Kerry Posted June 1, 2022 Report Posted June 1, 2022 Looking for some of these parts while I wait on an order... Mini-Universal MATE-N-LOK, Rectangular Power Connectors, Header, Receptacle, Wire-to-Board, 2 Position Part Number: 1-770166-0 Does anybody have some they can spare? Thanks Quote
jamesmking Posted July 12, 2022 Report Posted July 12, 2022 On 5/22/2022 at 2:33 PM, Kerry said: I'm not seeing this as obsolete on the OnSemi site (only on Mouser). Am I missing something? unfortunately now mouser, farnell and digikey now have the FQPF8N80C as obsolete and no longer manufactured... Quote
jamesmking Posted July 16, 2022 Report Posted July 16, 2022 (edited) C2M1000170D has just become available again from radio spares. if you want to avoid mouser (currently out of stock anyway) or digikeys current pricing gouging of $9+ EACH. In radio spares select production pack not standard pack to see 1213 in stock minimum purchase 5 the price is still more than pre-silicon shortage levels but is low compared to other sellers. Edited July 16, 2022 by jamesmking Quote
15lyl Posted July 17, 2022 Report Posted July 17, 2022 https://www.richardsonrfpd.com/Products/Product/C2M1000170D Quote
luvdunhill Posted July 18, 2022 Report Posted July 18, 2022 Hi! I'm looking for a CPLD that doesn't seem to be easily found, so perhaps would take a risk on a sketchy seller: ATF1502ASV-15AU44 or maybe ATF1504ASV-15AU44 or ATF1504ASVL-20AU44 (or other subs?) I'd like 3. Quote
sbelyo Posted August 16, 2022 Report Posted August 16, 2022 newark has STTH512FP in stock today. Just FYI Quote
audiostar Posted August 19, 2022 Report Posted August 19, 2022 (edited) Any recommendation for a good quality slider switch for panel mount to be used for selecting between XLR/RCA outputs? Thanks a lot. Edited August 19, 2022 by audiostar Quote
audiostar Posted August 19, 2022 Report Posted August 19, 2022 (edited) 6 hours ago, audiostar said: Any recommendation for a good quality slider switch for panel mount to be used for selecting between XLR/RCA outputs? Thanks a lot. Looking at something like this. Edited August 19, 2022 by audiostar Quote
Pars Posted August 20, 2022 Report Posted August 20, 2022 Are you going to use relays to switch them? If you were just wanting to use a mechanical switch, I believe you will need a 4P to do that. Please correct me if I'm wrong... 1 Quote
audiostar Posted August 20, 2022 Report Posted August 20, 2022 (edited) 6 hours ago, Pars said: Are you going to use relays to switch them? If you were just wanting to use a mechanical switch, I believe you will need a 4P to do that. Please correct me if I'm wrong... Yes, mechanical. It is a DPDT for two channels. Shorting pin3 to ground on the RCA out only. The XLR out is not affected by the switch. Edited August 20, 2022 by audiostar Quote
sbelyo Posted August 20, 2022 Report Posted August 20, 2022 I need at least 4 but could use 12 of KSC5026MOS for GRHV. Does anyone hve 4 that they could spare? Or a trusted source? Quote
luvdunhill Posted August 21, 2022 Report Posted August 21, 2022 I am looking for some sort of quick release system that I can use to move a wireless throttle over to the other side of the boat. The base would maybe be strapped on around grey mesh wing in the picture. Ideally I would have two bases and then disengage the plate and move it over. On the bottom of the throttle there are two female threaded inserts to attach it. This needs to be pretty sturdy in case the boat tips and pretty easy to disconnect. Any ideas what I might be able to repurpose? Quote
Rinat Posted August 21, 2022 Report Posted August 21, 2022 @sbelyo , do you think about possible substitution? I've found interesting transistor: TTC5460B. It is available at chip1stop. It has much lower max current but also lower Cob. I think you could check if it is suitable for you. Quote
audiostar Posted August 22, 2022 Report Posted August 22, 2022 (edited) On 8/21/2022 at 2:44 AM, luvdunhill said: I am looking for some sort of quick release system that I can use to move a wireless throttle over to the other side of the boat. The base would maybe be strapped on around grey mesh wing in the picture. Ideally I would have two bases and then disengage the plate and move it over. On the bottom of the throttle there are two female threaded inserts to attach it. This needs to be pretty sturdy in case the boat tips and pretty easy to disconnect. Any ideas what I might be able to repurpose? Check out the arca-swiss style mounting plates. Very sturdy, easy to detach and there are different size plates available. Used on high-end professional telephoto lenses and heavy cameras as well. Check out Really Right Stuff in in the US, Kirk as well. Those are hard anodized parts like guns, so water shouldn't be much of an issue. The plate will fit pretty nicely the throttle from below and is easy to detach within seconds from a quick release clamp. Edited August 22, 2022 by audiostar Quote
sbelyo Posted August 22, 2022 Report Posted August 22, 2022 On 8/21/2022 at 1:38 AM, Rinat said: @sbelyo , do you think about possible substitution? I've found interesting transistor: TTC5460B. It is available at chip1stop. It has much lower max current but also lower Cob. I think you could check if it is suitable for you. I haven't yet no. I did source what I need in a trade just now so for the immediate future I'm ok 2 Quote
Rinat Posted August 29, 2022 Report Posted August 29, 2022 About tubedepot's service: 1. They sent me 2 6922 "Jan Philips" tubes instead of 4 2. I checked "balanced triodes" box. What I get: The second tube has quite similar triodes unlike this one.... Quote
Pars Posted September 10, 2022 Report Posted September 10, 2022 For all you metric kids out there: what size of fasteners do you use for an L bracket to heatsink (i.e., dynahi, carbon, etc.)? M4? M5? Thanks! Quote
UFN Posted September 10, 2022 Report Posted September 10, 2022 (edited) 59 minutes ago, Pars said: For all you metric kids out there: what size of fasteners do you use for an L bracket to heatsink (i.e., dynahi, carbon, etc.)? M4? M5? Thanks! Something like that I tend to use M4 because I find it easier to tap the smaller holes, but both should be fine. EDIT: You can of course put more force on an M5, but if you have thermal compound or a silpad between the surfaces there's no need to tighten it too hard anyway IMO. Edited September 10, 2022 by UFN Quote
mwl168 Posted September 12, 2022 Report Posted September 12, 2022 On 9/10/2022 at 12:09 PM, Pars said: For all you metric kids out there: what size of fasteners do you use for an L bracket to heatsink (i.e., dynahi, carbon, etc.)? M4? M5? Thanks! I use M5 and find it good for that job. Quote
Craig Sawyers Posted September 12, 2022 Report Posted September 12, 2022 The tightening torque for devices (like TO220) to a heatsink is defined. It is less than you might think. I bought a torque screwdriver for exactly this. AN1040-D semiconductor mounting considerations.PDF Quote
audiostar Posted September 27, 2022 Report Posted September 27, 2022 On 6/1/2022 at 11:18 PM, Kerry said: Mini-Universal MATE-N-LOK, Rectangular Power Connectors, Header, Receptacle, Wire-to-Board, 2 Position Part Number: 1-770166-0 What is the difference to 1-770872-0? Looks absolutely identical to me. Quote
bbest Posted October 15, 2022 Report Posted October 15, 2022 On 8/20/2022 at 8:02 PM, sbelyo said: I need at least 4 but could use 12 of KSC5026MOS for GRHV. Does anyone hve 4 that they could spare? Or a trusted source? I also needs KSC5026MOS, for T2. On mouser it will be available in summer of next year. How know where to buy it ... Quote
Craig Sawyers Posted October 15, 2022 Report Posted October 15, 2022 It's an ONSemi part. I really don't know what has happened with ONsemi. They bought Fairchild and Sanyo, and have obsoleted most of the really useful audio parts. Anything remaining has ended up on ridiculous lead times. We're well beyond the Covid excuse, and I'm left with bungling corporate incompetence as the only explanation remaining 1 Quote
jamesmking Posted October 15, 2022 Report Posted October 15, 2022 5 hours ago, Craig Sawyers said: It's an ONSemi part. I really don't know what has happened with ONsemi. They bought Fairchild and Sanyo, and have obsoleted most of the really useful audio parts. Anything remaining has ended up on ridiculous lead times. We're well beyond the Covid excuse, and I'm left with bungling corporate incompetence as the only explanation remaining I hate nosemi... Quote
bbest Posted October 16, 2022 Report Posted October 16, 2022 (edited) 20 hours ago, Craig Sawyers said: It's an ONSemi part. I really don't know what has happened with ONsemi. They bought Fairchild and Sanyo, and have obsoleted most of the really useful audio parts. Anything remaining has ended up on ridiculous lead times. We're well beyond the Covid excuse, and I'm left with bungling corporate incompetence as the only explanation remaining so may be find some analog for KSC5026MOS, on Aliexpress some shops try to sell 1pcs for 24$ 🤔 Edited October 16, 2022 by bbest Quote
