bjarnetv Posted August 17, 2009 Report Posted August 17, 2009 How long does EIFL typically take to send a reply? I was completely ignored the last time I asked for an O2 cable :/ i sent around 5 emails to them last year... they still havent replied
The Monkey Posted August 17, 2009 Report Posted August 17, 2009 EIFL and Yama's both do not reply to my emails.
Tachikoma Posted August 17, 2009 Report Posted August 17, 2009 They've replied on my second try. Did you try to contact them via that form they had on their website, or through [email protected]?
bjarnetv Posted August 17, 2009 Report Posted August 17, 2009 They've replied on my second try. Did you try to contact them via that form they had on their website, or through [email protected]? i tried both, but this was a year ago, so things might have changed for the better.
Elephas Posted August 17, 2009 Report Posted August 17, 2009 okay, I was just curious and knew that it had to be just placebo from having the volume pot cranked up higher. Its hard to gauge these things when the amp starts to solidify images past 9 o'clock. Shows how important a difference in volume can make when listening or comparing equipment. It also shows how much I need a BH, lol:p You can mitigate the effect of different volume levels by listening and comparing several times, switching back and forth at varying volume levels. Compare A at a higher volume versus B and then switch around, B at a higher volume than A. Then try to volume match. Then compare both at low volume, both at high, etc. Yay, Team Blue Hawaii!
GPH Posted August 18, 2009 Report Posted August 18, 2009 AudiogoN ForSale: Stax DMA-X2 Current bid at 8550$ First time I see these on sale, seems like they're the T2 of Stax monoblocks...
spritzer Posted August 18, 2009 Report Posted August 18, 2009 It's a shame that the amps have been butchered like that. The caps are old so they have to go but why on earth would they swap out the transistors?
bjarnetv Posted August 18, 2009 Report Posted August 18, 2009 It's a shame that the amps have been butchered like that. The caps are old so they have to go but why on earth would they swap out the transistors? further down he writes: Of course I have thought about You Audiophiles, whom swear to complete Originality. I have therefore had my specialist Roar Malmin measure every single of the old Transistors and thus saved all the ones, which measured within the normal spectre of these types of transistors. This came to exactly ONE set of transistors for ONE Amp
spritzer Posted August 18, 2009 Report Posted August 18, 2009 I don't buy it for a second. This all smells of the usual audiophile nervosa crap...
Voltron Posted August 19, 2009 Report Posted August 19, 2009 I am curious about the extension cable I just got with my SR-Omega purchase because it is round like a power cable and the female end has 6 holes like the Normal bias plug but the male end is just a 5 pin Pro bias plug. So what is the deal with that? Older version, obviously, but why the two different ends?
n_maher Posted August 19, 2009 Report Posted August 19, 2009 I am curious about the extension cable I just got with my SR-Omega purchase because it is round like a power cable and the female end has 6 holes like the Normal bias plug but the male end is just a 5 pin Pro bias plug. So what is the deal with that? Older version, obviously, but why the two different ends? I believe what you have is this, right? And the reason for the 6-pin jack is that it was what they had. A horrible idea really since it would allow you to plug any normal bias can accidentally into a pro bias jack.
padam Posted August 19, 2009 Report Posted August 19, 2009 You can use both normal bias and pro bias phones with it but you can kill a normal bias phone as well, if you plug it into a pro bias socket. It is probably not a wide PC-OCC just the normal one so - in theory - it should degrade the SQ a bit unlike the current extension cables.
justin Posted August 19, 2009 Report Posted August 19, 2009 further down he writes: Of course I have thought about You Audiophiles, whom swear to complete Originality. I have therefore had my specialist Roar Malmin measure every single of the old Transistors and thus saved all the ones, which measured within the normal spectre of these types of transistors. This came to exactly ONE set of transistors for ONE Amp I would trust any specialist named Roar.
spritzer Posted August 19, 2009 Report Posted August 19, 2009 If it is brown then you have the SRE-15n which does have have PC-OCC conductors and is a very nice cable. The reason for the different connectors on each end is simple, make one extension that fits both types of bias since Stax was selling NB phones until 1990 at least. This does mean you can plug the NB phones into a Pro outlet...
Voltron Posted August 19, 2009 Report Posted August 19, 2009 I believe what you have is this, right? And the reason for the 6-pin jack is that it was what they had. A horrible idea really since it would allow you to plug any normal bias can accidentally into a pro bias jack. That's it! Thanks Nate, and thanks for the assist, Birgir. Padam, you are covered in failed, but thanks for trying.
spritzer Posted August 19, 2009 Report Posted August 19, 2009 That's the PC-OCC model and Nate is wrong, they had had 5 pin Stax sockets for at least 6 years when this cable was introduced. I bought one of these new with my first SR-007 back in 2003 and they still had the 6-pin socket.
John Buchanan Posted August 20, 2009 Report Posted August 20, 2009 I've got 2 of these round cables (one from Spritzer) - take care when plugging normal bias phones in that you don't accidentally use the pro socket on an amp. I did that once with the normal bias Sigmas - lots of squealing resulted, but no audible damage as far as I could tell.
n_maher Posted August 20, 2009 Report Posted August 20, 2009 Not sure how I'm wrong since the cable picture is at least close enough to what Al has as to descriptively work. Bottom line, do yourself a favor Al and find a way to close the center hole in the 6-pin socket and save yourself or someone else an expensive mistake.
luvdunhill Posted August 20, 2009 Report Posted August 20, 2009 Not sure how I'm wrong Spritzer was trying to clarify the fact that at that time this cable was made, Stax had already introduced the 5-pin jack. I think we both intrepreted your comment "And the reason for the 6-pin jack is that it was what they had" as meaning that Stax only had 6-pin jacks and the 5-pin jack didn't exist yet.
norfolk Posted August 20, 2009 Report Posted August 20, 2009 F.S. Stax SR-404/SRM-006t ? Stax noob..How's this setup?
spritzer Posted August 20, 2009 Report Posted August 20, 2009 Spritzer was trying to clarify the fact that at that time this cable was made, Stax had already introduced the 5-pin jack. I think we both intrepreted your comment "And the reason for the 6-pin jack is that it was what they had" as meaning that Stax only had 6-pin jacks and the 5-pin jack didn't exist yet. Yup F.S. Stax SR-404/SRM-006t ? Stax noob..How's this setup? You can do better for the price. A SRM-T1/Lambda Signature combo can be found for that price.
Voltron Posted August 20, 2009 Report Posted August 20, 2009 I think you both were reading too much into what Nate said yesterday, but I don't think it is all that relevant in any event. I don't have any normal bias stats, so using that cable won't be a problem for me.
drp Posted August 20, 2009 Report Posted August 20, 2009 I think they need to duke it out. In one corner we have Spritzer with a light saber constructed of huge (charged) capacitors glued together, and in the other corner, Nate with a some sort of custom octopus extension (like the good doctor in Hellraiser2) covered with hole saws and drill bits, driven with a cordless drill. It will be a battle of epic proportions! Okay; sorry, I likey the si-fi.... 8~)
luvdunhill Posted August 20, 2009 Report Posted August 20, 2009 I don't have any normal bias stats, so using that cable won't be a problem for me. excellent then. Perfect for sabotaging other peoples 'stats at meets!
