Parts and layout looks a lot like a KGST (KGSSHV front end) with SiC replacing the tubes.....
Great looking development gentlemen, keeping the hobby electric.
I know it was comically named in the other KGSShv thread  but should it be KGSC, Carbon , or KGSiC (!)
Well perhaps not KG sic.
Edited by headinclouds
Thanks. PSU is now finished, 1st amp board getting along nicely. Amp board version 0.63 has the 18v zeners -D5 and D6 below - marked with an M - I assume that they are not populated for the C4686A, just for the 05n100m? There is nothing in the schematic suggesting they are left out for the C4686A MvxqwX5.png On the PCB: g67pAd9.jpg Top right, marked B, between the 1K and 1M is a link when using the C4686A - left open using the 01N100D Mosfet? Thanks
Anything marked B is for the BJT's and anything M is for the mosfets.  The mosfets should never be used really (outside the CCS), the performance is pretty much terrible.
I have a grounding question relating to the the XLR ground (Pin 1). Earlier in the forum it’s mentioned:
“… XLR pin 1 should not be connected [to star ground]. it should be connected to the chassis through the shortest path possible.” Similarly, in johnwmclean wiring diagram, each XLR Pin1 is connected to the chassis by itself.
What I wanted to clarify:
  • Can the two Pin 1 wires be soldered to the same spot on the chassis? In the diagram they are connected at two different spots
  • What’s the reason for not connecting Pin1 to star ground? I.e. All ground wires into one point
If XLR pin 1 is the shield, the chassis should act as an extension of that shield, the best way to do this is to connect pin 1 via the shortest wire at the entry point of the chassis. This is all explained in rane notes.
Need some advice here.
Can the KGBH mini PSU that many have used to power the KGST be used to power the KGSSHV Mafia version? Would it compromise the performance of the KGSSHV?
Your thoughts and advice are much appreciated.
I was able to use the KGST mini PSU @ 350V with kgsshv amplifier boards, with no modifications whatsoever. The one thing I noticed was that the DC offset tended to settle at -15.x V
You can probably zero it out with a single resistor change
Thanks nopants and Birgir for your help.
Hi Birgir:
Can you elaborate what you mean by the Mafia version not being a forgiving PCB? Are you referring to the potential arcing problem resulting from less than careful soldering job and flux residual?
Also, for the Mafia board, can I replace the 2SA1968 in the current source with ixtp01n100d? I know this is possible with other version of KGSSHV boards but involve chaning a few resistors as well.
Best!
Well that plus the soldering technique has to be perfect due to the compact size of the board.  All leads neatly trimmed and the board properly cleaned of all flux residue.  Also the top center hole, if that is used for mounting (which I do) it has to be properly insulated.
The mafia board is 2SA1968 only and any attempts to try and make it work for the IXYS parts would probably end badly.  There is another slightly larger HV board design which can take both parts.  It's never been tried but it should be problem free.
Many thanks Birgir.
I'll have to give it some serious thoughts which amp board to use. I have spent many nights now reading this thread to learn as much as I can to prepare for a build. I am looking at the Mafia board because I like to build a off-board heatsink version to allow some flexibility in tweaking output current and voltage swing. The Mafia version is the only off-board version listed on Kevin's site and uses current parts except for the 2SA1968.
I am at page 137 of the thread now and have read about many firework and smoke shows. I may very well change my mind by the time I finish reading :-)
Two questions regarding PCB grounding and power PCB connection:
  • Should I use nylon or metal spacers to secure the PCBs? Does it make a difference if I'm already running wires to a star ground point?
  • On the power PCB (rev 0.6) there is the connector "CT AC30 AC30". Where do the CT and AC30 connect to? The transformer has secondary 16V-0-16V wires
You can use nylon or steel stand-offs, if in doubt it’s safest to stick with nylon. The PCB holes for the stand-offs are not connected to the circuit ground, so this won’t make any difference to your star grounding point.
16V-------> AC30
0----------> CT
16V-------> AC30
Edited by johnwmclean
Many thanks Birgir.
The fireworks are mostly a thing of the past as we've improved the circuit boards over the years.  This is still a very high voltage amplifier so if the soldering isn't perfect and the circuit boards clean of any flux, it can blow up.
I'll send the larger offboard PCB files to Kevin and if he's happy with them, he'll add them to the library.
That would be great. Much appreciated.
I have seen an offboard version in Kevin's earlier post (#3608), it's named kgsshvampv16mini which also allow the option to use ixtp01n100d for CCS. Is this the board you are referring to? It still looks small with very little space between parts. I do remember seeing photos of a larger but similar boards with less parts in earlier posts but did not see the Gerber file for it in Kevin's library.
For the Mafia boards, am I correct to assume running them at lower voltage (< 400V) would reduce the risk?
Thanks!
I posted kgsshvampv15mini and kgssmvampv16mini
Many thanks Kevin and Birgir.
What's the difference between the two versions? I tried compare the v15 and v16 boards using an online Girbir file viewer, it seems the only difference between the two is the 3.3K resistor (R43) being physically relocated to a different spot on the PCB. Did I miss something?
I apologize if this was already mentioned in the thread. I just got done reading all the posts and taking notes but don't recall coming across this information.
i'm pretty sure the only difference is the position of the center mounting hole
Thanks Kevin.
Yes, now that you pointed it out, I did notice that the center mounting hole was relocated to the center location on the kgssmvampv16mini PCB. There are actually a few parts that were relocated to make this possible. The silkscreen identify this board as Rev. 0.91.
