If it’s ksc5026 in KGSShv style power supply you can probably use stn0216 stn0214 intstead. Solder it standing on the to126 pads (might be to220 pads on your board?). Power dissipation there is something like 40 – 60 mW, I think.
Edited by JoaMat
  • Like 1
  • 4 weeks later...
I've been searching for some DN2540 to fix my KGSSHV Carbon but can't find them anywhere?  Do you guys know of anywhere I can get them?  Or can I substitute them with the small current version in TO-92 package?
I’ve been using the DN2540 in TO-92 package since my first Carbon build without any problems on the amp board. However I’ve seen two instances where the DN2540 on the GRHV developed a Drain-to-gate leakage. That caused excess current thru the HV PNP. In one case (my own build) it was caught in time and didn’t do any real damage, in the other case (someone else’s board with a TO220 DN2540) the PCB was cooked, the ST9360 failed and brought down both the BC557s. The leakage problem is regardless of the DN2540 package. I’m suspecting in the cascode CCS there may be a corner case where it is stressed beyond the safe limit.
Maybe DN2535 (max voltage 350V) will work. Main difference to DN2540 (max voltage 400V) seems to be the maximum voltage. In stock at Mouser for roughly the same price as DN2540.
  • Like 1
did the SiC survive (someone else’s board with a TO220 DN2540)?
The SiC did survive and still tested good all the way to 1700V on a curve tracer. I guess the ST9360 had a slow death and the BC557s gave up before more current could damage the SiC.
I've seen similar.
DN2540 leaking usually shows up as the output voltage of the PSU drifting.
As far as I remember the supplies breaking down was all wired as negative rails.
However, I have not seen it on any GRHV using the cpc1117.
They did suddenly show up in quantity at Mouser last time so it might happen again.  I just found out about it as I had some on order and they suddenly shipped, way ahead of the set date.
pray to the deity of semiconductor manufacturing (in a reverential voice tinged with grief)....
oh Nosemi please hear our plea for our DIY hobby....
in the name of silicon
please bless us with some manufacturing
and fill up our inventories
In the name of NPN and PNP
blessed are the mosfets, depletion or enhancement
for the DIYers shall inherit 10M90S
and it was good
Let not the ebay scammers rebrand and re-etch
for they will be accountable to silicon
and burn in the foundries of ixys
for all eternity
Let it be known Toshiba and NEC will escape Renesas
Sanyo and Fairchild will rise again
and return to us all
for now and for evermore
Ahmen.
(The DIY hymn book chapter 11 covid 19 to recession 2008 verses 1-4)
Edited by jamesmking
  • Like 6
  • 4 weeks later...
You guys know any other places that sell baseplates similar to what hifi2000 has?
I've used a few smaller ones and I'm pretty hooked, but shipping from Italy for the larger plates is a bit of a pain.
Does the diyaudio store have the one you want? They have US stock, so should be cheaper.
Sorry I wasn't clear- that page is from the diyaudio store, when you add a few pieces to the cart they tack on like 50 dollars shipping. I'll just grab a few extras when I buy the next case from them.
Yes, I realized that when I looked at diya. Your screenshot was from there. I know they do have US stock on some stuff; wish they showed that more clearly.
I'm looking to build a Gilmore CFA3 and GRLV, anyone have boards available?
Also, some sand is out of stock. Does anyone have the following, or know if the following subs will be OK:
CFA3:
MJF15030G: Can I sub MJE15028G? It has 120v C-E voltage vs 150v of the orig, and I'd need shoulder washers/isolation washers.
PZTA56 Can I sub DPLS4140E-13 ?
GRLV:
MJW21194G Can't find a decent sub here. Thoughts?
DN2540N3-G Can I sub DN2540N3-G-P003 Seems the same. Confirmed
OPA134, I assume I can sub the SMD version with an adapter board, but the SMD version is out of stock too... Other good subs? OPA228?  opa228 Confirmed
Transformers:
These three were recommended. Any reason to pick one over the other? The 30v 1.67A one is considerably smaller, still "enough"? 30V vs 24V practical differences?
https://www.mouser.com/ProductDetail/553-VPT24-4170
https://www.mouser.com/ProductDetail/553-VPT30-3330
https://www.mouser.com/ProductDetail/553-VPT30-1670
 Many thanks!
