2010 RMAF/CJ@RMAF
Asr
  • Replies 324
So you can listen to your stereo records and then listen to your mono records, or listen to your records with one cartridge and then another, and so on. Smartass.
Ah, that makes sense. I was really wondering if someone had figured out a weird way of, I dunno, double sampling the record with the needle aligned differently or something.
that's for quadraphonic records Colin, obviously!
I would actually have believed you, had you said this before Al's post. Still might, who would want to listen with more than one cart, or to mono?
Delay and flip the polarity and you can have true balanced.
Dibs on the patent!
Thought you already could have true balanced, since the coil is floating?
Dinner at the Cherry Cricket:
Looks like a good time, but who is that sitting across from Possessed Justin, with the pitcher?
Hey, don't go ruining my chances at my fortune with your silly logic. How about balanced-upon-balanced? You set up each needle as single-ended rather than balanced. And technically, you still lose any benefit of common mode rejection (with the dual needles), so it's an inferior balanced, not a moar troo balanced.
And that's not possessed Justin, that's Justin-with-lasers. I want what he's having.
