Rattle in right driver of Sennheiser HD 595, please help
hiya fellas. ive had my 595s for a while now and they've had some issues. at one point i lost nearly all sound from them, discovered my ground was disconnected and was able to fix that. the only lingering problem is a rattle coming from within the right driver. ive taken the right cup apart and found no hair in the driver, tried blowing gently on it to try and pop out a potential crease in the diaphram, and no luck. really a bummer at this point, anyone got an idea?
edit: it should be noted that the rattle is only present during really low bass notes, and this is all the more reason id like them fixed.. i listen to a lot of Dubstep.
im pretty certain the driver is sitting just fine. in fact, when seperated from the cup, i can clearly hear the rattle from within the driver. luckily these cans arent too difficult to disassemble and everything goes back together real snug.
