August 5, 201016 yr comment_377448 Hi everyone I want to create a new bedroom rig to replace my old sony minitower. I will be using the next gen ipod nano that will arrive in september as the heart of the rig and then probbably the onkyo ipod transport, i can connect a dac to that via spdiff or coax but I am not sure which one yet. I want one with xlr output and either spdiff or coax input. I want to spend 400 euro max. I was thinking about the dacmagic but the little dot dac_i uses the seem dac chip and has xlr out although the rest of the chips or implementation might be different. It is a lot cheaper though. I was also thinking about the buffalo II with placid power supply and the line stage legatto and maybe another placid power supply but I would need a builder for that so it might be more expensive The first two dacs use a wolfson chip and the buffaly uses a sabre chip. Any help would be appreciated. Thanks in advance, Greetings, Anouk, Report
August 5, 201016 yr comment_377475 There's a Welcome PM? I guess I predate such niceties. Yes, I think you do Report
August 6, 201016 yr comment_377673 There's a Welcome PM? I guess I predate such niceties. You were grandfathered in because you are cool and because you wouldn't make the mistake the op is currently making, and because you are cool. Report
