Deadneddz Posted January 22, 2010 Report Posted January 22, 2010 Both options would be fine, although hanging it from the arc assembly can cause the leather to become worn over time, since its so tightly wraped around the metal. I actually prefer to just lay them down on a towel or flat surface and under a dust cover. Quote
cetoole Posted January 22, 2010 Report Posted January 22, 2010 I'd say those were mint and the pads look to be in perfect condition too. The cable is indeed the only known place where they do fail and it is something which Stax took care of with the Mk2. Using them with an extension cable will increase it's life by giving it ample slack. I always hang mine for the headband on a Stax stand and after 7 years (fuck that's a long time ) the elastic band is just like new. If something eventually happens to the cable on a mk1, can it be replaced with the improved mk2 cable and strain relief? Quote
padam Posted January 22, 2010 Report Posted January 22, 2010 O2s might like to hang on a stand like this Quote
spritzer Posted January 22, 2010 Report Posted January 22, 2010 Yup but you'll have to use the small cover to block the port unless you want mad bass!!! Quote
padam Posted January 22, 2010 Report Posted January 22, 2010 The problem is, do they actually supply parts that are not considered to be user-replaceable? At least I was told before when I asked for an SR-404 Limited cable. Quote
spritzer Posted January 22, 2010 Report Posted January 22, 2010 Stax Japan have been ehhh... difficult as of late but the distributors will supply you with a cable. Quote
mypasswordis Posted January 23, 2010 Report Posted January 23, 2010 Finally got the universal plug adapter today so I could listen to my ET1000, only to find there's a fucking channel imbalance. There's a number of issues it could be, like it not being charged up or possibly the little bit of fabric damping in the front (the side with less volume has it while the other side is partially removed). Could be the adapter too. Sigh, I wish I didn't have to troubleshoot almost every single pair of headphones I've gotten. Sounds like an SR-X mk3 on uber steroids, though. Quote
skullguise Posted January 23, 2010 Report Posted January 23, 2010 SRM-T1W & LNS: AudiogoN ForSale: Stax Srm-T1w Tube driver with Lambda This seems to be a somewhat well-regarded combo based on a search of this thread. Can anyone concur/comment? I was basically ready to pay the ~$2K for the rig that Stretch got if he hadn't gone for it..... If not this, what phones might go well with a SRM-T1W amp, which I also may be able to get with help from Nate? Quote
cetoole Posted January 23, 2010 Report Posted January 23, 2010 Finally got the universal plug adapter today so I could listen to my ET1000, only to find there's a fucking channel imbalance. There's a number of issues it could be, like it not being charged up or possibly the little bit of fabric damping in the front (the side with less volume has it while the other side is partially removed). Could be the adapter too. Sigh, I wish I didn't have to troubleshoot almost every single pair of headphones I've gotten. Sounds like an SR-X mk3 on uber steroids, though. Fark, that sucks. With the issues I had with the pair I owned, I have to admit to being a bit leery of picking up a pair again if the opportunity presents, though they definitely have a certain appeal to them. SR-X on steroids though, that does sound promising. Be curious to hear them, and the SR-X Pros if you ever get those built. Quote
mypasswordis Posted January 23, 2010 Report Posted January 23, 2010 It has improved a lot over the last two or so hours, and is now barely perceptible (I'd guess ~1dB?). I'm gonna run them in for a bit longer but I'm thinking it is the fabric damping issue and I will cut a hole in the other side to match to see if that's the problem. I'm going to use the cliched bumblebee analogy in describing its speed... it doesn't know it can't go that fast, which is how it does. Really really fast. Listening to 15 Steps (Radiohead) and The Creator Has a Mastertape (Porcupine Tree) is an experience. It is slightly bright so you may not like it too much. And yes, once I find my stash of WPI jacks and plugs I will make the SR-X Pro and let you know. I'll look again today, but some places in my house are quite a bit of a mess. Quote
cetoole Posted January 23, 2010 Report Posted January 23, 2010 Excellent. Brighter than the K1000? Also, couldnt you just remove the center pin of the stock cable and short it to the correct bias pin for the SR-X? Quote
mypasswordis Posted January 23, 2010 Report Posted January 23, 2010 Yeah a bit brighter. I was afraid the stock wires in the SR-X cable couldn't handle pro bias, do you think they can? Quote
cetoole Posted January 23, 2010 Report Posted January 23, 2010 Actually, thats a good question, and I have no idea. What cable had you been planning to use? Quote
spritzer Posted January 23, 2010 Report Posted January 23, 2010 (edited) Some headphones which I've sold have worked just fine here but had channel imbalance when they arrived. Conditions they see in shipping sure plays a part here. Just run them in some more and the bias supply should overcome the parasitic charge. Yeah a bit brighter. I was afraid the stock wires in the SR-X cable couldn't handle pro bias, do you think they can? I've used them at Pro bias on quite a few sets with no issues. Stax also used the same cable (same internal wires too) on the SR-X Pro so it should be just fine. The way I did it was to cut the strain relief free from the plug and pull it higher up on the cable. Cut a small opening in the cable sheath and find the middle bias wire and combine it with the 5 pin bias wire. Slide the strain relief back into place, secure with glue and drill out the center pin. Very fiddly job though... Edited January 23, 2010 by spritzer Quote
mypasswordis Posted January 23, 2010 Report Posted January 23, 2010 Cool, I'll just use the stock cable then. I was planning on using the ESP950 cable Marc very kindly sent me. Time to figure out the fiddliness... and put in Birgir's pro bias board. Quote
mypasswordis Posted January 25, 2010 Report Posted January 25, 2010 I ripped off the pads from my Philips electret headphones since the drivers are fubar anyway and put them on the ET1000. Circumaural goodness. Next step is to remove some of the stock damping. Birgir, when you had one, did you experiment with playing around with damping? It's definitely overdamped for me, too fast and too bright. In other news, it seems I have made AmanGeorge a full-on Stax convert! He's the one who bought the SR-Lambda + SRM-1 Mk2 from me, and he prefers it to the HD800. So suck it, dynamics! A 30 year old headphone beat the best of the current production headphones. Long live planars! Quote
cetoole Posted January 25, 2010 Report Posted January 25, 2010 Wow, too fast and bright? Is there content below 1khz? Also, did I hear a rumor about you snagging a Lambda Sig? Quote
mypasswordis Posted January 25, 2010 Report Posted January 25, 2010 Is there content below 1khz? Ouch, that hurts, man. I just ripped out the stock damping. Much nicer now imo. I may put back just a thin layer of craft felt or something since I'm pretty sure there's a reason they put that thick layer of cotton there in the first place. Hm, did you? It's why I sold my SR-Lambda, a Lambda for a Lambda since I wasn't supposed to buy anything and felt super guilty. It has a couple of issues that need addressing though... originally I was just going to use it for parts. I might still, actually. Quote
AmanGeorge Posted January 25, 2010 Report Posted January 25, 2010 In other news, it seems I have made AmanGeorge a full-on Stax convert! He's the one who bought the SR-Lambda + SRM-1 Mk2 from me, and he prefers it to the HD800. So suck it, dynamics! A 30 year old headphone beat the best of the current production headphones. Long live planars! Heh, it's true - many thanks, Justin, for the conversion. The Sennheiser is on the selling block now. I'm going to miss the phenomenal soundstage, which I don't get with the Lambdas, but I'm spending so much more time with the Lambdas these days that I can't justify hanging onto the Senns. I think I'm going to see if I can get my hands on one of the last few 404LEs with some of the HD800 money. Quote
mypasswordis Posted January 25, 2010 Report Posted January 25, 2010 Glad to convert you. Now starts your long and expensive journey into the world of 'stats. If you want to try a 'stat with soundstage I should mod my Jecklin Float 'stats in the next couple of weeks for you to hear. But the Lambda soundstage isn't by any means small. The 404LE should sound really good and I'd be very interested in your comparing the two. Quote
spritzer Posted January 25, 2010 Report Posted January 25, 2010 He just needs a Sigma for some soundstage goodness (and ridicule of friends and family) Quote
mypasswordis Posted January 25, 2010 Report Posted January 25, 2010 True, any of the Sigmas will also work. I sometimes pretend I'm Magneto when I'm wearing the Jecklins, otherwise I would have gone completely off the deep end by now. Quote
AmanGeorge Posted January 25, 2010 Report Posted January 25, 2010 I'll have to check out the Sigmas sometime. The Lambdas to my ear have outstanding soundstage depth, but they're not quite as wide or airy as, say, an HD800 or a K701 (or even my CD3K). Quote
Hopstretch Posted January 25, 2010 Report Posted January 25, 2010 I've been listening to the Lambda Pros this afternoon with the 007t and I like them quite a bit. Quote
mypasswordis Posted January 25, 2010 Report Posted January 25, 2010 I like them too. At some point in time I will have the full set of original Lambdas (normal bias, pro, and sig), that I shall dub the holy troika. Quote
