spritzer Posted March 11, 2015 Report Share Posted March 11, 2015 They would probably sell a lot more of them if they fixed that... Quote Link to comment Share on other sites More sharing options...
meeskees Posted March 11, 2015 Report Share Posted March 11, 2015 My mistake, I didn't see it listed when I tried to filter all stax products It is the Korean version.You have to look at the self price quote. Look also at the kakaku site for prices. Quote Link to comment Share on other sites More sharing options...
nopants Posted March 11, 2015 Report Share Posted March 11, 2015 (edited) more like I need to stop looking at the self price quote so I don't end up buying it Birgir can you comment on the build issues? Are there any which may affect the longevity a la mk1 cable strain relief? Edited March 11, 2015 by nopants Quote Link to comment Share on other sites More sharing options...
Duffer Posted March 11, 2015 Report Share Posted March 11, 2015 The lego is very fitting... There are copper pins that hold them together. Pull them out and the drivers open up. Watch out for the front stator wire which is very easy to break. Yup, 1600$ isn't bad at all. Edit: As for the sound, I still like it a lot. I know I'll have to change the springs and move the earpads to the Mk1 position eventually but I'm digging the extra harmonics in the bass region. It's easy enough to move press the cups towards the head to hear how they should sound. Thanks Spritzer, I did tug vaguely at those pins but they didn't seem overly willing to come out. Now I know they're the key I'm pull with more confidence. Cheers Quote Link to comment Share on other sites More sharing options...
Ali-Pacha Posted March 11, 2015 Report Share Posted March 11, 2015 I've a pair of SR-5/NB which have developped strong imbalance...I may end up with this kind of solution/try, unless I find some spare drivers... Ali Quote Link to comment Share on other sites More sharing options...
DefQon Posted March 11, 2015 Report Share Posted March 11, 2015 You can easily fix the imbalance issues assuming the mylar membrane has seen too much sun light resulting in a complete sag like the pictures I posted Duffer quoted. To remove the 4 bronze pins don't use a flat head screw driver you`re going to be putting to much pressure and may end up cracking the plastic housing. Use a thin, sturdy but sharp Stanley or kitchen cutting knife and carefully pry it open with the sharp side in between the head of the pin and the plastic housing. Quote Link to comment Share on other sites More sharing options...
nopants Posted March 12, 2015 Report Share Posted March 12, 2015 trying out my 009 with Marc's bh and a vintage analog research segue dac. I like what I'm hearing, not perceiving as much brightness as I remember Quote Link to comment Share on other sites More sharing options...
HemiSam Posted March 12, 2015 Report Share Posted March 12, 2015 trying out my 009 with Marc's bh and a vintage analog research segue dac. I like what I'm hearing, not perceiving as much brightness as I remember That smacks of wickedness....I'm jealous. KGST should land shortly as it's now in TX and I'll see what she brings. HS Quote Link to comment Share on other sites More sharing options...
spritzer Posted March 12, 2015 Report Share Posted March 12, 2015 more like I need to stop looking at the self price quote so I don't end up buying it Birgir can you comment on the build issues? Are there any which may affect the longevity a la mk1 cable strain relief? No build issues I can see. Stax have learned their lessons on the older 007's. That smacks of wickedness....I'm jealous. KGST should land shortly as it's now in TX and I'll see what she brings. HS To quote an email I got this morning: On the SR-009 and the KGSSHV, it sounds very nice, but the emotion and energy just don’t get through. But when the 009 is paired with the KGST, I just want to dance on my desk again! The instruments have regained some meat, and that diffuseness is mostly gone. A lush 009, it’s a miracle! 'nuff said. 1 Quote Link to comment Share on other sites More sharing options...
Duffer Posted March 12, 2015 Report Share Posted March 12, 2015 You can easily fix the imbalance issues assuming the mylar membrane has seen too much sun light resulting in a complete sag like the pictures I posted Duffer quoted. To remove the 4 bronze pins don't use a flat head screw driver you`re going to be putting to much pressure and may end up cracking the plastic housing. Use a thin, sturdy but sharp Stanley or kitchen cutting knife and carefully pry it open with the sharp side in between the head of the pin and the plastic housing. Thanks Spritzer for all your advice. The job's now done and my SR3s are sounding beautifully balanced and as wonderfully clear as ever they were. Much appreciated. Quote Link to comment Share on other sites More sharing options...
DefQon Posted March 12, 2015 Report Share Posted March 12, 2015 Glad it worked out for you. Quote Link to comment Share on other sites More sharing options...
Ali-Pacha Posted March 12, 2015 Report Share Posted March 12, 2015 (edited) You can easily fix the imbalance issues assuming the mylar membrane has seen too much sun light resulting in a complete sag like the pictures I posted Duffer quoted. To remove the 4 bronze pins don't use a flat head screw driver you`re going to be putting to much pressure and may end up cracking the plastic housing. Use a thin, sturdy but sharp Stanley or kitchen cutting knife and carefully pry it open with the sharp side in between the head of the pin and the plastic housing. The 4 bronze pins are small screws on SR-X, right ? First, cup opening, then unscrew those 4 ones which are inside the plastic housing of the driver...and what's next ? I assume I have to remove the metal-ringed dust cover (ear-side), but don't know how Edit : forget it, understood now. Carefully disassembled, driver is fine, carefully re-assembled, sound is still the same (with imbalance), I've made no mistakes. Gonna get some antistatic solution tomorrow for recoating. Ali Edited March 12, 2015 by Ali-Pacha Quote Link to comment Share on other sites More sharing options...
DefQon Posted March 13, 2015 Report Share Posted March 13, 2015 Yeah make sure when you're applying the antistatic goop don't apply too much pressure this stretches out the mylar (which you can re-tension using a heat gun but not back to Stax spec's). Use the least amount of pressure possible and evenly spread it out, let it dry then install the spacer back in otherwise the surface is still wet and sticks to the stator. You need to coat both sides. Quote Link to comment Share on other sites More sharing options...
eggil Posted March 13, 2015 Report Share Posted March 13, 2015 The 009 sounds better with the Megatron than KGSSHV. With the latter sound is leaner. Megatron sounds fuller with better bass. Both are good, but Megatron is gooder. 1 Quote Link to comment Share on other sites More sharing options...
Ali-Pacha Posted March 13, 2015 Report Share Posted March 13, 2015 Yeah make sure when you're applying the antistatic goop don't apply too much pressure this stretches out the mylar (which you can re-tension using a heat gun but not back to Stax spec's). Use the least amount of pressure possible and evenly spread it out, let it dry then install the spacer back in otherwise the surface is still wet and sticks to the stator. You need to coat both sides. Any antistatic spray / gel will do ? I'll be unable to find the floor cleaner Wachara uses..I'm not in Thailand Ali Quote Link to comment Share on other sites More sharing options...
Hun7er Posted March 13, 2015 Report Share Posted March 13, 2015 The 009 sounds better with the Megatron than KGSSHV. With the latter sound is leaner. Megatron sounds fuller with better bass. Both are good, but Megatron is gooder. Interesting ! Did somebody planned to sell an Megatron ? Quote Link to comment Share on other sites More sharing options...
DefQon Posted March 13, 2015 Report Share Posted March 13, 2015 Any antistatic spray / gel will do ? I'll be unable to find the floor cleaner Wachara uses..I'm not in Thailand Ali Any computer screen/lcd cleaner gel. I don't use the spray only the gel which stays on forever. Or you can buy some Staticide liquid solution which will be a permanent fix. Quote Link to comment Share on other sites More sharing options...
Ali-Pacha Posted March 13, 2015 Report Share Posted March 13, 2015 Thank you DefQon, I'll try this evening or tomorrow. Ali Quote Link to comment Share on other sites More sharing options...
DolphinG Posted March 13, 2015 Report Share Posted March 13, 2015 Hello I recently acquired a pair of SR-1. It's fully working with its original driver, but does not have earpads. I wonder if SR-3/5 pad would work for it. (Once I saw a SR-1 with SR-3 pad) is there anyone who can help me with this problem? Quote Link to comment Share on other sites More sharing options...
spritzer Posted March 13, 2015 Report Share Posted March 13, 2015 Interesting ! Did somebody planned to sell an Megatron ? I will build a few this year after I sort out the PSU. It will serve as a stepping stone for the T2 project, testing some new ideas. Quote Link to comment Share on other sites More sharing options...
spritzer Posted March 13, 2015 Report Share Posted March 13, 2015 SR-3 pads will work but the SR-1 never shipped with those pads. I used the Brainwavez HM5 pads on mine as they are close to the original shape. Quote Link to comment Share on other sites More sharing options...
Duffer Posted March 13, 2015 Report Share Posted March 13, 2015 Glad it worked out for you. Looks like celebrations might have been a bit too precipitous. After leaving the SR3's on for 24hrs they reverted back to their old state after 10mins of listening this afternoon. They were fine to begin with. Was it a big mistake to use anti-static liquid instead of gel do you suppose, or might something more fundamental be amiss. D Quote Link to comment Share on other sites More sharing options...
DolphinG Posted March 13, 2015 Report Share Posted March 13, 2015 SR-3 pads will work but the SR-1 never shipped with those pads. I used the Brainwavez HM5 pads on mine as they are close to the original shape. Well, do you think that I should get Brainwavez HM5 earpad? Or is it OK to use SR-3 pad? I also am thinking about get a SR-3 to replace some parts of SR-1, so how do you think about it? Quote Link to comment Share on other sites More sharing options...
Ali-Pacha Posted March 13, 2015 Report Share Posted March 13, 2015 (edited) Looks like celebrations might have been a bit too precipitous. After leaving the SR3's on for 24hrs they reverted back to their old state after 10mins of listening this afternoon. They were fine to begin with. Was it a big mistake to use anti-static liquid instead of gel do you suppose, or might something more fundamental be amiss. D My try with monster iClean antistatic (got it at work for free) is also a failure, no temporary improvement. I'll try something else. Ali Edited March 13, 2015 by Ali-Pacha Quote Link to comment Share on other sites More sharing options...
spritzer Posted March 13, 2015 Report Share Posted March 13, 2015 Well, do you think that I should get Brainwavez HM5 earpad? Or is it OK to use SR-3 pad? I also am thinking about get a SR-3 to replace some parts of SR-1, so how do you think about it? I'd like the pads to be a bit higher and thicker but for the price, you can't go wrong. If it is a late SR-1 then the SR-3 pads will work. Most of the parts of the late SR-1's are the same as on the SR-3's. Not so much for the early ones. Quote Link to comment Share on other sites More sharing options...
