dBel84 Posted October 13, 2011 Report Posted October 13, 2011 https://audeze.com/audez%E2%80%99e-debuts-%E2%80%9Creality-1%E2%80%9D-planar-magnetic-professional-reference-monitor-and-audeze-lcd-3 the monitors look very interesting ..dB Quote
ujamerstand Posted October 13, 2011 Report Posted October 13, 2011 LCD-3? Purrin and Tyll if you guys are reading this, please measure them if you have the chance! Quote
monsieurguzel Posted October 14, 2011 Report Posted October 14, 2011 that was fast. I was expecting LCD-3s in the near future but didn't know they'd come out a month after the last revision! If history serves me right, it's best to wait at least 5-6 months for all the kinks to be worked out. Quote
K3cT Posted October 14, 2011 Report Posted October 14, 2011 (edited) I snatched a rev2 since it came first at a good price but I'm finding the vocals to distant for my taste. The rest I found out it was a improvement,the soundstage, treble etc.. This from memory and I recall the Lcd2 being much more upfront with the vocals but I could be wrong.. Is this just my imagination or the difference is really that much? Midrange is definitely different but I'd say overall the differences between the two versions are subtle (though discernible on certain aspects) once you make sure that both of them share the same pads and cables which I did when I A/B-ed them. Overall I'd agree that the R2's midrange is not as engaging as the older version ergo my decision to stick with what I have. I listen to a lot of vocals so a good midrange is an important criterion. Edited October 14, 2011 by K3cT Quote
kevin gilmore Posted December 4, 2011 Report Posted December 4, 2011 (edited) So i have birgir's pair of LCD2's here for extended listening while the transistors are on their way back from england. They sound so dramatically different on all the amps i have tried, And measurements show that these things generate signifant amounts of back EMF, and therefore require an amplifier with a very low output impedance to sound right. OTL tube amps, even the SP extreme perform very poorly on these headphones. The only single ended transformer based amp i have, also sounds pretty grim. Only push pull high bias amps seem to work right. And push pull tube amps also sound really good. Good enough that i will be buying my own pair on monday, and i'll skip the lcd3's for now and get lcd4's later. half an amp at reasonably loud listening levels has been measured with my hall probe. I think that tyll needs a high current buffer amp for his measuring system, because the built in amplifier really cannot drive these kind of headphones correctly. The waterfall and decay plots will change a bunch when done this way. Edited December 4, 2011 by kevin gilmore Quote
The Monkey Posted December 4, 2011 Report Posted December 4, 2011 How do you guys think a B22 would work with these things? Quote
Torpedo Posted December 4, 2011 Report Posted December 4, 2011 It drives them great, Dinny. Of all the amps I've got here, it is the one that gives best performance. On the P1... not of my liking. Quote
Pars Posted December 4, 2011 Report Posted December 4, 2011 When I had jvlgato's pair, both my SE Dynalo and Dynahi drove these quite well. They did not sound good on my brother's torpedo amp however. Quote
blubliss Posted December 4, 2011 Report Posted December 4, 2011 Have not listened too much but the new Dynahi is not great with them, but with the HD800, oh my! Quote
wink Posted December 4, 2011 Report Posted December 4, 2011 (edited) Johnwmclean's B22 sounds great with both his LCD-2 r2 and my LCD2 r1. I still like my HD800 on it better.... YMMV probably more than possibly. Edited December 4, 2011 by wink Quote
blessingx Posted December 4, 2011 Report Posted December 4, 2011 On my three board B22 I overall thought the opposite on the LCD2 v. HD800. Quote
Spychedelic Whale Posted December 4, 2011 Report Posted December 4, 2011 I believe some one from here reported good results with the peak, don't remember who. Quote
luvdunhill Posted December 4, 2011 Report Posted December 4, 2011 Kevin, perhaps adding a compensation circuit would help? Perhaps there is an impedance peak that a Zobel network could flatten? Quote
recstar24 Posted December 4, 2011 Report Posted December 4, 2011 I thought back emf was a non-issue with ortho's? Quote
wink Posted December 4, 2011 Report Posted December 4, 2011 I overall thought the opposite on the LCD2 v. HD800. So did John. After hearing my LCD-2 r1, he sold his HD800 and got his LCD-2. Quote
Torpedo Posted December 4, 2011 Report Posted December 4, 2011 Beta22 + LCD-2 = Good Beta22 + HD800 = meh Luxman P1 + LCD2 = meh-bah-not good Luxman P1 + HD800 = Gooood Quote
K3cT Posted December 4, 2011 Report Posted December 4, 2011 (edited) How do you guys think a B22 would work with these things? It's the best among the high-end amps that I've heard it with. The Zana Deux fared the poorest with the LCD2 doing a good imitation of a closed headphone in that combination, the WooAudio WA5 fared a little bit better but nowhere near what an $3k amp should sound like, the Apex Peak/Volcano probably came the closest with the Beta22 but I was a bit uncomfortable with its tendency to sound a bit shrilly (w/ Shuguang Treasure Tube). The quest for a tube amp that sound good with the LCD series continues. For now, I'm convinced that solid state seems to be the way to go with this particular headphone. Edited December 4, 2011 by K3cT Quote
kevin gilmore Posted December 4, 2011 Report Posted December 4, 2011 Kevin, perhaps adding a compensation circuit would help? Perhaps there is an impedance peak that a Zobel network could flatten? that would have to be on an amplifer to amplifier basis. Way too much trouble. I thought back emf was a non-issue with ortho's? you would have though that. But with a low impedance coil and a large magnet structure, the thing has quite a kick. blubliss wants me to find a push pull tube amp. I thought this would be easy, someone had to have a low power push pull tube amp for headphones. Evidently not so easy. The smallest of the atmaspheres might work, There is a cary that would probably work, and a vtl. All 3 of which have stupid pricing for what they are. i'm betting that classic old marantz and mcintosh tube amps are going to sound very nice, especially the mcintosh. Quote
deepak Posted December 4, 2011 Report Posted December 4, 2011 Leben CS300 is a push pull EL84 amp with headphone output, I hear skylab likes it I thought they sounded really good with the Dynamite balanced (with balanced source). A bit better than the G Lite. Quote
dsavitsk Posted December 4, 2011 Report Posted December 4, 2011 blubliss wants me to find a push pull tube amp. I thought this would be easy, someone had to have a low power push pull tube amp for headphones. Evidently not so easy. I've got a tube push pull Gm amp for headphones. Maybe not quite what you are looking for, but might be OK. Also, digger945 has one, I think. Quote
johnwmclean Posted December 5, 2011 Report Posted December 5, 2011 (edited) Beta22 + LCD-2 = Good Beta22 + HD800 = meh Agreed. Haven’t heard a Luxman. Just to add... EHHA + LCD = Good Beta22 + LCD = Good Edited December 5, 2011 by johnwmclean Quote
swt61 Posted December 5, 2011 Author Report Posted December 5, 2011 I guess that's why I was underwhelmed when pabbi1 lent me his HD800. Quote
FrankCooter Posted December 5, 2011 Report Posted December 5, 2011 blubliss wants me to find a push pull tube amp. I thought this would be easy, someone had to have a low power push pull tube amp for headphones. Evidently not so easy. I've been running my LCD-2's with a couple of tube amps. The first is a single ended, direct coupled 56/46 with Electra-Print 5k:32 output transformers. Power supply is solid state rectification with tube regulation. Output power is about 1.5w. The second, which might be more interesting to you, is a small push-pull amp based on the Russian 4P1L directly heated pentode (triode connected). Output transformers are recycled from an old Fisher 500C. Input stage is simply a W.E. 418A driving an Electra-Print autoformer. Power supply is same as the first amp. Output power is about 3w.. Small push-pull amps are underexplored in the headphone world, and at least in my experiance, can work quite well. Quote
