13 hours ago, luvdunhill said:
I saw that, but it said "recommended piercing plan". I have the part and it's really hard to measure. It could probably work with a slightly thicker PCB. I am thinking Kerry used these connectors and perhaps he used a > 1.57mm board and can provide some insight.
I like these connectors.  I've only used the vertical with 1.6mm boards, but there was plenty of extra length and I would typically need to trim them.
Thanks Kerry - how thick would you venture?
You have some interesting projects going on!
Always looking for prototypers :) I am working on an ultra low distortion all SMD buffer, probably have a layout done in a day or so.
What's the difference between the TKD variable potentiometers and variable attenuators? I know the datasheets say they are wired differently but how does that translate in terms of application? Does one track better then the other?
The potentiometers are continuously variable pots, whereas the attenuators are stepped attenuators and made up of fixed resistors, with a fixed number of steps, so a fixed jump between steps (2dB on many of them). Other examples of stepped attenuators would be Dact, Goldmund, etc. These probably track better, but the fixed number of steps could be a problem depending upon the volumes selected, and so on.
That's not what I was talking about, I think. TKD list stepped variable attenuators and variable attenuators as separate items. I noticed that they have CP600 listed in both the variable attenuators and variable potentiometers. I thought it was the same item at first but looking at the data sheet they appear different.
http://www.tkd-corp.com/products/att/pdf/cp600as-e.pdf
http://www.tkd-corp.com/products/pot/pdf/cp600ps-e.pdf
I was going through some components for a project and realized that my trim pots were Chinese clones of Bourns (Baoter). They measure and tune fine though, look pretty decently made. Is there any major issue with using them?
Thanks, for the link. I guess I'll err on the side of caution for this build and get some proper ones from mouser. But I'll keep them around for less heavy stuff, like if I want to rebuild an old stax amp and replace its one turn pots.
I bought the black Delrin one on ebay from knoberik and haven't had a chance to put it in an amp but it looks good quality and Stax headphones plug in fine. It looks like the same guy is making the teflon one... not sure why he made a different account.
The vertical work great with 2mm thick boards. The R/A ones just barely fit. I probably would add a bit of adhesive to make it extra secure.
I had another quick dumb question. Looking at a lot of the LED lit power switches, the LED's have a 12VDC rating. Since most of these are meant for things like car applications where they're running at 14-15VDC anyway, is there any reason not to just let it run a little overvolted off a 15V PSU straight?
or a simple circuit with a trimmer/transistor and a couple of resistors and you can dial in the brightness...not much to it...
Thanks for the recommendations guys. It's a good point about the brightness. I almost forgot how blinding they can be depending on the manufacturer and color. Looks like I have everything in my parts box already but an LM317 to make a variable one, and they're cheap. I always like a fifty cent solution.
