spritzer Posted September 13, 2015 Report Posted September 13, 2015 The AC in your house could be causing that or the transformer just has a bit of hum. Some do, some don't. 1
dripf Posted September 13, 2015 Report Posted September 13, 2015 The AC in your house could be causing that or the transformer just has a bit of hum. Some do, some don't. Thanks spritzer. It used to be silent but at this point must go under the desk.
spritzer Posted September 14, 2015 Report Posted September 14, 2015 Did you add any new stuff to that mains wiring? Computers, chargers, that type of thing? They could be causing the hum.
dripf Posted September 14, 2015 Report Posted September 14, 2015 (edited) Did you add any new stuff to that mains wiring? Computers, chargers, that type of thing? They could be causing the hum. There's a new line interactive UPS for a PC that is sharing the same circuit. However, that video was made from a different room which may or may not be in the same circuit as the office. I'll try a mass unplugging of devices including the UPS. Edit: No joy I'm afraid Edited September 14, 2015 by dripf
spritzer Posted September 14, 2015 Report Posted September 14, 2015 I really don't see any other reason why the transformer would suddenly start to misbehave unless it is simply failing. I take it is set to the correct voltage and not say a 100V unit plugged into 117V or something like that? Polarity of the mains can also be a factor if the plug is reversible.
dripf Posted September 14, 2015 Report Posted September 14, 2015 The 323S is PJ sourced and powered by a 240-100 V transformer. I asked on H-F and the one respondent thought it was a case of delamination that was benign. 1
n3rdling Posted September 15, 2015 Report Posted September 15, 2015 (edited) Doesn't Stax put a sticky rubber dampener between the transformer and chassis to minimize noise? Maybe it came loose. Edited September 15, 2015 by n3rdling
nopants Posted September 16, 2015 Report Posted September 16, 2015 009 take on the lamda driver? maybe it'll help some of the low end
Hennyo Posted September 16, 2015 Report Posted September 16, 2015 (edited) Now somebody is speaking the right language. Interesting, Isn't that funny, Sr 50"8" Edited September 16, 2015 by Hennyo
chinsettawong Posted September 16, 2015 Report Posted September 16, 2015 Those look a lot like wire mesh stators.
nopants Posted September 16, 2015 Report Posted September 16, 2015 I thought that's what the 009 did under the hoodhopefully only 1k or so for a pair, somewhere between the 507 and omega
chinsettawong Posted September 16, 2015 Report Posted September 16, 2015 I can try to make a pair to see the difference. 2
spritzer Posted September 16, 2015 Report Posted September 16, 2015 The problem with the Lambda has never been the drivers but the housing. We'll see if they ever change that...
Ali-Pacha Posted September 16, 2015 Report Posted September 16, 2015 Here's a link to a picture of the SRD7SB Prohttp://stereonomono.blogspot.com/2014_09_01_archive.htmlNope. SRD-7/SBmk2, and AC-Powered SRD-7 Pro.Ali
Ali-Pacha Posted September 16, 2015 Report Posted September 16, 2015 The problem with the Lambda has never been the drivers but the housing. We'll see if they ever change that...Lambda drivers + Orpheus housing, for instance ? Ali
catscratch Posted September 16, 2015 Report Posted September 16, 2015 I would like a Lambda that doesn't suck, mainly for more casual listening than the 007. The 007 is great but the finnicky fit and comfort aren't ideal. If I can get a Lambda that isn't brighter than a bus full of MIT students and still has that airy open thing going on that would be great. Also provided it doesn't cost an arm and a leg.
spritzer Posted September 16, 2015 Report Posted September 16, 2015 Lambda drivers + Orpheus housing, for instance ? AliYup.
DefQon Posted September 16, 2015 Report Posted September 16, 2015 (edited) It'd be a long time before we actually see a production release of a specific model. They had a new amp at one of the Tokyo shows 3 years ago and no word of it since. Edited September 16, 2015 by DefQon
Ali-Pacha Posted September 17, 2015 Report Posted September 17, 2015 Looks like a "basic" stiffening of the stators, they could easily stick that in a SR-507 housing and call it SR-509. I say "basic", but maybe some wachara-level dude would tell I've no clue about it Ali
4tray Posted September 19, 2015 Report Posted September 19, 2015 (edited) This is a ridiculous post i know. But after lots of electrostatic listenening I can't stand to hear normal speakers anymore. They're too boring and I need to take a break.Somehow this doesn't happen with the SR-X MKIII. I just really enjoy listening to them. I put velour pads on my SR-X MKIII and I can happily listen to them all day long now.I just wish I could find a way to make my speaker cables sit in the shitty SRD-7 wire terminal easier. A speaker wire falls out on occasion. I'm absolutely not going to be one of those people who chops off the cable receptacle...Anyone who has a SRD-7/SB they don't want should let me know, It would be nice to have one without a power cord Hands down I'll take a SR-X MK III and SRD-7 over any other Stax I've heard to date... Edit: Finally worked up the courage to wash off the headband with a damp cloth with shampoo and another damp cloth to wipe away leftover soap. Yeesh, glad I did. These headphones really showed their age on that paper towel Edited September 19, 2015 by 4tray
ericfarrell85 Posted September 19, 2015 Report Posted September 19, 2015 (edited) Given a choice between an original BH and KGST (400v if it makes much of a difference) is there any consensus on which would play best with the 007/009, SR-Ω & HE60? Hard enough to find someone who has heard one of the dozen or so Headamp BH's out there, let alone a comparison with any of the subsequent KG amps. Edited September 19, 2015 by ericfarrell85
ericfarrell85 Posted September 20, 2015 Report Posted September 20, 2015 DIY T2Pipe-dreaming is the closest I'll get to a T2 (that or if Andy decides he doesn't like his any more). BH and KGST/HV seem to be the only procurable options.
nopants Posted September 20, 2015 Report Posted September 20, 2015 nothing wrong with the kgst to cover the 009 corner case you'd probably need to audition that on the bh to compare
