March 28, 201214 yr comment_506471 I know I asked this a while back, but what are you thinking of doing for the power supply Kevin? You thinking of tailoring something for this specific build, or do we just come up with our own solution (ie, o22)? Edited March 28, 201214 yr by Horio Report
March 29, 201214 yr Author comment_506573 Have not even thought about the power supply yet. In the simplest version the smallest power one tripple works great. If you go with the outboard amplifier modules then you need something that does +/-20, then you can regulate that down to +/-15 with simple 3 terminal regulators, and +12 to drive the relays. Report
March 29, 201214 yr comment_506636 Do you have a rough idea what the current draw is for the various voltages? Seems like the 12V line is going to be very small, but the 5V line might see some current with the Arduino. I have no idea what the +/-20V and +/-15V might see though. Edited March 29, 201214 yr by Horio Report
March 29, 201214 yr Author comment_506637 Fully loaded, on the 20v lines about 500ma On the 15v lines about 250 ma 12v line peaks of 30 ma 5v line I gotta look up Report
April 27, 201214 yr comment_511624 How is the progress coming along? Is the testing going well? Report
April 27, 201214 yr Author comment_511648 Kerry still messing with the multi amp I'm waiting on hopefully final preamp boards Edited April 27, 201214 yr by kevin gilmore Report
April 28, 201214 yr comment_511737 I was out on vacation and came back to a ton of work. I'll have some time to finish playing with the servos next week and hopefully we'll be good. Report
May 23, 201214 yr Author comment_516613 Sure there is a schematic. Its in my head somewhere. There will be an official schematic at some point. There is a bunch of different ways to build it including single ended only, and balanced/single ended The on board buffer which you don't have to use is an lme49710 driving an lme49600 closed loop with a tl071 as the servo, optionally the lt1150. The onboard single ended to balanced is an opa1632 with a tl071 servo. you don't have to use that either. multiamp works for both. Single ended there are x1 buffer opamps. Clear as mud right? There are a couple of people on amb's forum that think i have sold out to ic's... But they should hear the thing. Just about impossible to tell between the chips and the multiamp. Edited May 23, 201214 yr by kevin gilmore Report
May 23, 201214 yr comment_516614 There are a couple of people on amb's forum that think i have sold out to ic's... But they should hear the thing. Just about impossible to tell between the chips and the multiamp. Blasphemy!!!!!!!! Report
May 31, 201214 yr comment_518184 They've been making good progress on the display front for the raspberry pi: Report
June 6, 201214 yr comment_519112 Kerry, How is the testing of the multi-amp boards going? Just curious. Report
June 19, 201214 yr comment_521222 I just finished reading through this thread and want to build one of these. I will definitely be on the lookout for the boards when they become available. Thank you KG. Report
July 21, 201214 yr Author comment_526756 waiting on kerry for any final changes to the multiamp board. preamp board is finished. Report
July 31, 201214 yr comment_528296 I've been out-of-pocket a bit on a new consulting gig and traveling as well. Will get to the multiamp next week. Just playing with the servos at this point. I've built it with the THAT bjt's but I'll try the jfets just to make sure. Report
September 11, 201214 yr comment_534782 Kerry, have you had a chance to play around with the multiamp boards at all or does the new job still have you swamped? Report
October 30, 201213 yr comment_542802 Has there been any progress on this? After the T2, I'm hoping this will be my next big project. Report
December 16, 201213 yr Author comment_552136 http://gilmore.chem.northwestern.edu/kgitsoch.pdf An even sweeter way to do unbalanced/balanced to balanced. Report
December 24, 201213 yr Author comment_553360 here is another one i like, buildable with currently available parts http://gilmore.chem.northwestern.edu/fcnf.pdf input can handle 10 volts peak to peak, its another operational transconductance amp. input can also handle 2 volts of common mode or differential mode offset with 0 volts dc output, something just about no other circuit can do. No feedback, and distortion approaching .01%. Flat to about 500khz. Needs +/-45 volt power supplies, and plenty of heatsinks. Otherwise cheap to build. Add a unity gain output buffer (2 of them) and set the gain with 2 resistors (or a 3 position switch) and a constant impedance attenuator and have something very slick. Report
December 26, 201213 yr comment_553637 No feedback, and distortion approaching .01%. Flat to about 500khz. at what load? Report
