I'd take 50 2sa1486
It really sucks how so many of these transistors get discontinued.
I just went in for 50 pairs of matched sk170/sj74 as well. Didn't realize they were getting so rare. Hopefully I can get some decently matched quads in there
Edited by cobra_kai
Congrats! What exactly did you change? Did you have to get a beefier transformer? IIRC your PSU was confirgured for 450V right?
Thanks!
The transformer is a beefier 150VA model, it uses a screen and the 420 V windings are now capable of continuous current @ 250mA.
The psu is standard 450V, for the amp boards I changed R8 and 9 from 180ohm to 113ohm, simply by parallelling 300ohm over the existing 180ohm resistors which saved lifting the amp boards of the heat sinks. I was going to dabble with the third stage, but chose to leave it, I was concerned about not being able to get the boards to balance. As it is I can get both boards under 1 V, but cannot get down to the ~ 0 V where I was before, not that is matters, just worth mentioning. As for heat, there’s not much difference, runs slightly warmer overall.
Listening I found higher frequencies have opened up, sounded really good to my ears and definitely worth the effort.
Justin, I'd like to change my request to 100 pieces of 2sa1486 if possible. Thanks.
John: that sounds pretty interesting. Would love to compare it with the standard resistors.
Thanks Victor,
There’s not really much to see, however here is what I did. Either side of the LED in R8 and R9 positions the default 180ohm resistor is still in place I simply paralleled a 300ohm resistor over the top. This changes the value to 112.5ohm.
The calculation mA is derived;
1.7v - vbe junction (.7) /112.5 ohms == 8.8mA
(see Kevin’s post #1893 for detail)
Thanks Kevin and Birgir for all your help with this.
Edited by johnwmclean
i'm going to order them but the lead time is 12-14 weeks
