The Headcase Stax thread
  • Replies 14.4k
  • Views 3.5m
  • bwck2000
    bwck2000
    Arrived yesterday and it really opens up every electrostatic headphone that I own. I was looking for an amp that can bring more bass out of my HE90 than HEV90 so I drained my pocket to bid on this and
  • I have been getting back at this..working up to a limited run of these as the STAX SR-X9000 and Audeze CRBN have made that need to happen. But the chassis is extraordinarily expensive and difficult to
  • Isn't everybody glad that I'm crazy enough to buy this stuff and have Kevin rip it apart?
How long do/did your ESP950 drivers take to charge up to full volume with Stax and Koss amps?
Instantly, but IMO it always sounds best with a little warm-up of the amp.
I get full volume out of the ESP/950 using either the E/90 or the SRM-1/mk2 about a second after I hit the power switch.
The diaphragm should charge up instantly or there is something wrong. Amp warm up is another matter though.
Electrostatics that haven't been used for many years take longer to charge up, though. My SR-5NB took about 15 seconds when I first got it, now it takes about one.
I still don't know what the hell is going on with my ESP10, though. spritzer, if the channels are reversed when I fool around with balance control does that mean I wired it wrong? Could it just be that the foam inside disintegrated and is shorting things?
Well, I mentioned previously to Spritzer after I got them that the APS modded ESP950 he sold me take 2-3 minutes to fully charge, and for the first 4-5 seconds the are silent. Both drivers charge equally slow, and after several minutes they are both loud and strong and normal volume. No imbalance, but none of my other stats take minutes to charge, and they've been like this for as long as I've had them.
I'm afraid to send them to Koss because I worry they will undo the APS cable and dampening mods.
Does Accutech ever respond to emails?
They did for me in May when I was asking them how much an arc assembly would cost.
I wanted it for my SR-Lambda, so it was for the SR-202 arc assembly. They said the SR-303/404 arc assemblies are more expensive. Here is their first email response to me:
Hi Justin,
Thank you for your inquiry and your support of STAX audio products.
The original SR-Lambda arc headband assembly has been discontinued and substitute are available and they are $100 for the assembly.
Please contact us at 310-324-7406 to provide payment information or please fill out the attached credit card form and fax back to 310-324-7422.
Should you have any questions, please contact us again.
Best Regards,
YEI / ACCUTECH
Yama's Enterprises, Inc. Importers of Fine Audio products
Here is their second:
Hi Justin,
The substitute replace part would be from SR-202, the only black color headband available. Other colors (olive green & brown) are available and slightly higher in price.
The newer assembly
Can you show me how you wired it? It's been well over a year but I'm certain that the stock Koss cable can't be rewired for Stax duty without cutting off the plug.
I would remove the foam and replace it with anything you have handy. The major damping is done by the felt pads at the back of the driver. You could also swap the foam for wool and line the crappy enclosure with bitumen. :)
Justin posted an update on his Web site today - 3 weeks until the first BHSEs ship! And he posted more pics here: HeadAmp - Audio Electronics (Blue Hawaii SE Electrostatic Headphone Amp)
Brilliant news to say the least!!!
I finally figured out what I wired incorrectly. I swapped the bottom two wires, bias and R- or something.:palm:
I'm definitely with you on the crappy enclosure.:o Everything sounds like I'm in a cave. It's even worse than a stock K340 with cotton removed. I took out the disintegrating crappy foam because every time I opened the cups up more of it broke off. I'm going to upgrade the caps later on top of redamping or whatever it is I need to do.
I think I might be dumber than I thought, which is not a surprise. The channels are still reversed. At least there isn't any distortion... everything still sounds cavernous, though.
What's the going price of the Normal-bias SR-Lambda (by itself) these days? I did some Google (and HF) searching but didn't turn up anything other than a general ballpark of somewhere <$200.
I had an opportunity to pick up a working pair of F81s for similar price and did not as I did not like how they sound.
If you don't mind, how did they sound? Stax speakers intrigue me.
Anyone ever modify a SRM-1/mk2 for 620v bias, or even sketch out a schematic for the stock bias supply?
I think I may have a schematic somewhere.. I'll check tonite.
