4-pin XLR to banana break out
large, high voltage, grabber probes
two, 3-pin XLR to banana (or spade) cables. These might need a bit of work, as I believe one of the connections was cutting out, so selling as is. Very nice cables though
4-pin XLR to TRS
surgeon silk thread, for turntable belts. Available by the foot.
a pair of LED arrays used for prototyping (ended up going with a different config)
prototyping board, sealed (for info look up part number)
Sony ECR-400: From Spritzer, but I lost the other $%$@ baffle, so available for parts / experimentation. These would really make the best SFI donor phone ever.
PDIP receiver
Koss ESP-950 extension cable
LSK389 SOIC-8 to Toshiba 7-zip package adapters
Apple-esque Flash drive
Rub on, "audio" decals, 3 packs in black and 3 packs in white
Last Update. This is it folks.
(5) Fairchild FQPF2N60C (TO-220F)
(2) ON TIP50G (TO-220)
(4) OPA2277PA (8-PDIP)
(5) OPA445AU (8-SOIC)
(3) OPA2227PA (8-PDIP)
(2) TLE2426IP (8-PDIP)
(2) IRFBC30 (TO-220)
(1) TL783C (TO-220)
(5) OPA227P (8-PDIP)
(3) OPA228PA (8-PDIP)
(2) TL081CP (8-PDIP)
(1) OPA2227P (8-PDIP)
(1) LT1206CN8 (8-PDIP)
(4) OPA2312P (8-PDIP)
(1) OPA2604PA (8-PDIP)
(1) OPA627BP (8-PDIP)
(2) OPA637BP (8-PDIP)
(2) OPA602AP (8-PDIP)
(6) OPA134PA (8-PDIP)
(5) OPA2107AU (8-SOIC)
(5) OPA134AU (8-SOIC)
(2) AD845KN (8-PDIP)
(2) AD8620 (8-SOIC)
(4) OPA2107AU (8-SOIC)
(175) BC550C (TO-92)
(75) BC560C (TO-92)
(17) IRF510 (TO-220)
( 8 ) 2SC2344 measured hfe (TO-220)
( 8 ) 2SA1011 measured hfe (TO-220)
(14) DSSK60-0045B (TO-247)
(22) 2SA968 (TO-220)
(60) 2SA1831 (TO-220)
(18 ) IRF9510 (TO-220)
(14) IXCP10M45S (TO-220)
x3
It's difficult to resist the temptation :(
tell me about it, I just couldnt help myself over at DIYA and its ongoing. Nate, you suck, I wanted those neutricons badly :(
update, here's what is left at this point
(1) turntable pulley (pic)
(1) twisted pear audio Ballsie (pic)
(1) pair matched 6.8uF/50V Wima caps (pic)
(1) Serpac H-67 AC project case (pic)
(2) Jantzen 12.00mH 14AWG inductors (pic)
(2) power supply PCBs (pic)
(1) 24VAC AC wall wart (pic)
(3) TO-3 mica kits (pic)
(24) BER200 heat pads (pic)
(3) TO-247 insulators (pic)
(1) Weller soldering iron tip cleaner (pic)
(2) measurement weights (pic)
(1) Pass Pearl kit (pic)
(16) TDA1543A
(1) Bondhus 1.27mm hex wrench, for Rega (pic)
(8) CMC ceramic octal sockets (pic)
(-) decent gauge uninsulated solid silver wire (pic)
(2) Li-ion 3.7V, 700mAh batteries (pic)
(3) microphone preamp boards, with parts (pic)
(2) G8P-1A2T-F Omron 12VDC relay (pic)
(-) lot of spade connectors (pic)
(-) surgical silk thread for turntable belts (pic)
(2) 5x7 LED arrays (pic)
(-) LSK389 SOIC-8 to 2SK389 7-ZIP adapters
(2) AD8620 (8-SOIC)
(75) BC560C (TO-92)
Chris, do you want to try the tweeters? Some :asshat: tried to do a chargeback on me after he thought I shipped the items via a non-trackable shipping method. Fortunately, I didn't ship them.
Wow that's douchy. Who was it?
Ooops, sorry didn't see this. I'll have to think about it. I have replaced a tweeter when I blew one playing around with a DEQ2496 :palm:, but they are a major pain in the ass to get to. I'll take a look at the dimensions, etc. and see if I want to mess with it or not. Bolt or screw pattern is different as well.
