insanity Posted April 29, 2015 Report Posted April 29, 2015 Nice experimental looking build. How does it sound? Quote
headinclouds Posted April 29, 2015 Report Posted April 29, 2015 Excellent stuff Joachim, Keep up the pioneering work. Quote
kevin gilmore Posted April 29, 2015 Author Report Posted April 29, 2015 (edited) http://gilmore.chem.northwestern.edu/kgsshvcarbonright1.jpg ground plane on both sides, surface mount components on both sides. Edited April 29, 2015 by kevin gilmore Quote
nopants Posted April 29, 2015 Report Posted April 29, 2015 damn that thing looks pretty intimidating Quote
gepardcv Posted April 29, 2015 Report Posted April 29, 2015 (edited) Apologies since I obviously missed this earlier: what is the advantage of the Carbon relative to the original ("classic"?) KGSSHV? Edited April 29, 2015 by gepardcv Quote
nopants Posted April 30, 2015 Report Posted April 30, 2015 it's a KGST with silicon carbide output devices in place of the triode 1 Quote
GrindingThud Posted April 30, 2015 Report Posted April 30, 2015 Ooo, that's small enough it makes me want one. Nice layout. http://gilmore.chem.northwestern.edu/kgsshvcarbonright1.jpg ground plane on both sides, surface mount components on both sides. Quote
Laowei Posted April 30, 2015 Report Posted April 30, 2015 http://gilmore.chem.northwestern.edu/kgsshvcarbonright1.jpg ground plane on both sides, surface mount components on both sides. Amazing work as always Kevin. Quote
kevin gilmore Posted April 30, 2015 Author Report Posted April 30, 2015 joamat is doing the layout on this. all of the stax brain trust use the same software which makes things easier. Quote
Laowei Posted April 30, 2015 Report Posted April 30, 2015 Will the gerber files be made public? Quote
kevin gilmore Posted April 30, 2015 Author Report Posted April 30, 2015 of course, thats the point, i'm working on adding connector blocks now. joamat did 2 boards, left side and right side, similar to the t2, that way everything is symmetrical. but it also means that there are twice as many boards. Quote
Laowei Posted April 30, 2015 Report Posted April 30, 2015 Great! I am looking forward to one day getting a pair made. Please take your time, I did not intend to pressure you. I appreciate all that you have already given so much to us DIYers as a gift.. And thank you too for getting me involved with Stax. Quote
kevin gilmore Posted April 30, 2015 Author Report Posted April 30, 2015 (edited) someone really needs to check this hard. http://gilmore.chem.northwestern.edu/kgsshvcarbonright1.pdf changed to multipage to make it easier. Edited April 30, 2015 by kevin gilmore Quote
JimL Posted April 30, 2015 Report Posted April 30, 2015 it's a KGST with silicon carbide output devices in place of the triode Actually, it looks like a KGST with a solid-state equivalent of the BH output stage (grounded grid/gate) and cascode current sources, if I'm not mistaken. 1 Quote
kevin gilmore Posted April 30, 2015 Author Report Posted April 30, 2015 yep, grounded grid. There is much more gain in the output stage, so all the extra parts in the BH are not needed. So the amp is faster because of less parts in the signal path. 3 stages instead of 5. board is 6.3 x 2.75 so it fits on a 3 inch high heatsink. (do I want to do 1500 lbs of aluminum again... highly unlikely) Quote
nopants Posted April 30, 2015 Report Posted April 30, 2015 There are only 4 devices that need to be sinked per board, Should be easy enough to do by hand Quote
Inu Posted April 30, 2015 Report Posted April 30, 2015 (edited) 2SC3324 is NPN. 2SA1312? Upside down... Pars number is correct. sorry.. Edited May 1, 2015 by Inu Quote
kevin gilmore Posted May 1, 2015 Author Report Posted May 1, 2015 this should give you all a headache... certainly gave me one. http://gilmore.chem.northwestern.edu/kgsshvcarbonstereo.pdf Quote
JimL Posted May 1, 2015 Report Posted May 1, 2015 With those colors, I bet if you stared at one side of the board for 30 seconds, then shifted down to the other side, you'd see the whole board layout at once. More seriously, one concern I have is that while the 10M90S/DN2540 makes for a very high impedance CCS (good) there is a fair amount of variability between DN2540 samples in the amount of current that is produced for a fixed source resistance (bad). That's why I put a trimpot in the source to adjust the current. This is unlike the 10M90s which is designed as a current source so is reasonably tightly controlled for current vs source resistor. Quote
JoaMat Posted May 1, 2015 Report Posted May 1, 2015 (edited) I believe JimL have an important point and a trimmer is needed and it will make the setup considerable easier. Edited November 11, 2015 by JoaMat Quote
JoaMat Posted May 1, 2015 Report Posted May 1, 2015 (edited) / Edited November 11, 2015 by JoaMat Quote
JimL Posted May 1, 2015 Report Posted May 1, 2015 First time I got 2 pieces of DN2540 from a local store. Same resistance gave same current with 0.1 deviation between them. Second time I bought 20 pieces of DN2540 from Mouser. From that population I found 17 or 18 individuals that gave a current of 10mA within +/- 0,2 mA with 150 ohms resistor. I don’t remember resistance for the first 2 DN2540 but it was different, not 150 ohms. If you randomly pick a group of 10m90s you will have a variation not less than what I found among the 17 or 18 DN2540. My guess is, if you get DN2540 which are produced at the same time (batch or whatever you call it) they are close but else there are deviations and you need to adjust resistance accordingly. I built a small test board with the actual current source and with an uTracer I tested the dn2540 relatively easy. I didn’t feel any needed for a trimmer and that’s why there are no trimmers on the board (at this moment). Either you were lucky or I was unlucky or both. I found 5-10% deviations in current with the same source resistor was fairly common, but I also ordered various DN2540 over a period of time. Also, I was trying to get within 1% of designed current so my OCD is probably showing. Quote
luvdunhill Posted May 1, 2015 Report Posted May 1, 2015 I have found very close matching of DN2540, as I have a project that uses a dozen or so of them. I did add trimmers though, but didn't really end up using them much. I am considering using the SMD with the TH part to try and reduce some board space and not sure if that will net the same consistency. Quote
gepardcv Posted May 3, 2015 Report Posted May 3, 2015 I just received a batch of KGSSHV mini stereo boards. Looking good. I've been thinking about the build, and it looks like my original plan to use a KGSSHV mini power supply with the stereo board in a Galaxy 388 chassis won't work, it's about 10mm too narrow, unfortunately. A larger chassis would certainly work, but the 388 fits really well on my desk. The question now becomes: do I have any alternatives for a smaller power supply board? The mini BH power supply is just the right size, but it's 350V, and I'd like 400V (though I'm also wondering if it would make significant audible difference if I tried running the KGSSHV mini stereo circuit at the lower voltage). I remember reading that the kgbhultraminipsv4 can be cranked to 400V — will I have heat issues? What are the drawbacks to using this power supply with the KGSSHV? Quote
