luvdunhill Posted June 2, 2018 Report Posted June 2, 2018 I just paid $1.55 for one RN60D resistor at Digikey. Heh. Quote
Pars Posted June 2, 2018 Report Posted June 2, 2018 (edited) Hehe. In order to avoid paying $3.40@ for some Wellwyn RC55s from Mouser for the Salas phono stage I built, I lucked out on some from element14 (Newark) or somewhere where I had to buy something like 12-15 of them (one off) but got them for $1@ or something like that. Other values of the same resistor were on the order of $1.25@ or so. I just wouldn't pay that price each. Edited June 2, 2018 by Pars Quote
Helium Posted June 22, 2018 Report Posted June 22, 2018 Stupid question. Now searching for tube socket for KGST, GG and BH. Lot's of options. Aside from the material they are made of (bakelite, ceramic, teflon), I'm stuck at terminal type. https://www.ebay.com/itm/301444050005 https://www.ebay.com/itm/301838302161 Are these gold pins really intended to be soldered into PCB? Will solder adhere to gold plated surface? Or better look for sockets with leaf terminals? Quote
jose Posted June 22, 2018 Report Posted June 22, 2018 I´m using the same kind of socket (but I prefer bakelite). So far I have not had problems. You can solder them to the Pcb without problem (always when you have a powerful soldering iron, about 25 / 30W). I recommend that when you solder them to the plate, you have a valve inserted. This will keep everything aligned. Quote
spritzer Posted June 23, 2018 Report Posted June 23, 2018 These are similar to the pins we use on the Stax sockets so not a problem to solder to them. Quote
Helium Posted June 23, 2018 Report Posted June 23, 2018 Thank you jose and spritzer. Thanks for the hint to have valve inserted. I usually do the same when soldering Mill-Max DIP sockets in order to prevent pins from moving when socket plastic is heated. Quote
lkong Posted July 28, 2018 Report Posted July 28, 2018 (edited) I need to make/buy some very short and soft (5-10cm) USB cables. Any suggestions? Edited July 28, 2018 by lkong Quote
luvdunhill Posted July 28, 2018 Report Posted July 28, 2018 Can anyone give me the guidelines for drawing the CMC octal socket? The diameter of the circle and pin diameter should suffice. Quote
kevin gilmore Posted July 28, 2018 Report Posted July 28, 2018 the Teflon drifts a bit. So the diameter is .716 inch and the hole size is 81th have not found a socket that does not fit or fits tight yet. Quote
luvdunhill Posted July 29, 2018 Report Posted July 29, 2018 16 hours ago, kevin gilmore said: the Teflon drifts a bit. So the diameter is .716 inch and the hole size is 81th have not found a socket that does not fit or fits tight yet. Thank you! I'm trying to push the boundaries around spacing a pair of EL34 output tubes pretty close to each other. It seems standard minimum recommendation is spacing of 1.5 times the envelope diameter. The EL34 is 33.3mm and I'd like to space them 1" apart (2" center-to-center). What about rotating one 90 degrees of the other, or another specific orientation, as the heat dissipation patterns are directional, I'd think. Do you have any guidance on positioning, assuming I'd like to get them pretty close together - like you see on Atma-Sphere, etc? Quote
penmarker Posted September 9, 2018 Report Posted September 9, 2018 Does anyone know where can I get blanking plates for IEC inlet holes? I found blanking plates for XLR is pretty common but I can't find any info for IECs. Do they even exist? Attached is the blanking plate for XLR Quote
UFN Posted September 9, 2018 Report Posted September 9, 2018 (edited) I have never seen any, but that doesn't mean they don't exist. I would be doubtful though - Neutrik makes the blanking plates because you can get pre-punched 19" rack panels for Neutrik D-series jacks where there may be more holes than you need and so the blanking plates are handy for keeping dust out etc.. I can't imagine many cases where there are many more IEC-holes in an enclosure than you need ? Edited September 9, 2018 by UFN stupid autocorrect... Quote
Pars Posted September 9, 2018 Report Posted September 9, 2018 ^ This. Plus the Neutrik blanking panels are for a known standard jack series. I don't know if there is a standard IEC hole size (it seems that most of mine are all over the map), but that might make it more difficult to find. I know a lot of the chinese vendors on ebay, etc. all sell cases with the IEC cutout (presumably to a standard size), so perhaps someone does make some. Quote
dsavitsk Posted September 9, 2018 Report Posted September 9, 2018 Front Panel Express will cut a cover for you for about $15 Quote
cspirou Posted September 9, 2018 Report Posted September 9, 2018 (edited) Or just put in the IEC socket anyway and use a plug Edited September 9, 2018 by cspirou Quote
penmarker Posted September 10, 2018 Report Posted September 10, 2018 Thanks everyone. I've discussed this with some friends and we all agreed its very uncommon if they exist at all. My case already has IEC mounting hole but I'll be using external PSU. I'm planning to just cut a rectangle out of some plastic/acrylic/pcb, sand & spray, then mount from the inside. 1 Quote
arteom Posted October 11, 2018 Report Posted October 11, 2018 Not able to find PZTA06 transistors in stock to complete a Dynalo mini build, anyone have any tips on where to look? Ebay seems to be only place to get them, not sure if reliable - https://www.ebay.com/itm/9PCS-PZTA06-TRANSISTOR-GP-NPN-80V-SOT-223/372271869750?hash=item56ad21ef36:g:vmQAAOSw9hJbVyi8:rk:5:pf:0 Quote
Pars Posted October 11, 2018 Report Posted October 11, 2018 Yeah, those seem to be a problem to find right now. I don’t know that I would trust anything from eBay. How many do you need? I may have enough that I could spare some.Sent from my iPhone using Tapatalk Quote
arteom Posted October 11, 2018 Report Posted October 11, 2018 3 hours ago, Pars said: Yeah, those seem to be a problem to find right now. I don’t know that I would trust anything from eBay. How many do you need? I may have enough that I could spare some. Sent from my iPhone using Tapatalk Just the 16 needed for that build, would very much appreciate it if you had any to spare, let me know! Quote
Scgorg Posted November 18, 2018 Report Posted November 18, 2018 Currently sourcing parts for a KGSSHV, using a BOM I got from spritzer (don't know who made it). Have been able to find most stuff, my main problem is the 130V zener (625-Z4KE130-E3 on mouser), the 3N254-E4/51 (currently EOL and minimum order of 120, which is more than I'll need in a lifetime probably), and the 1000pf/1000V cap. I found the 562R10TSD10 as a possible replacement for the cap, would that one be fine? For the 2 others I can't find anything that looks like a good replacement. Any help is appreciated. Quote
spritzer Posted November 18, 2018 Report Posted November 18, 2018 This 130V zener works just fine: 863-1N5952BRLG You can use this 833-2KBP06-BP instead of the 3N254 562R10TSD10 will be just fine. 1 Quote
sbelyo Posted December 24, 2018 Report Posted December 24, 2018 (edited) is there a reliable source for 2SJ109BL ? I need 2 Edited December 24, 2018 by sbelyo Quote
Pars Posted December 24, 2018 Report Posted December 24, 2018 2SJ109BLs are a tough ask (for genuine ones). You could use singles (2SJ74 or Linear equivalents), or the Linear duals with some lead manipulation. Maybe: https://www.diyaudio.com/forums/swap-meet/320192-toshiba-2sj109bl.html This guy... maybe: https://www.ebay.com/itm/Matched-quad-of-2SK389BL-2SJ109BL-100-original-and-genuine-Toshiba-015-idss9-9/282424664232?epid=593519663&hash=item41c1d260a8:g:2-oAAOSwuxFYtUc~:rk:3:pf:1&frcectupt=true Quote
sbelyo Posted December 24, 2018 Report Posted December 24, 2018 Thanks Pars... I sent the diyaudio person a PM. There was a US seller on ebay that had them listed for a while now and of course hasn't relisted them in a month. I'll see what happens Quote
