I'm about to give my M^3 a major overhaul - new enclosure, sigma 11 to replace the current tread power supply, and a possible cap upgrade.
I've never found myself using the bass control much and am considering removing it. It's removal would seem to remove 1 pot and a few caps from the signal path, which might be a good thing to do, especially if you don't see the need for constant bass adjustment.
I'm building a M3 and the first thing I did was to install the jumpers to bypass the bb circuit. Variable gain may be a good idea but you can always put in a switch to do that. Hell wire up a 24V relay directly on top of the board for a short signal path. :)
I'm running one with variable gain, but after setting it at a nice level for my cans I never used it again, it's a nice feature for people with different cans!
Whoa, first a Cmoy, now an M3. Moving up in the world, spritzer! :)
Register a new account
Sign in
