I just realized that I probably won't ever be able to afford a decent multichannel setup, even though I believe that is the primary benefit of the new digital formats... perhaps a lot of "stereophiles" are the same way - they don't actually have a philosophical bias against multichannel recordings, they just can't stomach the cost of buying the new equipment (e.g., 5 more speakers, amps, preamps/controllers, cables, stands, etc.).
So I am a stereophile by default.
I just don't really like how multichannel sounds. I never heard a multichannel setup that was even near in quality to a very good stereo setup. Also majority of the music that I listen to was recorded in 70's and 80's :D
On an idealistic basis, I like 4.0 better than 5.1 It eliminates the subwoofer and the centre channel. If there were no centre channel then most DVDs wouldn't be mono with rumble feature and occassional rear speaker special effect and would at least be stereo.
Unplug your centre speaker and see how long you can put up with having to use subtitles.
