justin Posted August 3, 2010 Report Posted August 3, 2010 (edited) ^ the big round one 30mm diameter x 36mm length with M8 thread I'm going to be ordering these but there is a huge min quantity. Maybe there is interest in a group buy? Likely, $1/piece is enough to cover the cost + share of shipping charges from China, and also some hex nuts. If there is interest the minimum would probably be about 16 pieces or shipping would get too crazy for just a couple. Edited August 3, 2010 by justin
luvdunhill Posted August 3, 2010 Report Posted August 3, 2010 yeah those are pretty cool. I've seen then in some of the street stalls.
kevin gilmore Posted August 3, 2010 Report Posted August 3, 2010 i'm going to verify that the hole size on the T2 will take an M8 but this is definitely what you want for the T2's
n_maher Posted August 3, 2010 Report Posted August 3, 2010 If/Once Kevin confirms that they are appropriate for T2 use feel free to put me down for the min. qty (16?).
kevin gilmore Posted August 3, 2010 Report Posted August 3, 2010 (edited) Well the chassis are drilled for a #10 Which is .1900. So a M8 definitely will not fit (roughly .250). Should be easy to drill out the holes. And for the front two feet on the power supply only, you have to cut the shaft to the size of the nut otherwise it would hit the circuit board. Edited August 3, 2010 by kevin gilmore
struts Posted August 4, 2010 Report Posted August 4, 2010 If there is interest the minimum would probably be about 16 pieces or shipping would get too crazy for just a couple. I'm in for 16 Justin.
nattonrice Posted August 4, 2010 Report Posted August 4, 2010 I'm in for 16 as well. T2 can only look more swish with em.
nattonrice Posted August 4, 2010 Report Posted August 4, 2010 Fuck me that's a lot of feet I guess you can retrofit all your KG** stuff with them.
spritzer Posted August 4, 2010 Report Posted August 4, 2010 Can't be outdone by Kevin so 100 for me as well.
luvdunhill Posted August 4, 2010 Report Posted August 4, 2010 In for 16. damn, got to keep up with the Toole's. I'm in for 16 too.
nattonrice Posted August 5, 2010 Report Posted August 5, 2010 Actually I just found another use for them so correcting my previous: I'm in for 32
Augsburger Posted August 5, 2010 Report Posted August 5, 2010 I have no immediate use for them since the M8 thread is too big but I can't resist a group buy. I'm in for 16 please, I can always install them under the granite plates I have stored in my bedroom waiting for the next great idea.
justin Posted August 5, 2010 Author Report Posted August 5, 2010 just got the shipping weight & package dimensions. it looks like shipping (to me) is going to cost more than the cost of the feet so $1.50ea once they get to me is probably more like what it will cost.
justin Posted August 5, 2010 Author Report Posted August 5, 2010 have it shipped REALLY SLOW boat. maybe if i could get them thrown in someone else's container, that would work but i doubt they'll go for it
kevin gilmore Posted August 5, 2010 Report Posted August 5, 2010 i was thinking REALLY SLOW BOAT. As in one guy in a rowboat. what do 1000 of those weigh... about 300 lbs??
