Thanks JoaMat. The LT1021 datasheet does refer to a two-terminal, shunt regulator mode as you stated.
I also looked up the older versions of KGSSHV PSU that also used the LT1021 and it was connected the same way (V in pin open).
AU is now officially 230V, so 250V is just about the top margin. I'm in Sydney as well, I checked my outlets this weekend and it was 235V.
No worries.
Should check your line voltage, mine here fluctuates around 240V - 250V here in Sydney.
The 230v spec could be a problem?
I'm getting closer to being able to fire up everything.  I only have SR5 gold with normal bias - so I either need to build with both normal and pro bias, or I need to buy a pro bias headphone. I don't really want to buy the pro headphone until I know the amp is not going to go up in smoke. Question - any reason I shouldn't test the amp with SR5 and normal bias? Double Bias or Ebay pro phone for testing?
I'll post PSU and Amp board pics shortly and would appreciate any "that doesn't look right" comments
Lucky you most places in Melbourne is still between 240 and 250v. The last two properties i had including my current house my mains is 245vac.
I have a minty SR5 gold coming in next week, really looking forward to it. On testing I have a 207 I use with a long burn in period. Probably unnecessary, but I'm more comfortable than using expensive and/or out of manufacture headphones.
You mean they just recently standardized this? Wow, that's unusual.
I received several 4686 I bought from UTSOURCE and with the DY294 and they test at 1180 or so. The thing is it measures the same even if the transistor is not being tested. What gives?
post-2299-0-47078600-1427650001_thumb.jp
post-2299-0-75101400-1427650017_thumb.jp
Edited by eggil
Mine does the same thing, except at around 1400V. I just assumed it's because the actual breakdown voltage is higher than the capability of the tester (higher with fresh batteries). It's a 1200V part so the real ones can definitely handle more than 1200V.
Edited by mypasswordis
Hi,
Where is everyone getting their transistors from?
Had a look on ebay , bdent and Chinese sellers. Are they worth buying from or do we
have to take Pot luck, buy them then test?.
Thanks
Les
Edited by iwik
I've never come across fake 2SC4686A's but I'm sure they will surface once supplies dry up.
I bought thousands of them from Japan and I've been selling them with the boards.
What I was really referring to were the 2sa970 /2sc2240 ect for the amp. Researched the Mpsw series and they seemed
to be hard to get also. Spotted the 2s series on ebay so wondered if they were worth taking a chance on them.
Les
Need help with testing/debugging the KGSSHVPSMINIFINALSTN9360 PSU board.
The PSU is set up to deliver around 400 VDC (450 V Zener string, R29/R26 = 432K, R6 = 22.1K, ditto on the - side) Transformer is a 200VA Antek with dual 350v/290mA secondaries. It's overkill I know but they do not have a 150VA option and I thought the 100VA one's current rating is a bit on the low side.
I wired one each 10ohm/ 2A inrush current limiter (Mouser part number 871-857153S100M54) on the L and N primaries and use a 3.15A slow blow fuse.
I tested the PSU first with 15V secondaries to make sure I did not make elementary mistakes like insert the rectifiers or capacitors out of phase and it tested fine. When I connected the PSU with the 350v/290mA secondaries it blew the 3.15A fuse on start up. I did not see or smell any spark nor smoke and did not see any visible damage to the PSU. The output voltage showed around -170 VDC momentarily before the fuse blew ( I decide to test the PSU one section at a time ).
My question; are my inrush current limiters under rated for this application? I did buy extras so would it help if I wire two in series on each primary? Or does this signify some more serious issues?
Thanks for any insight or suggestion you can offer.
Edited by mwl168
