nopants Posted April 23, 2016 Report Posted April 23, 2016 I think I read somewhere that lavry had some heating network in order to maintain consistent temperature across each of the DAC chips, but I don't know how feasible that'd be in a discrete setting What would you do about the math, FPGA? Quote
kevin gilmore Posted April 23, 2016 Author Report Posted April 23, 2016 (edited) finishing a project with a kintex-7 now so yeah whatever one has more than enough horsepower and compatible with the xilinx compiler. the totaldac uses 74hc574, so yeah not so good either. if someone with the fpga tools wants to do that part, fine by me. I definitely want a dsd to 192/24 thing inside. Edited April 23, 2016 by kevin gilmore Quote
spritzer Posted April 23, 2016 Report Posted April 23, 2016 The Lawry heater is just a resistor on top of the precision resistors. Quote
nopants Posted April 24, 2016 Report Posted April 24, 2016 ah that's way less cool...the spectral sdr2000 also has a fan loop between the analog and digital sections to maintain temperatures Quote
electrostatics Posted April 29, 2016 Report Posted April 29, 2016 I just finished my KGSSHV and love the sound! I'm not an electrical engineer so can anyone shed some light (or point me to some further reading) what the servo jumper is for? When do I need to use it? I'm powering my SR-007 MK1 with the KGSSHV. Quote
chiguy Posted April 29, 2016 Report Posted April 29, 2016 I haven't looked at KGSSHV boards but if it's anything like the other KG boards, it's used to enable/disable the servo. You turn off the amp and disable the servo (remove the jumper) when you're making trimpot adjustments to set the offset and balance. Once you are done, you turn off the amp and enable the servo (put the jumper in) again. Quote
spritzer Posted April 30, 2016 Report Posted April 30, 2016 It's just to enable or disable the servo. Even with the opamp not installed and all the other parts populated it will have an effect on the circuit with the jumper engaged. Quote
electrostatics Posted April 30, 2016 Report Posted April 30, 2016 Ah ok, so the servo circuit is usually enabled (but generally optional) after adjusting balance/offset close to 0V? The servo would then automatically take care of those values? Quote
llamallama Posted May 7, 2016 Report Posted May 7, 2016 Just a note for anyone using the BHSE video to adjust Offset and Balance, the video has it backwards. L+/L- is adjusting Balance (not Offset as the screen overlay says). And L+/Ground is Offset (not Balance). Quote
*high Posted May 8, 2016 Report Posted May 8, 2016 First of all, many thanks to Dr Kevin Gilmore and all contributors! I’m the lucky one to get KGSSHV… almost =) Well, here is the build, not my though. Long story short I bought the kit with all parts populated from someone I trust (and maybe he will help me, I’ll have to ship 30 pound unit a few thousand miles lol), PSU board was tested and amp boards weren’t. Then after dozen of refusals I finally found someone (highly qualified and reputable diyer) who agreed to do the casing and wiring, with no responsibility of how THAT may sound. Funny thing to say, I’m the first one to listen to this unit. And it DOES sound tremendously resolution-and-soundstage-wise, needless to say. Except one thing. It’s not just me crazy, two more experienced listeners heard the same spot on. Compared to 007t amp (as well as some other small diy amp) the bass is lacking big time. You can hear all the sub down to 20 Hz but dynamics and amplitude is missing. Barrel drums which are quiet on the recording are barely discernable (Shake off the Dust by Herlin Riley, to name just one) big drums sound much smaller and drier with more kinda mid-bass impact. No hint of that manner not in a single owner impression! The headphones are dyi, 3 models with different sensitivity and membrane thickness, no problem with them (they may hit hard like devil dare I say, close to HE-6 & beta22 rig). All parts populated are those recommended, though I can go into the details if needed. 20 hours warm-up. I’ll have it measured and will get the readings is two days… But what may be the problem? Voltage swing? Volume pot (rk27 btw, original)? Almost forgot to say, got the ground loop hum sound, pretty audible on sensitive headphone pair. The wiring is done strictly to that scheme https://docs.google.com/file/d/0B4NVeoQi85GgOTdvOGpxc1hyRFU/edit Quote
spritzer Posted May 8, 2016 Report Posted May 8, 2016 (edited) I bet the hum is coming from the transformer. That is literally the worst place possible to put it. As for the bass issue, what PCB is that hiding underneath the volume pot? Not a chance the RK27 is the culprit and I can't even think what could possibly do that to the circuit. Edit: Also the diodes in the power supply could go boom at any moment... They have to be insulated with this PCB layout. Edited May 8, 2016 by spritzer Quote
nopants Posted May 8, 2016 Report Posted May 8, 2016 aren't those exposed-tab diodes a bit close to other? Quote
*high Posted May 8, 2016 Report Posted May 8, 2016 The hum disappears when I ground the case or rca banana, i.e. touch it. The hum increases when I touch the headphone cable. PCB underneath the volume pot is rca unbalanced to balanced converter. My dac is has rca outputs only, unfortunately. Quote
spritzer Posted May 8, 2016 Report Posted May 8, 2016 Ehhh why are you using a RCA to balanced converter? Bypass that crap and just ground the - input of the amp. Grounding is simple, they all go to the PSU including the chassis. Quote
*high Posted May 8, 2016 Report Posted May 8, 2016 On 5/8/2016 at 11:33 PM, spritzer said: Ehhh why are you using a RCA to balanced converter? Bypass that crap and just ground the - input of the amp. Grounding is simple, they all go to the PSU including the chassis. Expand isn't it correct grounding? so there are I+ I- inputs of the amp and gnd On 5/8/2016 at 11:19 PM, spritzer said: Edit: Also the diodes in the power supply could go boom at any moment... They have to be insulated with this PCB layout. Expand thanks for your help could you pls name the parts which should be insulated? upd I guess I see them poor little diodes, jammed lucky me 20 hours 'n no blow up? I keep on digging... all parts are the same as marked on the psu board 1.0 http://imgur.com/9wennYm - may have a look Quote
*high Posted May 9, 2016 Report Posted May 9, 2016 On 5/8/2016 at 11:33 PM, spritzer said: Ehhh why are you using a RCA to balanced converter? Bypass that crap and just ground the - input of the amp. Grounding is simple, they all go to the PSU including the chassis. Expand Well, my universe is upside down now and I'm in Borat mode so to say So, no balanced, I remove that thing. Still using quad volume pot? A bit unsure how to +, - and gnd all that stuff. Quote
congo5 Posted May 9, 2016 Report Posted May 9, 2016 (edited) On 5/8/2016 at 11:58 PM, *high said: could you pls name the parts which should be insulated? upd I guess I see them poor little diodes, jammed Expand No .......... the 8 large ones, high voltage, in groups of four with shiny metal on top in the front middle of your power supply. that tab is HOT... look at these: STTH512FP On 5/9/2016 at 1:34 AM, *high said: Still using quad volume pot? A bit unsure how to +, - and gnd all that stuff. Expand Use half your volume pot, tie the minus inputs to ground at connectors on amp boards and drive the plus from volume pot, twisted pair or shelded cable from each section of pot to each board....easy! Edited May 9, 2016 by congo5 1 Quote
chinsettawong Posted May 9, 2016 Report Posted May 9, 2016 Nice looking DIY headphones. Can you share more details on them? By the way, my KGSSHV sounds very nice with all my DIY headphones. Wachara C. Quote
spritzer Posted May 9, 2016 Report Posted May 9, 2016 When using RCA's you only use two of the four decks on the pot. The output of those is taken to the + input of the respective channel while the - input of the each channel is connected directly to the ground tab next to it. Those diodes have to go and the board is clearly marked for the insulated units. The person who built this board doesn't have a clue what they are doing as the tabs of the transistors is indeed live. Wrong heatsinks for the bias supply and I guess the other current sources as well. Inadequate isolation as well since the tab of these sits at a very high voltage. 1 Quote
Skooby Posted May 10, 2016 Report Posted May 10, 2016 I'm one of the guilty ones who didn't use isolated diodes; used a non-blessed BOM which specified non-isolated diodes. Blew a lot of fuses before realizing the problem. Seeing the outlet wires go directly to on/off switch, no fuse on the 120V main line? Should put one on in case of shorting (like non-isolated diodes). Also, two-prong outlet plug? Where's the ground/third prong or how do you ground the whole amp? Is there a chassis ground? Quote
*high Posted May 10, 2016 Report Posted May 10, 2016 I'll show you all the grounding again when I remove balanced pcb. I guess just one thing is missing here https://docs.google.com/file/d/0B4NVeoQi85GgOTdvOGpxc1hyRFU/edit and therefore this build: 15V GND on the safety earth. On the other hand, that again may cause a ground loop. So, transformer shield is hidden. 220V and 2-pin power socket, no ground plug. Then there is and So I guess my mistake is that volume pot GND is not on the star ground, as a theory says it should be on the spot with the weakest current, which is a volume pot gnd. Quote
spritzer Posted May 10, 2016 Report Posted May 10, 2016 So the chassis is not earthed? That is very, very bad idea. All the GND pads on the boards are connected together. Quote
*high Posted May 10, 2016 Report Posted May 10, 2016 On 5/10/2016 at 2:44 PM, spritzer said: So the chassis is not earthed? That is very, very bad idea. All the GND pads on the boards are connected together. Expand It's grounded all right, as far as three-phase power transmission goes, but it's pretty common ungrounded / unearhed system standard. It sucks, I agree, but not that bad =) So 15V GND and 450V GND and volume pot GND all connected together? Quote
spritzer Posted May 10, 2016 Report Posted May 10, 2016 (edited) I got a power amp from China and it was naturally ungrounded and it hummed no end. I could actually feel the current flowing when I touched it. One wire later and it was fine. Take one wire from each of the amp boards to the PSU and one from the pot to the PSU. Then one wire to the chassis, nothing else. That should fix the issue. Edited May 10, 2016 by spritzer Quote
*high Posted May 11, 2016 Report Posted May 11, 2016 It's time for awesome / horrific stories Diodes are insulated, RCA single end is taken, the amp is star-grounded So the reading of my 450V: bias TP 575V, bias 397V, R+R- and L+ L- are balanced to 0V, and horror time: R+ GND 136V and L- GND 122V, offset pot doesn't seem to change that Huston, is it a big problem? Quote
