grawk Posted November 29, 2022 Report Posted November 29, 2022 the brush if I start noticing retention. Not very often. 1
HemiSam Posted November 29, 2022 Report Posted November 29, 2022 On the Niche for espresso machine shots I'm between 9 and 11 depending on the bean and the age of the coffee. I don't clean my Niche that often. When I do, I simply disassemble to get the burr related parts out and use the provided brush. HS
EdipisReks1 Posted November 30, 2022 Report Posted November 30, 2022 I clean grinders the same as Dan. The Hoffman giveaway item I received was the refractometer! It’s not the best one in the world, but I’m sure it’ll be fun.
grawk Posted November 30, 2022 Report Posted November 30, 2022 One thing to know about the niche: the numbers are only really useful as an internal reference, because they're entirely dependent on how you calibrated it.
EdipisReks1 Posted November 30, 2022 Report Posted November 30, 2022 And the corollary being that we can all calibrate the same way. I go slightly to the right of the indicator, myself.
HemiSam Posted November 30, 2022 Report Posted November 30, 2022 One thing I started doing after the espresso machine acquisition is placing a couple of small pieces of masking tape between the rotating rings/parts so I could see if they were drifting (require recalibration) given I use the Niche for pour over in the morning and for espresso after lunch. YMMV... HS 1
Augsburger Posted December 1, 2022 Report Posted December 1, 2022 Ok, now that I reduced the grind to 12, the puck crumbles upon whacking the knock box. (Behave here Steve) Prior to changing the grind the puck would pop out as a solid piece. Is that bad or nothing?
grawk Posted December 1, 2022 Report Posted December 1, 2022 if you have a bottomless portafilter, does the stream consolidate into a single stream or is it a shower or multiple streams? It's probably crumbling because you're getting better extraction. Watch the pour, and stop it a little after you get blonding, and you should have a good shot. Experiment with that and find out where your sweet spot is for flavor. 2
HemiSam Posted December 1, 2022 Report Posted December 1, 2022 One of my smarter purchases in support of the espresso maker is a small mirror that is magnetic and rotates. I place it on the espresso maker next to my scale so I have a clear view of the portafileter screen so I can see the stream coming together, etc... Money well spent IMHO. I found it on Etsy and I'm happy to provide a link if anyone is looking for one. HS
Augsburger Posted December 1, 2022 Report Posted December 1, 2022 1 hour ago, grawk said: if you have a bottomless portafilter, does the stream consolidate into a single stream or is it a shower or multiple streams? All of the above. I need to try a few more pulls and watch closer with my mirror to assess my progress.
velomane Posted December 2, 2022 Report Posted December 2, 2022 2 hours ago, HemiSam said: I found it on Etsy and I'm happy to provide a link if anyone is looking for one. HS Yes please. I tired of crouching to watch the pour.
HemiSam Posted December 2, 2022 Report Posted December 2, 2022 6 minutes ago, velomane said: Yes please. I tired of crouching to watch the pour. This is the one I purchased, but it appears they are out of stock. https://www.etsy.com/listing/1103111404/shot-nanny-elegant-bottomless?show_sold_out_detail=1&ref=nla_listing_details I saw this one in the feed that looks like it could be the same. https://www.etsy.com/listing/1205499848/espresso-shot-coffee-mirror-50mm-2?click_key=3ea59f7c4e3dca25744ec94a5a9c03a6578bc067%3A1205499848&click_sum=eff1b793&ref=sold_out-6 HS 1
EdipisReks1 Posted December 11, 2022 Report Posted December 11, 2022 I have a Normcore mirror and a Weber looking glass. The Weber is nice, but not worth the money over the Normcore. The Normcore has a magnetic base. I keep it on the edge of the drip tray.
mikeymad Posted December 11, 2022 Report Posted December 11, 2022 How often are y'all struggling with channeling? I have not invested in a new portafilter yet, so I can only judge by flow rate change, taste and puck inspection.
EdipisReks1 Posted December 12, 2022 Report Posted December 12, 2022 (edited) Not too terribly often; are you WDTing? I WDT or use a blind shaker; they both do a great job of distribution, which is the number one element for reducing channeling. Edited December 12, 2022 by EdipisReks1
mikeymad Posted December 12, 2022 Report Posted December 12, 2022 Nope - using the Oracle grinder built in setup with it's spiral press. It does a really good job most of the time. I have found that if I have an issue it is the grind setting (well it is the only setting that I have). I was just curious with most people using an open portafilter, if there were issues that people were trying to resolve. Q - with the duel boiler - do you have a preference for your pre-infusion pressure? I have been using 65 (I assume %). I think that the duel is the same setup.
EdipisReks1 Posted December 12, 2022 Report Posted December 12, 2022 (edited) The Oracle and the Dual Boiler have the same basic mechanism, so yeah, it works the same way. I don’t think my having the OPV set much lower than factory affects the preinfusion, but my having a different solenoid very well may: I’m running at 80, which on my machine gives me a solid 1/2 bar preinfusion. My understanding is that it’s percentage of pump pressure, yeah. Edited December 12, 2022 by EdipisReks1 1
HemiSam Posted December 12, 2022 Report Posted December 12, 2022 I don't have channeling issues very often. I do have to play with the grind setting as I purchase new coffee, or adjust a smidge as the beans age but these are very minor tweaks to grind setting (well less than one tick on the Niche). I pre-infuse with the Lelit Bianca at 2 bar for roughly four seconds and then swing the paddle for higher pressure until the gauge hits 9 bar. Seems to work pretty well. One thing I have concluded is I can torture myself with a less roasted bean trying to hit the sweet spot for espresso or I can purchase a bean clearly roasted for espresso (plenty dark) and make my life much easier hitting my marks. Much darker notes on the heavily roasted beans so it's a taste thing. HS 2
Grahame Posted December 12, 2022 Report Posted December 12, 2022 Meanwhile ... https://www.seattletimes.com/business/technology/seattle-startups-bring-robots-to-coffee-pizza-prep/ 1
HemiSam Posted December 12, 2022 Report Posted December 12, 2022 1 hour ago, Grahame said: Meanwhile ... https://www.seattletimes.com/business/technology/seattle-startups-bring-robots-to-coffee-pizza-prep/ After watching the latte art, I hate this guy already...LOL. HS 1
EdipisReks1 Posted December 13, 2022 Report Posted December 13, 2022 Latte art is sure hard if you aren’t making 100 lattes a day and/or are not a robot. 1
mikeymad Posted December 16, 2022 Report Posted December 16, 2022 After two pounds of coffee, I am starting to get the hang of the Oracle. The new portafilter helps with being about to see the flow and distribution. I am on my third new coffee now. And I am able to get it dialed in with about three shots. I seem to work best starting with too much flow {a bit sour} and then work towards making it stronger and more extracted. My palate can detect that easier than starting on the bitter side. I wanted a bit more coffee in my latte, So I have increased my dose up to 22 in and 45 out, right at 35 second. I will probably decrease my milk volume a bit to give me a little more coffee ratio. Still a few things I may change, the burr set is a little worn {rough cutting edge}, and they are relatively cheap to replace. It was a used machine. But overall I am becoming more happy with it as I use it more. Surprise, good coffee makes me happy. cheers 3
EdipisReks1 Posted December 17, 2022 Report Posted December 17, 2022 Nice! It feels really good when you get things dialed in. Plus, as you say: good coffee makes you happy. 1
EdipisReks1 Posted December 20, 2022 Report Posted December 20, 2022 If anybody wants one of Twitter’s Lineas, here is your chance: https://www.gearpatrol.com/home/a42283958/twitter-furniture-auction/
Aura Posted December 29, 2022 Report Posted December 29, 2022 Unfortunate situation for a local roaster (to me) turns into a rather good deal if you are interested. I grabbed a case. https://www.modest.coffee/2022/12/how-we-got-grifted/ 2
