JoaMat Posted October 16, 2022 Report Posted October 16, 2022 (edited) If itβs ksc5026 in KGSShv style power supply you can probably use stn0216 stn0214 intstead. Solder it standing on the to126 pads (might be to220 pads on your board?). Power dissipation there is something like 40 β 60 mW, I think. Edited October 16, 2022 by JoaMat 1 Quote
bbest Posted October 16, 2022 Report Posted October 16, 2022 9 hours ago, JoaMat said: If itβs ksc5026 in KGSShv style power supply you can probably use stn0216 intstead. Solder it standing on the to126 pads (might be to220 pads on your board?). Power dissipation there is something like 40 β 60 mW, I think. you mean this one https://www.mouser.com/ProductDetail/STMicroelectronics/STN0214?qs=pmcUWs1B1IKOCzUPe9wAgg%3D%3D stn0214? So tiny Quote
JoaMat Posted October 16, 2022 Report Posted October 16, 2022 15 minutes ago, bbest said: stn0214? Yes, of course, stn0214. My mistake β I shouldn't rely on memory solely. 1 Quote
chinsettawong Posted November 11, 2022 Report Posted November 11, 2022 I've been searching for some DN2540 to fix my KGSSHV Carbon but can't find them anywhere? Do you guys know of anywhere I can get them? Or can I substitute them with the small current version in TO-92 package? Quote
Pars Posted November 11, 2022 Report Posted November 11, 2022 ChipOneStop shows some stock, not sure how trusted they are. https://octopart.com/dn2540n5-g-microchip-47153345?r=sp Quote
RonH10 Posted November 11, 2022 Report Posted November 11, 2022 I bought some from ebay last year from a German seller, that tested good. Seller was darisusgmbh. Good luck! Quote
kevin gilmore Posted November 11, 2022 Report Posted November 11, 2022 the to243 definitely work and are the same pinout. also probably out of stock. seems like the to92 versions like to blow up in some situations. Quote
simmconn Posted November 11, 2022 Report Posted November 11, 2022 Iβve been using the DN2540 in TO-92 package since my first Carbon build without any problems on the amp board. However Iβve seen two instances where the DN2540 on the GRHV developed a Drain-to-gate leakage. That caused excess current thru the HV PNP. In one case (my own build) it was caught in time and didnβt do any real damage, in the other case (someone elseβs board with a TO220 DN2540) the PCB was cooked, the ST9360 failed and brought down both the BC557s. The leakage problem is regardless of the DN2540 package. Iβm suspecting in the cascode CCS there may be a corner case where it is stressed beyond the safe limit. Quote
JoaMat Posted November 11, 2022 Report Posted November 11, 2022 Maybe DN2535 (max voltage 350V) will work. Main difference to DN2540 (max voltage 400V) seems to be the maximum voltage. In stock at Mouser for roughly the same price as DN2540. 1 Quote
sorenb Posted November 11, 2022 Report Posted November 11, 2022 2 hours ago, simmconn said: Iβve been using the DN2540 in TO-92 package since my first Carbon build without any problems on the amp board. However Iβve seen two instances where the DN2540 on the GRHV developed a Drain-to-gate leakage. That caused excess current thru the HV PNP. In one case (my own build) it was caught in time and didnβt do any real damage, in the other case (someone elseβs board with a TO220 DN2540) the PCB was cooked, the ST9360 failed and brought down both the BC557s. The leakage problem is regardless of the DN2540 package. Iβm suspecting in the cascode CCS there may be a corner case where it is stressed beyond the safe limit. did the SiC survive (someone elseβs board with a TO220 DN2540)? Quote
simmconn Posted November 11, 2022 Report Posted November 11, 2022 22 minutes ago, sorenb said: did the SiC survive (someone elseβs board with a TO220 DN2540)? The SiC did survive and still tested good all the way to 1700V on a curve tracer. I guess the ST9360 had a slow death and the BC557s gave up before more current could damage the SiC. Quote
sorenb Posted November 11, 2022 Report Posted November 11, 2022 8 minutes ago, simmconn said: The SiC did survive and still tested good all the way to 1700V on a curve tracer. I guess the ST9360 had a slow death and the BC557s gave up before more current could damage the SiC. I've seen similar. DN2540 leaking usually shows up as the output voltage of the PSU drifting. As far as I remember the supplies breaking down was all wired as negative rails. However, I have not seen it on any GRHV using the cpc1117. Quote
jamesmking Posted November 23, 2022 Report Posted November 23, 2022 mouser currently has ksa1156. radio spares has STN9360, FJPF2145TU and FQPF8N80C Quote
bbest Posted December 14, 2022 Report Posted December 14, 2022 Mouser has changed delivery date for IXCP10M90S on 08-Aug-2023. So where to buy it? Quote
jamesmking Posted December 14, 2022 Report Posted December 14, 2022 2 hours ago, bbest said: Mouser has changed delivery date for IXCP10M90S on 08-Aug-2023. So where to buy it? about the only hope is from a forum member or take chances with fakes on ebay π Quote
Pars Posted December 14, 2022 Report Posted December 14, 2022 According to Octopart, Winsource Electronics has 6300. Pricey ($22@+), not sure if they're reputable. My guess is no, but only a guess. Quote
spritzer Posted December 15, 2022 Report Posted December 15, 2022 They did suddenly show up in quantity at Mouser last time so it might happen again. I just found out about it as I had some on order and they suddenly shipped, way ahead of the set date. Quote
jamesmking Posted December 15, 2022 Report Posted December 15, 2022 (edited) pray to the deity of semiconductor manufacturing (in a reverential voice tinged with grief).... π oh Nosemi please hear our plea for our DIY hobby.... in the name of silicon please bless us with some manufacturing and fill up our inventories In the name of NPN and PNP blessed are the mosfets, depletion or enhancement for the DIYers shall inherit 10M90S and it was good Let not the ebay scammers rebrand and re-etch for they will be accountable to silicon and burn in the foundries of ixys for all eternity Let it be known Toshiba and NEC will escape Renesas Sanyo and Fairchild will rise again and return to us all for now and for evermore Ahmen. (The DIY hymn book chapter 11 covid 19 to recession 2008 verses 1-4) Edited December 15, 2022 by jamesmking 6 Quote
bbest Posted December 21, 2022 Report Posted December 21, 2022 very strange, now mouser shows for IXCP10M90S Quote 1,180 Expected 26-Apr-23 Quote
nopants Posted January 15, 2023 Report Posted January 15, 2023 You guys know any other places that sell baseplates similar to what hifi2000 has? I've used a few smaller ones and I'm pretty hooked, but shipping from Italy for the larger plates is a bit of a pain. Quote
Satyrnine Posted February 16, 2023 Report Posted February 16, 2023 Hello, new here. Hoping to build a Kevin Gilmore CFA3, and looking for a set of boards. Anyone have spares? Thanks! Quote
Pars Posted February 16, 2023 Report Posted February 16, 2023 On 1/14/2023 at 7:53 PM, nopants said: You guys know any other places that sell baseplates similar to what hifi2000 has? I've used a few smaller ones and I'm pretty hooked, but shipping from Italy for the larger plates is a bit of a pain. Does the diyaudio store have the one you want? They have US stock, so should be cheaper. Quote
nopants Posted February 17, 2023 Report Posted February 17, 2023 19 hours ago, Pars said: Does the diyaudio store have the one you want? They have US stock, so should be cheaper. Sorry I wasn't clear- that page is from the diyaudio store, when you add a few pieces to the cart they tack on like 50 dollars shipping. I'll just grab a few extras when I buy the next case from them. Quote
Pars Posted February 17, 2023 Report Posted February 17, 2023 Yes, I realized that when I looked at diya. Your screenshot was from there. I know they do have US stock on some stuff; wish they showed that more clearly. Quote
Satyrnine Posted February 18, 2023 Report Posted February 18, 2023 I'm looking to build a Gilmore CFA3 and GRLV, anyone have boards available? Also, some sand is out of stock. Does anyone have the following, or know if the following subs will be OK: CFA3: MJF15030G: Can I sub MJE15028G? It has 120v C-E voltage vs 150v of the orig, and I'd need shoulder washers/isolation washers. PZTA56 Can I sub DPLS4140E-13 ? GRLV: MJW21194G Can't find a decent sub here. Thoughts? DN2540N3-G Can I sub DN2540N3-G-P003 Seems the same. Confirmed OPA134, I assume I can sub the SMD version with an adapter board, but the SMD version is out of stock too... Other good subs? OPA228? opa228 Confirmed Transformers: These three were recommended. Any reason to pick one over the other? The 30v 1.67A one is considerably smaller, still "enough"? 30V vs 24V practical differences? https://www.mouser.com/ProductDetail/553-VPT24-4170 https://www.mouser.com/ProductDetail/553-VPT30-3330 https://www.mouser.com/ProductDetail/553-VPT30-1670 Many thanks! Quote
