SrRealist Posted February 12, 2010 Report Posted February 12, 2010 hiya fellas. ive had my 595s for a while now and they've had some issues. at one point i lost nearly all sound from them, discovered my ground was disconnected and was able to fix that. the only lingering problem is a rattle coming from within the right driver. ive taken the right cup apart and found no hair in the driver, tried blowing gently on it to try and pop out a potential crease in the diaphram, and no luck. really a bummer at this point, anyone got an idea? edit: it should be noted that the rattle is only present during really low bass notes, and this is all the more reason id like them fixed.. i listen to a lot of Dubstep.
Voltron Posted February 12, 2010 Report Posted February 12, 2010 Hiya fella. See if Senn will replace the driver for you or get another pair.
The Monkey Posted February 12, 2010 Report Posted February 12, 2010 Obvious question, but is the driver seated properly? If so, sounds like a new driver for you. Although I recall some strategies mentioned when I had a similar driver issue, so others may chime in here.
SrRealist Posted February 12, 2010 Author Report Posted February 12, 2010 im pretty certain the driver is sitting just fine. in fact, when seperated from the cup, i can clearly hear the rattle from within the driver. luckily these cans arent too difficult to disassemble and everything goes back together real snug.
