Part Sourcing Assistance/Advice Thread
I bought a few aluminum chassises from VT4C before. The QC is non-exisitent. One of the chassis is impossible to put together due to serious misalignment. One of the chassis cover was not even rectangular.
Don't have experience with their other products.
  • Replies 1.5k
  • Views 440.9k
  • Never underestimate the obfuscating twats on diyaudio I asked a question regarding Kemet vs. Vishay-Polytech tantalum-polymer capacitors (since the Vishays are considerably cheaper and appear to
  • pray to the deity of semiconductor manufacturing (in a reverential voice tinged with grief)....  🙏 oh Nosemi please hear our plea for our DIY hobby.... in the name of silicon pleas
  • Craig Sawyers
    Craig Sawyers
    It isn't confined to On-Semi. Rohm did the same thing with all their low noise offerings ages ago, So did Renesas with the J79/K216 - in fact lateral MOSFETs are a thing of the past. Most p-channel jF
1 hour ago, johnwmclean said:
http://www.viljomarrandi.com/gallery/
Vilts will make any custom knob to your liking.
I am actually working on a better way to get all your knob needs met - www.knobsly.com. Prices are still tentative for the custom part and I have bunch of knobs that need to get photographed and put up there. But it's a start :)
Your custom order form doesn't have a shaft diameter parameter, but other than that, that looks excellent! (Sending you a PM shortly.)
Looks like these Toshiba MOSFETs won't fit a #6-32 screw (I had to drill them out slightly). Is there an equivalent part to these Aavid heatsinks that accepts a metric screw? Any other ideas or similarly sized heatsinks?
Ran into the same problem a while ago. and found two potential solutions:
1) There is an equivalent size (as far as I can see) with an M3-hole called the SK437 xx STS 2 from Fischer Elektronik (xx is length in mm.). However, note that only the STS 2 version has the right pin configuration for our use. Available from TME in the EU, but I haven't checked for other sources.
2) I mounted my parts with a (nylon) M3 screw, where I trimmed the head slightly with a Dremel-type tool so it would fit between the fins of the original Aavid HS, with an M3 nut on the device side. A bit of a faff to do, but seems to work OK.
//UFN
Very nice. The dimensions are "close". I will try and order some and then if needed incorporate them into my board respin. Thanks!
Edit: and bought them all :)
Can anyone help with a source for the HE90 Fischer panel sockets? I am trying to decide if I bother with one or just go with more Stax sockets.
Ouch - Thanks Spritzer. I was hoping for another source other than moon-audio, but this helped make up my mind. All Stax jacks it is :)
I placed an order, how can you resist work like that
I got my order, how can you resist work like that
sandblasted titanium finish, opted for the tritium tube so I can see things in the dark
Just received a titanium knob from @vilts for an RK50. Looks and feels pretty fantastic!
  • 4 weeks later...
You sure that B&K will measure that low? My Fluke 89 will only go into nF. Like about 10...
I have a real simple question maybe someone can help me with. Given an opamp connected as a buffer, if instead shorting the output and inverting input, I place a resistor here, this should have the effect of bandwidth limiting the buffer effectively, correct? How can I calculate the effect of this value on the overall bandwidth? I can't seem to find this discussed in any detail in intro texts on opamp circuits.
I've checked with all my usual suspects on the bookshelf, and the only thing that I can find relates to minimising DC offset - in a unity gain buffer fed by a source with output resistance R, you put R between output and inverting input - so the same bias current flows into both inputs and hence minimises output offset in a simple way.
Why would it act as a bandwidth limiter?
Analog Devices (actually now TI) just announced the obsolescence of the lowest available noise biplolar parts - pnp matched doubles with a noise of <0.7nV/root Hz and 1/f corner of 3Hz - SSM2220 and MAT3 http://www.analog.com/media/en/PCN/ADI_PDN_16_0034_Rev_-_Form.pdf .  The MAT12 is still current, buy eye poppingly expensive in a metal can only.  These have a noise equivalent resistance of about 30 ohms.
The only thing I know of that used to have lower noise was the late lamented Rohm 2SB737 with <0.4nV/root Hz and <10 ohms equivalent resistance.  That was just too damned useful to survive without being discontinued.  Lots of fake Chinese stuff out there.
Also the On Semi 2N5087 low-ish noise PNP is now obsolete too.
What have manufacturers got against audio?
Series resistance forming a pole with the input capacitance/Miller capacitance of the inverting input?
Edited by cetoole
These are sad days indeed.  We should all be using opamps for everything...  ^_^
I'm sure somebody will make high performance parts for us but they won't be as cheap as the K389/J109 were back in the day.
I've been thinking about replacing Phoenix Contact terminal blocks on future builds with Molex connectors. The SPOX line with a 5.08mm pitch seems like it would be a drop-in replacement on all Mafia PCBs. I am worried about the voltage ratings, though: Molex datasheets say 250V, whereas Phoenix datasheets for the terminals I've been buying say 400V.
Judging by photos I saw posted, some people here use Molex. What's your take on this?
