deepak Posted August 15, 2008 Author Report Posted August 15, 2008 i do Applied with dummy-case1, dummy-case2, dummy-case3.
JBLoudG20 Posted August 15, 2008 Report Posted August 15, 2008 dummy_deepak applied to deepak and grawk charts
lostonetr Posted August 16, 2008 Report Posted August 16, 2008 If you poison my charts with that x japan crap I'm banning you from head-case whoaz. I only clicked add to library outa curiosity. Didn't scrobble anything. But just in case...let me go take that off of the library <3. --update. er... I can't remove it from the library T_T. I guarentee it'll have 0 plays, but hm.. I'll probably make a diff dummy account..and put him in. I have three dummy accounts. Reply or PM if you want me to join your groups. I do too. http://www.last.fm/group/00143
Hopstretch Posted April 4, 2009 Report Posted April 4, 2009 Just started using lastfm. Am tomorrow person me!
deepak Posted April 4, 2009 Author Report Posted April 4, 2009 Just started using lastfm. Am tomorrow person me! Added to group
VPI Posted May 22, 2009 Report Posted May 22, 2009 I was wondering where everyone got those cover art banners in their signatures as I had no idea what Last.FM actually did. Now that I have signed up with my Squeezebox Duet I applied to the Head-Case group.
NoValidTitle Posted May 25, 2009 Report Posted May 25, 2009 I just applied to the group, I'll have to check out those weekly charts. I've been using Last.fm for a while but wasn't aware of the charts. I have to start logging in foobar and on my H140.
NoValidTitle Posted May 25, 2009 Report Posted May 25, 2009 Damn 15 minute edit rule, I hate double posting. I made a group for charts, if you guys with dummy accounts could join NVT_charts it would be greatly appreciated. Thanks
Torpedo Posted May 25, 2009 Report Posted May 25, 2009 I just joined, but since I'm using Foobar in the computer, I don't think this works.
NoValidTitle Posted May 25, 2009 Report Posted May 25, 2009 I just joined, but since I'm using Foobar in the computer, I don't think this works. I believe there is a foobar plugin that adds last.fm support. I will be looking into this some more tonight as I use foobar also, at work at the moment.
Torpedo Posted May 25, 2009 Report Posted May 25, 2009 Oh thanks, I'll look for it myself and post results if I find anything
Torpedo Posted May 25, 2009 Report Posted May 25, 2009 (edited) Got it. The plugin can be found here You need Foobar2000 0.9.6.2 or higher installed. Once installed you need to go to preferences>Tools>Audioscrobbler to type your Lastfm username and password to get Foobar sending the statistics. I'm now using it, but I don't know if it's sending anything up there. The good part is that you can disable it very easily by just removing a tick. EDIT: I've checked it and it's working flawlessly, now Lastfm knows I'm listening to Melody Gardot Edited May 25, 2009 by Torpedo Adding more info
NoValidTitle Posted May 26, 2009 Report Posted May 26, 2009 Got it. The plugin can be found here You need Foobar2000 0.9.6.2 or higher installed. Once installed you need to go to preferences>Tools>Audioscrobbler to type your Lastfm username and password to get Foobar sending the statistics. I'm now using it, but I don't know if it's sending anything up there. The good part is that you can disable it very easily by just removing a tick. EDIT: I've checked it and it's working flawlessly, now Lastfm knows I'm listening to Melody Gardot Sweet, that worked perfect. Thanks. Did they lower the requirement for group charts? The group I made for my own charts says they are calculated for groups with more than 2 people.
zippy2001 Posted August 24, 2009 Report Posted August 24, 2009 Hi, I joined last.fm can i join the fun. thanks
n_maher Posted August 24, 2009 Report Posted August 24, 2009 Hi, I joined last.fm can i join the fun. thanks Of course you can, join the group!
