jack1953 Posted April 22, 2010 Report Posted April 22, 2010 One of the rubber earpads came off. If you own a pair of these you know it's impossible to put these back on. Is there a plan B? Quote
grawk Posted April 22, 2010 Report Posted April 22, 2010 Rubber ear pads? You mean the pleather? Those aren't hard to put on. Quote
jack1953 Posted April 22, 2010 Author Report Posted April 22, 2010 Rubber ear pads? You mean the pleather? Those aren't hard to put on. How? there's a small slot that the pleather is supposed to go back into and i have no clue how it's possible to do. Jack Quote
mypasswordis Posted April 22, 2010 Report Posted April 22, 2010 One of the rubber earpads came off. If you own a pair of these you know it's impossible to put these back on. Is there a plan B? I guess you should've thought about that before you had unprotected listening. there's a small slot that the pleather is supposed to go back into and i have no clue how it's possible to do. Do it like you did the first time but make sure not to have it fall off halfway through. Sorry, I couldn't resist. Quote
Dusty Chalk Posted April 22, 2010 Report Posted April 22, 2010 Rubber ear pads? You mean the pleather? Those aren't hard to put on.It's hard, but not impossible. Especially with a twinkle-thumbs like me. Quote
Pars Posted April 22, 2010 Report Posted April 22, 2010 If they're anything like the sony mdrV2s I used to have, patience is the key. Sounds like you're running a bit short on that. Try using a small screwdriver or something similar to get the edge into the slot and work your way around. I did mine at work where I don't have a lot of time to be farking with such shit, and I got mine back on. Quote
grawk Posted April 22, 2010 Report Posted April 22, 2010 eh, if you can't figure it out without help, just buy a new set and give the set you have away. Quote
Knuckledragger Posted April 22, 2010 Report Posted April 22, 2010 The answer is simple. #1 You buy there: Beyerdynamic | Padded Earcushions for DT250/DT280 | 942704 | B&H #2 You peel the backings off your old pads. #3. You put the backings on your earcups. #4. You use your comfy new pads to hold the backings in place. #5. You enjoy your newly-upgraded V6s/7506s. You can expect much more comfort, a better seal, and possibly more bass. Quote
