The Headcase Stax thread
  • Replies 14.4k
  • Views 3.4m
  • bwck2000
    bwck2000
    Arrived yesterday and it really opens up every electrostatic headphone that I own. I was looking for an amp that can bring more bass out of my HE90 than HEV90 so I drained my pocket to bid on this and
  • I have been getting back at this..working up to a limited run of these as the STAX SR-X9000 and Audeze CRBN have made that need to happen. But the chassis is extraordinarily expensive and difficult to
  • Isn't everybody glad that I'm crazy enough to buy this stuff and have Kevin rip it apart?
But it does work as a replacement, correct?
All the dimensions are identical but you have to remove the metal inserts on the cups since the pins are much larger on the new forks if you are going to replace the whole arc assembly.
You could, in theory at least, use the old forks with the new arc. They are just held in place with a single screw on each side but I've never tried to do this. Is your old arc broken?
As for the Jade... they are growing on me after the mods. They are still abnormally forward which and have weird tonality which is probably due to the membrane and I don't want to swap that out. The midrange is very nice though there is something that's bothering me. I can't quite put my finger on it but there appears to be a mild texture on all voices. The bass is more subdued and better controlled but more like the Lambdas then the Omegas.
I could try to damp the drivers somewhat but the less times I open up the housing the better as the lead wires on the drivers could break and that would be a PITA to fix... :o
Did you try to dampen them mineral wool ala Lambda Pro? That could even out the FR and subdue vibrations and reflections that could be causing this strange coloration.
Nope I didn't try that. I was going to try air damping them via solid mylar dust covers but the drivers can't take being handled too much so I dropped the idea.
Spritzer,
When you described the jades initially before mods, you stated that they displayed a very 2d image, lacking depth.
Now, i've never heard a really highend speaker setup. But everytime i listen to speakers, i notice their uncanny ability to portray depth because of their actual ability to produce sound over a large area of actual space(compared to headphones)
Speakers---------------------------------------->Ears
Headphones---->Ears
(arrows being actual space between the transducer and ears)
This space that speakers have, allow instruments and voices to sort of "sail" across, which give music incredible energy and realism to me.
But high end headphones have given me this amazing feeling of depth "extension" within its housings, to the same degree as speakers but far more focused than any speakers i've listened to. Which is why i love the O2s so damn much.
Just wanted to know if you know why the jades, lacked this ability initially, and if this is more of a design issue of the headphone, or an issue that can be remedied with a better source perhaps.
These fucking 007 pads are going to drive me out of my goddamn mind. I can't get them on. Fuck. Someone give me a clue. I can get them over the spring, but it is impossible to get them to bite over the black inner ring (if that makes a bit of sense to anyone).
Also, I stripped one of the fucking screws that holds in the headband so I can't get it out. Any suggestions about how to deal with THAT nightmare?
Fuck.
I used a cheap (thin) butterknife to get the pads back on. It is tricky, but just requires a steady hand (fingers to grip each bit that goes back in as you feed more through) and patience. Once you've got more than half back under the rim you can gently rotate the pad to help the rest.
I've never removed the headband so I can't offer any help there I'm afraid. Perhaps some kind of putty, fill the stripped hole and when it hardens drive the screw into it creating a new thread.
Thanks Doug. Got the pads on. Can you remind me what the "default" orientation is for the pads? In other words, the pad is shaped like a "D." In which direction is the "D" supposed to be facing by default?
Also, is it ok that I can see some of the outline of the spring through the pad?
Also, I wasn't clear, it's the head of the screw that I stripped, not the thread itself. I guess the putty idea still applies, right?
Use the seam to help you position them. The straight part of the D should be behind and slightly below your ears.
I have the seam closer to horizontal than angled up, when my hair was longer the opposite was true. It's much dependent on your head and how you manipulate the arc.
Thanks Doug.
Gang, this screw is going to be tough to get out. It's one of the pair of very small screws that attaches the arc/headband assembly through the brown plastic of the assembly to the metal ear cups. They are phillips head and they are small. And now I've managed to strip one of the heads. Any thoughts about how to get it out? I am not too keen on the thought of drilling it out given its proximity to, well, everything.
Buy throwaway screwdriver and krazy glue to the screw? (I can't take responsibility for this completely untested unverified unprofessional idea)
Ah the screw head is fubar, i thought the hole was. I also would use glue, but a replacement screw would be the best thing. Stax will probably ask $40 for a set of 4. ;D
The portrayal of soundstage depth and over all size has a lot to do with how the drivers utilize the ear or rather how they are positioned in relation to the ear. The housing also plays a large part so I don't think that a better source helps in this regard.
Thanks Doug.
There are special screwdrivers you can buy which have sharp tips that actually cut into the metal and are meant for removing screws where the head is stripped. I think they are called screw extractors, but you may want to look into getting one of these. No idea where the screw is on the O2, but depending on location, you may be able to get it out with vice grips too.
It's next to the two metal arcs and it secures the headband. I would just drill it out and then use a wisegrip to remove the stub.
