The Monkey Posted November 14, 2010 Report Posted November 14, 2010 So it looks like the old B&W speakers are ok, which leaves pretty much only the amp as the culprit. Specifically, it seems like one channel is problematic. The sound it puts out sounds very very muffled, distorted, and scratchy. I opened up the amp and didn't see anything that to my untrained eye appears to be obviously kablooey. However, I did note that one of the fuses on the board looks different than the others. It's not blown but could that be it? Anyone see anything else? Quote
Yikes Posted November 14, 2010 Report Posted November 14, 2010 A fuse being blown can sometimes cause your described symptoms, but having a different fuse in one location (That's not blown) would not. Did you check the fuses with a meter, or did you eye-ball them? Sometimes a fuse looks good when it's not. Quote
The Monkey Posted November 14, 2010 Author Report Posted November 14, 2010 No meter here, so I just eyeballed them. I'll try to replace the fuses as a first step. Quote
Yikes Posted November 14, 2010 Report Posted November 14, 2010 Have you isolated it down to one channel? Quote
spritzer Posted November 14, 2010 Report Posted November 14, 2010 Is there an output relay? I can't see it but a bad connection there would account for the issues you are describing. Quote
Pars Posted November 14, 2010 Report Posted November 14, 2010 (edited) The far right fuse looks a little different, but doesn't really mean anything. Saw one thread on diyaudio regarding these, something about loose RCA grounds: Seeking help- something caused HUGE noise - diyAudio Do you have a meter, but just not there? At a minimum I would check the DC offset on both inputs if you have access to a DMM. And I have gotten schematics for free from Adcom just by asking them via email (if it comes to that). EDIT: A bit of info in this thread as well (see post 34) http://www.diyaudio.com/forums/solid-state/56735-adcom-gfa535-bad-transformer-3.html And follow Doug's advice Edited November 14, 2010 by Pars Quote
dsavitsk Posted November 14, 2010 Report Posted November 14, 2010 No meter here, so I just eyeballed them. I'll try to replace the fuses as a first step. Just swap them from channel to channel, if the problem moves, you've found the issue. Quote
The Monkey Posted November 14, 2010 Author Report Posted November 14, 2010 I replaced the fuses on the suspect side. Problem persisted. I then replaced the single fuse that's at the bottom of the picture. Success! Then the problem returned. Replaced that fuse again. No joy. Problem back where I started. Does this seem like a grounding issue? This is starting to annoy me. EDIT: also blew out some dust with some compressed air. Quote
Salt Peanuts Posted November 14, 2010 Report Posted November 14, 2010 What does a sound spider look like? Quote
The Monkey Posted November 14, 2010 Author Report Posted November 14, 2010 I don't know, but based on its droppings, I don't want to find out. Quote
luvdunhill Posted November 15, 2010 Report Posted November 15, 2010 but once you catch one, and defeat it in a game of chess, and then a game of spider wrestling, you can force it into the amp, which will then start working again! I'd choose a slightly more intractable game, just in case... Quote
