Congratulations S_R!
It's not the alpha pot. I had a similar problem with my offboard build unit a goldpoint.
There was a hum with the knob turned all the way down and only with the first step. Dead silent afterwards. Could not get rid of it.
With my onboard build and using he alpha pot, it's dead silent.
Very good news for a fantastic job, I don't found the time to start with my amplifier and when I see a new KGSSHV is always an incentive to start this little adventure.
Congratulations s_r
-- o --
Rodrigo
My HV is now back up and running after the replacement trafo came in.
To be on the safe side, I went from having a 100VA to a 150VA.
I  finished cabling the onboard version of the kgsshv (v0.2). I am running in some trouble with the amp boards and could use some help and pointers on how to resolve the problem(s)
- Power supply is OK +/- 445V (I was going for ~450V), and +/-15.0V.
- On the first amplifier board, one LED does not come on. That's the LED that is closest to the lsk379, towards the lower left corner of the board. The voltages at O+ and O- are the same as for +VCC (+443V). -VCC is -442V
- On the other amp board, all LEDs are on. O+ and O- are approximately 20V apart, (+110 and +130V). +VCC and -VCC read the expected values (about +443 and -442V).
All voltage measurement with respect to ground. All measurements with Khozmo attenuator set to lowest level. All transistors from respectable sources. Any help to jumpstart the troubleshooting would be appreciated. Thanks.
The one board is clearly working, adjust the offset pot to get the outputs close to zero.
On the other one, make sure the differential pot is set to the middle first and the offset
pot set for the higher end of the resistance range.
Thank you Kevin. Though that may have to wait until next week-end, I will try and report.
I've been interested in building a smaller version of this amp so I started playing around with a chassis layout and board layouts for PS and the amp boards that could fit in a chassis that is approximately 8"x3"x14".
I blended SMD in with the amp board.  Makes it a bit more difficult, but I wanted to experiment.
Here's the project so far:
The power supply...
Requires two boards (2.5" x 5" each).  The Output MOSFETs will mount directly to the heat sinks.
The small board on the left is the adjustable voltage doubler for the BIAS.
The amp boards will mount vertically against the heat sinks.  I'm going with Conrad MF20-75.  They are 200mm x 75mm x 48 mm.  I haven't gotten to the amp boards yet since I wanted to get the PS up and running first.  These boards are 2.5" x 6" each.
This will be the BIAS.  It supports two different voltages.  This one is set at 500V and 580V.
Still in the experimentation phase, but moving along.  Will keep posting as I go through this.
Edited by Kerry
I like the dimensions,
I wonder what would be the best way to support the psu boards in their upright position? The transformer diameter might be a factor as well.
Edited by johnwmclean
The PSU boards will mount against the side plates using stand-offs (approximately 40mm).
I had SUMR build me a transformer that is 2.3" tall and 3.7" diameter.  That gives about .25" between the transformer and PS boards.  I'm hoping this doesn't cause any induced hum in the PS.  I'll test before I mill out the chassis plates.
Well I haven't done anything on that small one for months...  :-[   Too much crap going on and currently thinking too much about DHT's...
Ohh and my Tiny Triode amp PCB's just arrived for some true miniature fun. ;D
I just tested the first board.  Everything worked great :)
I've got to adjust the voltage down a bit but that's a simple fix.
Ignore the heat sink on the MOSFET.  It's just while I'm doing the unloaded test.
Amazing job Kerry.
I bought some 2SA1968 (Lots 1E4 and 9G2) and I'm not sure if these sands are original. I think that the aspect is similar of the originals, I measured Vbr with a DY294 and all units are over 1000v, but the HFE is lower than 20 (14 to 17) and I've read in the datasheet that HFE is between 20 and 50. Are these low values of HFE normal, or these sands are fakes?
-- o --
Rodrigo
Edited by PICaudio
The outputs of problem board are unresponsive to offset or balance adjustments. Both are stuck at vcc. The LED that does not light up is the bottom right one on the picture. The LED in the middle will come off with high balance setting. Could it be the LSK389 that is faulty or fried?
I adjusted the other board's outputs to 0v
Register a new account
Sign in
