luvdunhill Posted December 20, 2011 Report Posted December 20, 2011 Is there any sort of standard connector for DSD output (specifically 3-wire, DSDR, DSDR and DSDCLK)? I'm thinking of using a 5-pin Lemo. No way I can fit a bunch of BNC connectors either. Quote
vvs_75 Posted January 3, 2012 Report Posted January 3, 2012 Is there such thing as a male version of the socket pin above? The one you would use to make stax headpnones plug? Quote
ujamerstand Posted January 9, 2012 Report Posted January 9, 2012 (edited) Could somebody help me buy this, or suggest a similar alternative? I'd like a good-enough quality, but easy to use stereo ADC interface. The roland UA-1G seems to fit in, because it could record 24bit/96kHz audio for less than 100 dollars. Thanks! The goal is to measure a room's impulse response. Edited January 9, 2012 by ujamerstand Quote
M3NTAL Posted January 10, 2012 Report Posted January 10, 2012 Is Parts Connexion my only option for a stereo TKD pot in the United States? Quote
Pars Posted January 11, 2012 Report Posted January 11, 2012 percy audio http://www.percyaudio.com/ Quote
Shaman Posted January 13, 2012 Report Posted January 13, 2012 Hey guys, Could you please guide me to a source for good quality prototyping boards in EU/shipping to EU? Also, I have trouble finding black M3 screws at affordable prices. Any ideas are more than welcome! Quote
bhjazz Posted January 27, 2012 Report Posted January 27, 2012 A case. Just a case. I read nattonrice's comments about the modushop/hifi2000 cases, and was thinking the same thing: cold rolled steel. Meh. I do like the smaller hifi2000 Galaxy cases, but need something bigger this time, like around the size of the 3U which is 16.9 x 11.8 x 4.72. Aluminum would be best, or at least mostly aluminum. Suggestions? Quote
Pars Posted February 11, 2012 Report Posted February 11, 2012 VT4C? http://www.vt4c.com/shop/program/main.php Anyone done business with them? I have some Yarbo RCAs that I got through them via another member, but have never ordered directly from them myself. I was going to buy some knobs from them, and have sent them 2 emails (per their order instructions) but have not heard anything back from them (in 3 days). Just wondering whats up with them... I need 6 small knobs (17-19mm or 3/4") and don't feel like spending $6-$8 apiece for Kilos from Digikey for this application. They need to match as well. Chris Quote
deepak Posted February 11, 2012 Report Posted February 11, 2012 VT4C? http://www.vt4c.com/...rogram/main.php Anyone done business with them? I have some Yarbo RCAs that I got through them via another member, but have never ordered directly from them myself. I was going to buy some knobs from them, and have sent them 2 emails (per their order instructions) but have not heard anything back from them (in 3 days). Just wondering whats up with them... I need 6 small knobs (17-19mm or 3/4") and don't feel like spending $6-$8 apiece for Kilos from Digikey for this application. They need to match as well. Chris Some places will take several weeks off for Chinese New Year. Quote
n_maher Posted February 11, 2012 Author Report Posted February 11, 2012 In addition to the new year issue be aware that shipping will either take a long time or be pretty expensive. If they didn't need to mat or pairs would work I might be able to help. Quote
PICaudio Posted February 23, 2012 Report Posted February 23, 2012 Anybody know where I can acquire a 6 pin mini-DIN connector male for Panel mount?. All panel connectors that I found has female pins -- o -- Rodrigo Quote
luvdunhill Posted February 24, 2012 Report Posted February 24, 2012 Rodrigo: Check a company named Lundberg at Farnell, I think they have something. Real nice connectors, I use them on my test gear. Quote
Pars Posted February 24, 2012 Report Posted February 24, 2012 Sure it isn't Lumberg? Looking them over, they do have receptacles with male pins, but not the same form factor. Kycon has some in the same form factor, but female pins. You couldn't switch it and the plug over? Quote
luvdunhill Posted February 24, 2012 Report Posted February 24, 2012 Sure it isn't Lumberg? Looking them over, they do have receptacles with male pins, but not the same form factor. Kycon has some in the same form factor, but female pins. You couldn't switch it and the plug over? yeah, typo on my phone.There are two different DIN plug angles, it's hard to tell what that one is. They definitely have a female of both angles though. Quote
PICaudio Posted February 24, 2012 Report Posted February 24, 2012 I cannot change that type of connector for other with female contacts . I have to find another solution to this problem, if the act of designing a equipment were as easy to buy some things and throw them in a box, everything would be boring Thank you very much for your help. -- o -- Rodrigo Quote
luvdunhill Posted February 24, 2012 Report Posted February 24, 2012 I'm looking for a part. I am going to be making a bunch of discrete opamps. I need some sort of edge connector system to plug them into a main board. Ideally, for space reasons, I'd like them to be perpendicular to the main PCB, as there will be around 20 of them. Anything in particular I should look to use, other than the standard SIP connectors/sockets? Quote
bhjazz Posted February 24, 2012 Report Posted February 24, 2012 (edited) VT4C? http://www.vt4c.com/...rogram/main.php Anyone done business with them? I have some Yarbo RCAs that I got through them via another member, but have never ordered directly from them myself. I was going to buy some knobs from them, and have sent them 2 emails (per their order instructions) but have not heard anything back from them (in 3 days). Just wondering whats up with them... I need 6 small knobs (17-19mm or 3/4") and don't feel like spending $6-$8 apiece for Kilos from Digikey for this application. They need to match as well. Chris Not sure if you've heard back from them yet, but I ordered a few parts from them a couple of years back. Not fast, but not bad. they do seem to have an interesting assortment of shtuff. Partsconnexion has a decent assortment, although I wish they had some satin black 12mm items for sale. Edited February 24, 2012 by bhjazz Quote
luvdunhill Posted February 25, 2012 Report Posted February 25, 2012 Anyone know where I can get some 2sa1312 while Mouser gets their act together? Perhaps some overseas vendor and someone could pop them in the mail for me? I need about 50. Quote
ujamerstand Posted February 25, 2012 Report Posted February 25, 2012 http://www.maroon.dti.ne.jp/satodenki/2sa.html Have kuboTEN ship them to you. Or ask one of our members in japan to give you a hand? Quote
dBel84 Posted February 27, 2012 Report Posted February 27, 2012 VT4C - bought loads of things from them over the years, the process of order - email - paypal - ship works, just takes a little time. ( shipping times are not ridiculous either ) They have great customer service too. question for the masses. Is ampslab reliable? I have heard rumours of delays and difficult transactions but don't see much mention of them. ..dB Quote
luvdunhill Posted February 27, 2012 Report Posted February 27, 2012 I'm probably going to just wait for mouser. These are nice transistors, better than 2sa970/2sc2240 if you don't need the extra Pd. As far as I can tell, this is what Toshiba has slated for a replacement for the older devices. Quote
luvdunhill Posted April 18, 2012 Report Posted April 18, 2012 Best price on TKD 2511 mono 10K? I need three or so. Quote
dsavitsk Posted April 29, 2012 Report Posted April 29, 2012 Does anyone have a part # or source for the caulk like goo used to stabilize parts on a PCB? Quote
