8 hours ago, luvdunhill said:
Can anyone recommend a nice portable HD microscope to go with my new far-sightedness for soldering?
I purchased a cheap rebranded scope from amazon one a few years back for smd and pcb inspection It looks identical to this one:
https://amscope.com/collections/student-microscopes-low-power-stereo/products/se420xyz-2l
it works. My only complaints are
1. it does not have a zoom
2. its not trinocular so you can't add a camera look through it at the same time
3. there is no real X and Y adjustment. instead it pivots around which makes moving around a pcb a bit of a pain.
4. because the objective lenses are housed in a rectangular box you cant fit a ring light easily.
5. the objective lenses are not a "standard" mount and that limits you options for different lenses
Edited by jamesmking
Do you use it for inspection or for assembly?
bit of both. working distance is ok for either a hot air handle or a soldering iron.
It takes some getting used to since you have a fixed defined viewing circle, you can't move your head and have to organise everything around that.
I personally found that exact head positioning was very critical to get a good 3d perspective view and this meant I wanted to minimise the number of times I looked up away from the microscope.
3 hours ago, bbest said:
Hello all!
Now FJPF2145 obsolete on Mouser. But I need to finish my T2. Where it is possible to get or how to replace them?
What you think?
FJPF5027OTU seems to be a possibility, seems to have similar specs except lower current rating and the same pinout.
Hfe of FJPF2145 is 20 - 40 which is the same as the O variant of the 5027
all good, but output capasitance 60pF vs 11pF.
Edited by bbest
On 10/13/2024 at 4:06 PM, bbest said:
Noted that and am wondering for this application; how much does it matter when used as a current source? I don't know enough of the theory to figure that one out. Help... :) ?
  • 5 months later...
On 8/2/2023 at 10:36 AM, jokerman777 said:
Wanted to buy some FQPF8N80C seems uk rs-online only let me enter UK address, is there a way to get them ship worldwide?
Hello all!
Same question - how to replace it or where to buy?
May be something from this:
* FQP8N80C
* STP8NK80Z
* STP7NK80Z
Edited by bbest
9 hours ago, bbest said:
Hello all!
* FQP8N80C
* STP8NK80Z
* STP7NK80Z
I ended up using STP8NK80Z(FP) in place of those FQP ones and they work all good if that's what you asking? Should be available from major vendors still.
  • Thanks 1
