johnwmclean Posted July 11, 2021 Report Share Posted July 11, 2021 It’s really dried up out there, I’ve looked everywhere for KSC5026M for a HV supply, if any one has stock kicking around I need 4 pcs? Happy to trade on something you may need, have quite a few bits and pieces. Quote Link to comment Share on other sites More sharing options...
mwl168 Posted July 11, 2021 Report Share Posted July 11, 2021 3 hours ago, johnwmclean said: It’s really dried up out there, I’ve looked everywhere for KSC5026M for a HV supply, if any one has stock kicking around I need 4 pcs? Happy to trade on something you may need, have quite a few bits and pieces. You got PM. Quote Link to comment Share on other sites More sharing options...
starcat Posted July 12, 2021 Report Share Posted July 12, 2021 (edited) I can get real LSK389A for 12 Euro the piece. Will be ordering some, so If anyone is interested PM me. Edited July 12, 2021 by starcat Quote Link to comment Share on other sites More sharing options...
Rinat Posted August 10, 2021 Report Share Posted August 10, 2021 Hi all! I've just bought via a friend in Tokyo a few transistors in a strange japanese shop (it has not it's own site). I want to test them and if they are genuine, then I will buy more. But how should I test them ? I've measured a breakdown voltage: 230-240 volts for 2sk216/2sj79s from Japan 228-233 volts for 2sk214s from bdent.com Is it ok for genuine parts ? Is it ok that 2sk214 and 2sk216 have almost the same breakdown voltage ? I am measuring with DY294 and etracer (tube curve tracer). I am going to trace full curves for 2sk216/2sk246gr via etracer at this thursday. Do good curves mean that transistors are genuine ? If no, then what should I measure ? Thanks for help! Ps: example of breakdown measurement for 2sk214: Quote Link to comment Share on other sites More sharing options...
Rinat Posted August 10, 2021 Report Share Posted August 10, 2021 Is this 2sk246-GR a genuine one ? The plot is Ids (Vds) for different Vgs Quote Link to comment Share on other sites More sharing options...
Craig Sawyers Posted August 11, 2021 Report Share Posted August 11, 2021 If you test parts into hard avalanche breakdown at large numbers of mA, you can permanently change their characteristics. Generally if you want to check if the breakdown voltage corresponds to datasheet values you need to limit breakdown current to the tens of microamps region. For example check the static characteristics in the original Toshiba datasheet of the 2SK246, where the breakdown voltage at each characteristic curve is limited to about 100uA. Quote Link to comment Share on other sites More sharing options...
Rinat Posted August 11, 2021 Report Share Posted August 11, 2021 2 minutes ago, Craig Sawyers said: If you test parts into hard avalanche breakdown at large numbers of mA, you can permanently change their characteristics. Generally if you want to check if the breakdown voltage corresponds to datasheet values you need to limit breakdown current to the tens of microamps region. For example check the static characteristics in the original Toshiba datasheet of the 2SK246, where the breakdown voltage at each characteristic curve is limited to about 100uA. I can't find what current measures DY294 in the breakdown test ( In the datasheet for 2SK246 Vgds is 50V and in my measurements I have 69-73 Volts. Maybe DY294 just can't detect 0.1 mA ( Unfortunately I can't limit current to 100uA in my etracer, but I will think what can I do. I hope the measurements will not damage the FET, because it measures using pulses with duration up to 5-10 ms. But I know it is still not safe. Thanks. Quote Link to comment Share on other sites More sharing options...
jamesmking Posted August 11, 2021 Report Share Posted August 11, 2021 (edited) 58 minutes ago, Rinat said: I can't find what current measures DY294 in the breakdown test ( In the datasheet for 2SK246 Vgds is 50V and in my measurements I have 69-73 Volts. Maybe DY294 just can't detect 0.1 mA ( Unfortunately I can't limit current to 100uA in my etracer, but I will think what can I do. I hope the measurements will not damage the FET, because it measures using pulses with duration up to 5-10 ms. But I know it is still not safe. Thanks. on the 200V breakdown setting my dy294 initially puts out a maximum of 712uA (tested on a brymen bm869s) and about 530uA on the 1000V setting. This is with the dy294 powered at 6Vdc from a bench power supply. if you reduce the input voltage to the dy294 to about 3VDC from the usual 6V, the 200V breakdown outputs about 180V at 375uA and the 1000V range gives about 570V at 270uA. about the lowest you can go is 2VDc input before the microprocessor crashes or the breakdown readings on the display get radically incorrect. At 2VDC input the 200V settings gives about 105V at 225uA and on the 1000V setting 365V at 171uA Edited August 11, 2021 by jamesmking 2 Quote Link to comment Share on other sites More sharing options...
penmarker Posted August 16, 2021 Report Share Posted August 16, 2021 (edited) I’ve bought some of those common anti-vandal push button switches and took one apart to study the mechanism. Are the contactors big enough for a headphone amp? Edited August 16, 2021 by penmarker Quote Link to comment Share on other sites More sharing options...
n_maher Posted August 16, 2021 Author Report Share Posted August 16, 2021 ^^^ Not sure exactly what you're asking, many of us have used switches like what you're describing but not knowing what or how you're proposing to use one it's impossible to answer your questions. Most uses that I'm aware of have been to trigger relays (power on/off, source selector) in which case it sees very little voltage or current and is serving its intended function. If you're thinking about some other application, it'll require careful consideration. 1 Quote Link to comment Share on other sites More sharing options...
penmarker Posted August 16, 2021 Report Share Posted August 16, 2021 Thank you, that made perfect sense. This switch is rated for 220V and I was planning to use it as the power switch. A trigger for a relay sounds a lot more safe it seems. Quote Link to comment Share on other sites More sharing options...
Beefy Posted August 16, 2021 Report Share Posted August 16, 2021 44 minutes ago, penmarker said: Thank you, that made perfect sense. This switch is rated for 220V and I was planning to use it as the power switch. A trigger for a relay sounds a lot more safe it seems. Well, go with the switch rating then, relative to your intended usage. What exactly does the data sheet say, and what are you planning to install the switch in? I use a locking anti-vandal switch rated for 250V @ 3A for mains power switching duties in a couple of pieces of gear. They are running on 120V, draw about 0.25A steady-state, and are behind 1A fuses. Rating exceeds operating conditions, part is good to use. 1 Quote Link to comment Share on other sites More sharing options...
penmarker Posted August 17, 2021 Report Share Posted August 17, 2021 These came from china so there are no datasheets. I was planning to put these in a new Dynahi but I've decided to get the momentary counterpart to trigger a relay instead. Quote Link to comment Share on other sites More sharing options...
Craig Sawyers Posted August 17, 2021 Report Share Posted August 17, 2021 I use illuminated latching anti-vandal switches on all my gear. The interesting thing is that although the LED connections have a + and a - moulded in, the LED is bidirectional, and illuminates equally whichever way it is connected. At least with the ones I use. Blue LED of course. I also set the current on all front panel LEDs to be very low, so they don't intrude when listening in the dark. Quote Link to comment Share on other sites More sharing options...
Beefy Posted August 17, 2021 Report Share Posted August 17, 2021 5 hours ago, Craig Sawyers said: The interesting thing is that although the LED connections have a + and a - moulded in, the LED is bidirectional, and illuminates equally whichever way it is connected. At least with the ones I use. The polarity is usually there for the dual color LEDs. I bet the single LED and dual LED units are identical to streamline manufacturing and save costs, except the 'single' units have two LEDs of the same color. 7 hours ago, penmarker said: These came from china so there are no datasheets. I was planning to put these in a new Dynahi but I've decided to get the momentary counterpart to trigger a relay instead. Maybe I'm overly cautious, but I wouldn't use a part if I didn't have a spec sheet. Quote Link to comment Share on other sites More sharing options...
Craig Sawyers Posted August 17, 2021 Report Share Posted August 17, 2021 FWIW I use these https://www.te.com/commerce/DocumentDelivery/DDEController?Action=showdoc&DocId=Data+Sheet1-1773878-3_Alcoswitch_AntiVandal0517pdfEnglishENG_DS_1-1773878-3_Alcoswitch_AntiVandal_0517.pdf2213775-3 The style I use is at the top of the second page. 1 Quote Link to comment Share on other sites More sharing options...
Beefy Posted August 17, 2021 Report Share Posted August 17, 2021 43 minutes ago, Craig Sawyers said: FWIW I use these https://www.te.com/commerce/DocumentDelivery/DDEController?Action=showdoc&DocId=Data+Sheet1-1773878-3_Alcoswitch_AntiVandal0517pdfEnglishENG_DS_1-1773878-3_Alcoswitch_AntiVandal_0517.pdf2213775-3 The style I use is at the top of the second page. Yep, looks about right. I bet they use the same casing across all the styles, and just use two of the same LED for the single color version, meaning polarity doesn't matter. And for the 19+ mm sizing, contacts rated at 250V 3A just like the eSwitch I've used recently. To @penmarker, again, maybe I'm overly cuatious, but I think you are much better served using a quality switch of known providence. Quote Link to comment Share on other sites More sharing options...
penmarker Posted August 17, 2021 Report Share Posted August 17, 2021 That's the safest choice I agree. Quote Link to comment Share on other sites More sharing options...
Kerry Posted October 18, 2021 Report Share Posted October 18, 2021 I'm looking for some LT1021DCS8-10#PBF. I need at least 4 but would take more. Anybody have some their not using? Quote Link to comment Share on other sites More sharing options...
Pars Posted October 18, 2021 Report Share Posted October 18, 2021 I don't Kerry, but I used to buy directly from Linear Technology. Now that they have been bought by ADI, I don't see how to do that on their website. I couldn't check to see if they even have availability. Quote Link to comment Share on other sites More sharing options...
Kerry Posted October 19, 2021 Report Share Posted October 19, 2021 Thanks @Pars. I had a great veteran builder PM with a few pieces. I think I'll be ok for now 1 Quote Link to comment Share on other sites More sharing options...
Beefy Posted October 24, 2021 Report Share Posted October 24, 2021 So I'm curious what the current SOTA is with respect to non-potentiometer volume control for a balanced DIY amp. Context: I'm working through an repair/refine/replace blitz of all my DIY gear. My Exstata - which if you can believe it is still kicking after 10+ years - has one of the dual PGA2320 volume controls that Marc developed way back then. It works great, and was incredible $$$ value, but it seems ripe picking for a small update project. I see the TPA Joshua Tree is still kicking, still dead easy to implement, still has limitations of variable input impedance and always-on relays. AMB's δ1 uses latching relays and has constant impedance, but having to do a full Arduino control board build seems a but nutty for just an attenuator. And Kevin was busy a few years back with something that seemed technically excellent, but getting PCB's and programming done is probably way beyond my skillset and the time I am willing to invest. Thoughts or suggestions? Thanks! Quote Link to comment Share on other sites More sharing options...
Pars Posted October 24, 2021 Report Share Posted October 24, 2021 The Gerbers for Kevin's attenuator board are still available. I believe Kerry had worked up a controller board with rotary attenuator for that as well, including the software? One control that looks good and has good reviews is the Muses72320. I'm currently (very slowly) building a UGS Muse preamp based on the Pass UGS and using the NJR MUSES72320V-TE2-ND IC. There is a project on diyaudio using these chips and apparently can handle up to an 8 channel control. https://www.diyaudio.com/forums/swap-meet/322983-muses-volume.html. The chips seem to be in short supply right now (both Digikey and Mouser carry them, both out of stock). 1 Quote Link to comment Share on other sites More sharing options...
Beefy Posted October 24, 2021 Report Share Posted October 24, 2021 (edited) 3 hours ago, Pars said: The Gerbers for Kevin's attenuator board are still available. I believe Kerry had worked up a controller board with rotary attenuator for that as well, including the software? One control that looks good and has good reviews is the Muses72320. I'm currently (very slowly) building a UGS Muse preamp based on the Pass UGS and using the NJR MUSES72320V-TE2-ND IC. There is a project on diyaudio using these chips and apparently can handle up to an 8 channel control. https://www.diyaudio.com/forums/swap-meet/322983-muses-volume.html. The chips seem to be in short supply right now (both Digikey and Mouser carry them, both out of stock). That Muses project looks really neat. But yeah, availability of the chips is quite bad, and it will almost certainly preclude it as a pre-Xmas project. Will definitely keep an eye on it for new builds though, so thanks! I'm sure the Kevin/Kerry option is probably the best, but making my own boards is the difference between a weekend soldering/wiring project, and learning an entire new skill. Unfortunately, I think my brain is full. Edited October 24, 2021 by Beefy Quote Link to comment Share on other sites More sharing options...
Pars Posted October 24, 2021 Report Share Posted October 24, 2021 You can have boards run for quite cheap at places like seeedstudio, etc. Upload the zip of the gerbers, make your selections, etc. and you're good. Quote Link to comment Share on other sites More sharing options...
