I got an HRT Music Streamer II for my parents Mac Mini. Just needed a cheap DAC and wanted one that didn't need a power supply. In theory, this DAC fits the bill. In practice, that's not the case. For anyone out there considering the HRT, be forewarned that you very likely will need to run it off a powered USB hub. It appears to simply draw to much power to run reliabily out of a 'puter's USB ports.
There are a bunch of posts about this on the internets, but I figured I'd give a heads up here, too.
If you have an additional usb port to spare, you can try using a two pronged usb cable to supply additional power. Something like this:
Amazon.com: Cables to Go 28108 USB 2.0 B Male to 2 USB A Male Y-Cable (Black): Electronics
edit: Oops, just realized you already bought a usb hub to solve the problem. Guess it's good to keep the Y cable in mind in case you ever need it :)
Would that work? Isn't it more than likely running off the same power supply?
Perhaps there has been a bad batch of them around? I've had mine for 3 months and no issues thus far.
Wish there were more similar simple dacs around, just usb in and rca out. Maybe Justin will release an update to the pico dac with an async 24/96 dac he is using for the Gilmore X2.
