Thanks johnwmclean, you're right, this is a single primary transformer. Will have to reorder one /w dual primaries.
No worries.
Should check your line voltage, mine here fluctuates around 240V - 250V here in Sydney.
The 230v spec could be a problem?
The transformers are over spec so line fluctuation should never be a problem.
It still can be tricky, making sure the power supply heat sinks can cope, for example, even if there is extra current capacity in the PSU. I like to plan for 10% line fluctuation.
Edited by luvdunhill
So I received two packages today and one of them is the 2SC4686A I bought on eBay from UTSOURCE.
In the photo below are two 2SC4686A, one I bought from BDENT (on the right) and one from UTSOURCE (on the left). Can anyone spot any difference or discrepancies other than the batch code?
All I have is a Fluke 112 multimeter. Is there some way I can test the two to see if the eBay ones are legit?
Thanks!
post-4147-0-31546000-1425945746_thumb.jp
Looks legit. I have some old stock I got from a diy'er on diyaudio, bdent and a UK seller on ebay and there are some in the odd 50 bag of them that look like either of those 4686's.
It's probably the same that a few of us got from another ebay-seller a while ago; genuine but very old (pre-RoHS). They look the same at least.
//UFN
Edited by UFN
Thanks all for your response. I do plan on getting a DY294 in the near future.
Seeing yours look the real deal I just bought a bunch from the same vendor.
At $0.50 a piece and cheap shipping.... not bad. ;D
What are you building me?
The lsk389 is supposed to be better than the PMBFJ620. is this difference really significant.
As I will have to buy the 389 from Trendsetter and with Postage to NZ will cost me $35 per
Transistor. Is it really worth paying that?.
Thanks
Les
Oh I was referring to ordering from Linear, you can shoot the company an email and they are perfectly willing to sell pieces in any quantity. I think it's either 6 or 8 usd a pop
You can order the LSK170s from diyaudio at ~$18 for a set of 8. Not sure how these typically match up; I know Spritzer said the LSJ74s were all over the place for Idss.
Register a new account
Sign in
