LF-03-4023-B RS0 1330 PFC-W1206LF-03-1331-B RS1 2610 PFC-W1206LF-03-2611-B RS2 4910 PFC-W1206LF-03-4991-B RS3 8870 PFC-W1206LF-03-8661-B RS4 14300 PFC-W1206LF-03-1372-B RS5 20000 PFC-W1206LF-03-2002-B RS6 23200 PFC-W1206LF-03-2322-B RS7 23700 PFC-W1206LF-03-2372-B RT 24300 PFC-W1206LF-03-2432-B edited according ujamerstand Edited August 31, 2011 by jgazal
ujamerstand Posted August 31, 2011 Report Posted August 31, 2011 That one is a little outdated. There are newer resistor values a couple pages back. (24.3k impedance vs. 10k in the older BOM, I think?)
Kerry Posted September 1, 2011 Report Posted September 1, 2011 (edited) Here's the actual BOM I used to order: Quantity Ref Def Item Description Mouser Digikey 2 PCF8574AN 595-PCF8574AN 296-13106-5-ND 2 ULN2803AN 595-ULN2803AN 296-19046-5-ND 8 G6SK-2F-DC12 653-G6SK-2F-DC12 Z2666-ND 1 ID 1x3 Pin Header - .1" 571-5-146276-3 1 Mini Jumper 151-8010-E 2 Terminal block 651-1935190 2 PCF8574AN DIP-16 Socket 4816-3004-CP Resistors 2 3.3K Resistor Pack 71-CSC09A01-3.3K 2 Pullup 3.3K Pullup Resistors CRCW12063K30FKEA Input Z = 24K Qty, Ref, Value, Part # 2 RP7 15 PFC-W1206R-03-15R0-B 2 RP6 619 PFC-W1206LF-03-6190-B 2 RP5 4530 PFC-W1206LF-03-4531-B 2 RP4 15800 PFC-W1206LF-03-1582-B 2 RP3 41200 PFC-W1206LF-03-4222-B 2 RP2 93100 PFC-W1206LF-03-9312-B 2 RP1 196000 PFC-W1206LF-03-2003-B 2 RP0 402000 PFC-W1206LF-03-4023-B 2 RS0 1330 PFC-W1206LF-03-1331-B 2 RS1 2610 PFC-W1206LF-03-2611-B 2 RS2 4910 PFC-W1206LF-03-4991-B 2 RS3 8870 PFC-W1206LF-03-8661-B 2 RS4 14300 PFC-W1206LF-03-1372-B 2 RS5 20000 PFC-W1206LF-03-2002-B 2 RS6 23200 PFC-W1206LF-03-2322-B 2 RS7 23700 PFC-W1206LF-03-2372-B 2 RT 24300 PFC-W1206LF-03-2432-B Capacitors 2 100uF 661-EKZE250ELL101MH0 EDIT: The three pin header was a bit tall and I had to trim it down. Edited September 1, 2011 by Kerry
