spritzer Posted April 10, 2015 Report Posted April 10, 2015 The thermistors can go bad and do all sort of funny things to the amps. Try bending the arc to get a better fit on the SR-40. Most of these were designed to be bent into shape. Quote
ktm Posted April 10, 2015 Report Posted April 10, 2015 I don't see anything obvious. Thermistors appear ok, but that's pretty hard to really check. I'm going to have to unsolder them There's two on each channel in parallel. The rest of it looks ok. There are some differences in how they are built. The srd4 has larger, single thermistors on the input. it also has 5 watt 27 ohm resistors in parallel with the transformers. The srd6 has a spot on the board for them, but doesn't have them installed. This is the big difference (other than bias tapped off one channel). I could see where this might change the sound signature. Guess I just need to accept the fact they have a different sound. Quote
DefQon Posted April 11, 2015 Report Posted April 11, 2015 They would be the same except the SRD-6 box has a bias supply for full blown Stax electrostatic models. The SRD-4 don't have bias which suits exactly the SR-80's electret nature as it has a fixed/charged bias. I think the original SR-80 Pro's came with a pro-bias solution box. (Again the Pro was just purely for marketing because it came with a pro-bias capable adaptor and not the standard SRD-4 electret adaptor). Quote
ktm Posted April 11, 2015 Report Posted April 11, 2015 I really am going to have to build a decent energizer. I built an exstata hybrid, which is ok, but with all the great designs out there it's about time to move up a couple of levels. The sr-80 and srd-4 should hold me over for a while. I think I'll gut out parts from the exstata and drop in some new boards. Quote
spritzer Posted April 11, 2015 Report Posted April 11, 2015 The SR-80 Pro shipped with a bog standard SRD-4 except it had gold printing on it. Well that and the SRM-Xs too which was just a Xh minus the bias supply. There is no difference between the boxes whether they have bias or not. The SRD-6 not having protection resistors almost guarantees that it has suffered some damage. The SRD-6's also didn't have a power switch which has caused some problems though mostly on the headphone side. Quote
ktm Posted April 11, 2015 Report Posted April 11, 2015 Ok, I've played with vintage stuff for years, so I should of done this 1st. Clean 30+ years of crud out of the switch, clean out the socket connections, I also cut back the wires to fresh copper and crimped on copper pins. Bass is there now. But the srd-4 still has the warmer sound. I didn't have 27 ohm wirewounds, so I doubled-up 68 ohm 3 watt for 34 ohms. Now both boxes pretty much sound the same. That was the only real difference, and with them in place on the srd-6 it changed the sound. The 4 is still just a bit warmer, but I prefer it this way. If I change my mind, I'll go find the proper 27 Ohm ones. In a pinch I could use the 6 with the 202's as well. Quote
DefQon Posted April 12, 2015 Report Posted April 12, 2015 Such a rare sight to see something like this: But overpriced http://buyee.jp/item/yahoo/auction/r126553633 Quote
spritzer Posted April 12, 2015 Report Posted April 12, 2015 You do know these are our boards so not that rare. Silly expensive though. Quote
mwl168 Posted April 12, 2015 Report Posted April 12, 2015 The description says the boards are 4mm thick. Wonder how much the accounts for the high price? Quote
spritzer Posted April 12, 2015 Report Posted April 12, 2015 Not much. Most of the Chinese boards are silly thick. Quote
GeorgeP Posted April 12, 2015 Report Posted April 12, 2015 Such a rare sight to see something like this: But overpriced http://buyee.jp/item/yahoo/auction/r126553633 Those look like the boards Tran made with other people 's money. 1 Quote
kevin gilmore Posted April 12, 2015 Report Posted April 12, 2015 for that price you could have 5 sets made, no problem. Some of this is beginning to upset me, people making money for stuff I give away. The Chinese ksa5 clones also piss me off, they are hacked up garbage. They have no idea why the original sounded so good. Quote
Tachikoma Posted April 13, 2015 Report Posted April 13, 2015 Heh, if you look on Taobao now, there's an ad for the Megatron as well. Quote
nopants Posted April 13, 2015 Report Posted April 13, 2015 (edited) http://tw.taobao.com/item/43870740416.htm Description taken straight from mjolnir audio's site. Those sinks aren't even the right size. Wasn't there a guy on this forum asking about the use of AMRG resistors? Edit: same exact pictures from xianghao's bs, with those undersized sinks used in the megatron supply Edited April 13, 2015 by nopants Quote
wink Posted April 13, 2015 Report Posted April 13, 2015 Gents. How do you tell a Stax SRE-725 extension cable from a SRE-925S..? The new ones are both black and don't have any differentiating marks like model number on them. Quote
padam Posted April 13, 2015 Report Posted April 13, 2015 White vs yellow lines on the cable just like on the headphones Quote
edstrelow Posted April 13, 2015 Report Posted April 13, 2015 " There are at least 4 very different versions of the SR-007Mk1 but they never changed the name. The SR-Omega came in three versions and that was with Stax on their last legs. " I am curious as to what these differences were? "It has also been confirmed why Stax altered the headphones." Confimed? How and/or by whom? Quote
DefQon Posted April 14, 2015 Report Posted April 14, 2015 You do know these are our boards so not that rare. Silly expensive though. Ah didn't know only have seen the green ones from Tran's GB. I thought the pcb's were original Stax SRM-T2 ones. Quote
spritzer Posted April 14, 2015 Report Posted April 14, 2015 A Stax T2 has about 8-10 different PCB's and is built in no way like ours. Also black PCB's are just stupid. We do green for a reason. Quote
chiguy Posted April 14, 2015 Report Posted April 14, 2015 Just curious, what benefits would one PCB color have over another? Quote
spritzer Posted April 14, 2015 Report Posted April 14, 2015 It's better to be able to see arcing and other burns should they occur. Also the traces are all but invisible on a black board which is far from ideal. Quote
kugino Posted April 15, 2015 Report Posted April 15, 2015 I picked up a used 717 that is a Japanese 100v model that the seller said was adjusted to 117v. is there any way to verify this? if I were to use it plugged into my US outlet, will I damage the amp or earspeakers if it has not been converted properly? Quote
rx79ez08 Posted April 15, 2015 Report Posted April 15, 2015 I picked up a used 717 that is a Japanese 110v model that the seller said was adjusted to 117v. is there any way to verify this? if I were to use it plugged into my US outlet, will I damage the amp or earspeakers if it has not been converted properly? Open up the amp and see if the jumpers are set correctly. A guide to the jumper can be found here: http://www.head-fi.org/t/223263/the-stax-thread-new/23625#post_9627206 Quote
spritzer Posted April 15, 2015 Report Posted April 15, 2015 Post a picture of the transformer board and we can tell you. Quote
kugino Posted April 16, 2015 Report Posted April 16, 2015 thanks...so it looks like the jumpers are on 2, 4, 6, which corresponds to 120V, correct? Quote
